You can go to:
Lexmark X1290 Downloads
Make sure you have the correct one for your operating system - 32 bit or 64 bit. If you are not sure, you can go to Control Panel and select
System. It will say 64-bit in the window. If it does not say 64-bit, assume it is a 32-bit.
When you go to download, choose
Save from the download window and direct it to save the file to your Desktop.
You need to disconnect the USB cable, uninstall any previous software if it is on your computer and the printer from your Printers folder. (Through the control panel.)
Make sure the printer is on with ink and paper. Connect the USB cable. If (when) you get a
New Hardware Found window, simply cancel it out.
Run (double-click) the file on your desktop that you downloaded. Follow the installation instructions. That should get you going.
Thanks for using Fixya.
Also for other links (User guides, other support) here is a link to that page:
Lexmark X1270 Support
(NOTE: Although that says X1270, it is good for all 1200 series printers.)
