Question about Qep 60083 7" Professional Tile Saw
I need to remove the top of the saw. I have removed the four bolts under the four corners. It seems to be held by something in the corner where the on and off switch is. Can you let me know how to remove this I need to replace the nut on the gaurd support. Thanks in advance for your help Angie
2008 chevy equinox driver seat removal
It is held in place by four bolts under the plastic trim covers at each corner of the seat, remove them and unplug the electrical connectors to the seat.
Jun 26, 2017 | Seat Cars & Trucks
How do I remove the rear baffle on a craftsman rotary lawn mower 917.374352?
It is held in by four bolts. Two in rear under the rear door and two by the rear wheel adjusters. There also may some additional sheet metal in the left rear corner may need to removed.
Oct 29, 2014 | Garden
How to replace ignition coil on 1991 GMC Suburban
check out AA1car.com It helped me out a lot and it's free.. An awesome site if you are willing to search a bit. The coil is on top of the distributor cap. remove the top cover then the 4 small bolts holding it on. Unplug it fro the side, 3 wires... then just replace. Make sure to reinstall the ground wire that is located under one corner of the coil and held in place by the mounting bolt.
Nov 08, 2013 | 1991 GMC Suburban
Changing my fuel line on my husqvarna141 chain saw and after pulling line out cant figure out where it threads back in to tank
The 141 uses a a very small bore fuel hose, it feeds through the top of the crankcase under the carb, and into the top of the fuel tank, it is not easy to do without removing the fuel tank from the crankcase. To remove the tank, start by removing the air filter held with two screws, remove the two 8mm nuts securing the filter back plate and remove, remove the two 7mm studs securing the carb, and the two cross head screws securing the carb support plate, remove the carb and throttle wire, now remove the four screws securing the starter cover ( these screw into two of the anti vib mounts ) turn the saw over and remove the 4mm allen screw securing the chain catcher at the front corner of the saw, remove the single cross head screw at the rear top corner of the saw and remove the plastic orange cap, the tank will now come away with the top handle as a unit, you can now see and fit the fuel hose.
Oct 18, 2012 | Husqvarna Chain Saw 20" Bar
How to replace the coolant reservior?
they are easy to replace, held in by 2 acorn bolts up top and one on the lower corner toward the front of the car-then, you remove a small hose up top and a slightly larger hose near the bottom corner, it lifts right out.
Apr 17, 2011 | 2000 Oldsmobile Intrigue
Does the 1989 honda civic sedan with a/t have a transmission drain plug?
Unfortunatly no. Can be a messy job removing the pan to change the fluid but here is a tip. Unbolt all the pan bolts except the four corners (if you get the idea) then remove two of the four corners on one side. Then slowly loosen the other two a little at a time on each bolt so as you are loosening it will kind of be like you are pouring something in a bowl in your sink if you can understand what I am saying. I hope this helps and good luck.
Feb 15, 2011 | 1989 Honda Civic
Replace rt side (psg) front headlaight assembly, for a 97 cadilac deville.
pull upward on black cover above headlamp assy. (marked pull here for headlamp service) you will then see on the front side a large bolt above the lamp assembly that holds it to the front of the car. it is a 10MM socket you will then need to remove a similar bolt on the top and bottom on the center front of the car where the assembly bolts up to the sheet metal. on the corner near the cornering lamp is a star shaped head bolt. (looks like star of david) you will need another small metric socket to remove this. this will free up the cornering lamp from the headlamp assembly. gently pull forward and away from headlamp assembly. remove both light pig tails by gently twisting on pigtails. you will then see 2 nuts which are also 10mm remove these and gently pull forward on entire headlamp assembly. you will need needle nose pliers to compress the head of plastic retaining tabs on headlight and signal light pig tails where they are held into the headlamp assembly. gently twist hi-low beam sockets free of the headlamp assembly then do like wise with the signal lamps. to install reverse procedure as above. note: the side with the cornering lamp has a tab that must fit back into tab-hole in front sheet metal of the front fender.
Dec 18, 2010 | 1997 Cadillac DeVille
Button has pushed in dropping into opening behid front panel;To access, must top of washer be removed to allow access to fron wall where button has dis-engaged?
This model usually has two screws hidden under corner trim sections that snap on each end. The best thing to do is grab the top part of the endcap and pull back towards yourself. this will make it come loose and then remove it. Under these endcaps will be two screws...one in each corner , remove these and pull towards you and up the whole console should come up......now, sometimes, there are four screws holding a back cover on...if so, just remove these and you can see everthing there. the start switch just is held in place by a plastic tab thats attached to the switch. The switch has a square shape which you line up into frame and turn switch like 1/4 turn until the locking tab snaps into place...its possible that the switch fell apart and if it did...you will need to replace switch
Bruce Denton
Dec 12, 2010 | Kenmore 84052 Dryer
I need to replace the front driver's seat in a 95 saturn...
seat frame base is held to floor with four bolts, one in each corner.  Begin by moving seat to the full forward position, remove the two rear seat frame bolts, they may be covered by carpet and plastic trim.  Them move seat to full rear position and remove both front frame bolts, the seat will now be free to remove.  Keep me posted
Jan 06, 2009 | 1995 Saturn Sl
Headlight assembly
Pull upward on black cover above headlamp assy. (marked pull here for headlamp service) you will then see on the front side a large bolt above the lamp assembly that holds it to the front of the car. it is a 10MM socket you will then need to remove a similar bolt on the top and bottom on the center front of the car where the assembly bolts up to the sheet metal. on the corner near the cornering lamp is a star shaped head bolt. (looks like star of david) you will need another small metric socket to remove this. this will free up the cornering lamp from the headlamp assembly. gently pull forward and away from headlamp assembly. remove both light pig tails by gently twisting on pigtails. you will then see 2 nuts which are also 10mm remove these and gently pull forward on entire headlamp assembly. you will need needle nose pliers to compress the head of plastic retaining tabs on headlight and signal light pig tails where they are held into the headlamp assembly. gently twist hi-low beam sockets free of the headlamp assembly then do like wise with the signal lamps. to install reverse procedure as above. note: the side with the cornering lamp has a tab that must fit back into tab-hole in front sheet metal of the front fender
Dec 15, 2008 | 2001 Cadillac DeVille
Qep 60083 7" Professional Tile Saw Logo
Top Qep Saws Experts
JOHN LAPIER
Terry Hair
Tim Marx
Tim Marx
Are you a Qep Saw Expert? Answer questions, earn points and help others
