When i connect the vga to pc it does not display
  • 998 Answers
Try to check the video settings of your flat panel TV if vga is properly selected. If your VGA wire is connected on your TV you need to select the VGA settings for it to properly work.
Posted on May 19, 2011
Monitor vga connection hdmi
You can check these:
1. Connection: Make sure that both ends are connected properly,
2. Monitor: Most newer monitor has 3 options: VGA or DVI or Automatic. Test the "Automatic" and "VGA" options.
3. Cycle your display option using your laptop keyboard (Alt + F4). Please tap the F4 several times (to change the option to Mirror, Laptop Display only, External Monitor only)
Dec 25, 2013 | Packard Bell iMedia Computers & Internet
MY acer ZD1 screen has gone black how do i connect it to a pc screen blind
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the Right/Rear of the laptop.
Example of a VGA connector (Port), and a VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for an example of a VGA Cable.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Yes. You can also connect an HDMI cable to it, and HDTV with this capability.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings the display should show on the external VGA monitor.
If not;
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY
Press, and hold down on the Fn key. At the SAME time tap once on the F5 key. The F5 key is the Display Toggle-Over key.
Regards,
joecoolvette
Feb 19, 2013 | Acer Aspire 5920-6423 Notebook
I have hp compaq 6910p laptop, which worked at its best for several weeks after it was bought. but few days back it started freezing, taking too much time in startup and to run programs aswel. I was t
Instructions
Plug one end of the VGA connection cable into the VGA port on the external display. Tighten the knobs on the VGA connector to secure the cable to the monitor.
Plug the other end of the VGA connection cable into the VGA port on the on your Compaq 6910P. The VGA port is located on the back of the device. Tighten the knobs on the VGA connector to secure the cable to the laptop.
Plug the external display's power cord into a wall outlet. Power on the device by clicking its "Power" button.
Boot your Compaq 6910P.
5
Click on the "Start" button in your task menu.
6
Select "Control Panel," then click "Appearance and Personalization."
7
Click "Personalization" in the window that appears.
8
Select "Display Settings."
9
Select "Mirrored" from the New Display Detected dialog box to have your displays mirror each other.
10
Select "Extended" from the New Display Detected dialog box to have your display function like one, large workspace.
11
Select "External Display Only" from the New Display Detected dialog box to use only your external monitor.
12
Click the "OK" button to keep the changes and exit the setup.
Jan 10, 2013 | HP Compaq 6910p Notebook PC PC Notebook
I JUST CONNECTED THE PC TO TV WITH VGA TO RCA CABLE BUT PICTURE WON'T COME ON THE TV SCREEN
Make sure that you have the correct display mode selected. While many connections like a VGA to VGA connection will automatically detect, I don't think a VGA to RCA adapter will. Go to control panel/display and see if your computer has detected the second display.
Also make sure the RGB or RCA is selected as the input source on your TV.
Once these are both set correctly you should be in business!
Dec 21, 2011 | Computers & Internet
P5KPL-AM mb bios only four line display
Try another monitor, if problem still exists your VGA is damaged, if youre using the onboard vga then connect a PCIex vga card get into bios (suppose the display problem is solved) and disable the onboard VGA option. Keep your pc running like this (using external VGA adaptor).
Aug 03, 2011 | ASUS P5KPL-AM SE Motherboard
I have HP Pro3000MT, and it has vga and dvi port. I want to use dual monitor for this pc. the monitor are HP LCD and it only has vga input. first i use vga port, secondly i use this dvi cable to connect to...
you need a dvi to vga adapter not a dvi to vga plug and you must also go into your graphics card setup catalyst control center if its ATI Nvidia Display manager for Nvidia if you boot the computer with it pluged in and you can see the boot screen on bolth displays then its an os thing just right click and select the display manager the activate all display's through the managers
Apr 01, 2011 | HP SmartBuy Pro 3000 MT Pent Dual Core...
I can't connect my data projector to Aspire One Pro Netbook. Why doesn't it show my powerpoint presentation?
just connect the vga cable to vga port of laptop and to the projector and in projector choose the source of display vga or pc mode and in laptop press f5 button or right click on desktop and choose the display mode lcd +monitor it will show you the display on projector.
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | Acer Aspire One PC Notebook
My monitor keeps going to sleep & can not get computer on. What's wrong & how do I fix it ?
it could be the monitor VGA cord is not properly connected to the PC and the VGA Port on the PC is faulty. Try use the monitor on another working PC and see if the monitor displays, if it displays then your PC VGA cord is bad or the display resolution in the PC is too hight. Or if the monitor does not gives the same problem, replace the VGA cord.
Jan 30, 2010 | HP w1907 LCD Monitor
What is the exact mane of the DVI to VGA adapter needed for dell optiplex GX 240?
Sorry, but what do you mean with mane (can't find a correct translation to dutch)
Do you mean advantage, or do you mean what you can do with it?
Normally a DVI to VGA adapter can be used to connect a display with a VGA connector to a DVI port. If you have 2 ports VGA and DVI, maybe you can connect 2 displays to your pc. It's great working with multiple displays, making your desktop twice the size. For example: you can open your mail program in one display and your web browser in the other.
Jul 22, 2009 | Dell Computers & Internet
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
