Question about Garden
I need to know the correct fuel mix ratio for homelite hbc-30b strimmer
  • 104 Answers
SOURCE: fuel ratio for homelite ut10829
the ratio should be 25 to 1 so 250 mls of oil for 1 litre of petrol
Posted on May 23, 2009
  • 4088 Answers
SOURCE: mini mac 35. need to know the fuel/oil mix ratio.
Use 40:1 mix. Be sure to use chain saw engine oil designed for this service, not boat motor oil. Premix the fuel/oil, not in the saw fuel tank itself.
Posted on Jan 28, 2010
dontbother10
  • 2220 Answers
SOURCE: oil mix ratio for homelite chainsaw
Current models recommend 50:1
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil. Once adjusted for this mix your saw will start easier, take longer to carbon foul, and is better for your grandchildren, regardless of what your manual says.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 21, 2010
dontbother10
  • 2220 Answers
SOURCE: fuel mix ratio for poulan counter vibe 3400 chain
Oil Mix Ratio: (last 5-10 years)
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If me I would have the Poulan tweaked to run properly on 50:1 and use that in both. It will start easier and take much longer to carbon foul.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Posted on Apr 30, 2010
dontbother10
  • 2220 Answers
SOURCE: fuel mix ratio for poulan counter vibe 3400 chain saw; mix ratio
A different site that lists 40:1. http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/4a98e23d38cbda9b88256bf80015de57?OpenDocument
Oil mix is controversial. Some think more is better, todays saws run much faster and carbon up much quicker. Ask the mechanics at a local saw shop. I will wager they say 50:1 regardless of the age of the saw. Me too! The Echo site now says use 50:1 regardless of what is printed in the OM. It is your saw Mike; run what you want.
Lou
Posted on May 03, 2010
Testimonial: "Thank you so much for the prompt replies. I'm going to try the 50:1 mix and see how it runs. Thanks again. Mike"
What is the gas to oil ratio for a Homelite backpack blower model # UT08111A
50:1
consider using stihl 50:1 oil as it is made to run in any 2 stroke engine at any ratio that way you only need one fuel tank correctly mixed for all 2 stroke operations
Jun 25, 2017 | Homelite Garden
What is the fuel oil ratio per litre for a husqvarna 535rxt strimmer
If it is 2 stroke, take petrol /fuel and mix it with preferably synthetic2 stroke oil.
Ratio is usually 10L petrol mixed with 200 ml or 2 stroke oil, that is the best result, used it on my chainsaw, strimmer, moped, working for years without a glitch.
Jul 20, 2015 | Husqvarna Garden
What is the correct gas mix ratio for a Homelite Pro 20" model #4620C 46cc
50:1 ratio to a gallon of gas. Non ethanol if you can find and a octane rating over 87
Dec 30, 2014 | Homelite Garden
What is gas m ratio fr 25cc weer
Hello there
Download here friend.
http://manuals.homelite.com/system/files/4262/original/UT40502_UT40903_041_eng.pdf?2011
Page 8 of the Homelite user Manual gives you the EXACT ratio.
FUEL MIXTURE
'This product is powered by a 2-cycle engine and requires
pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded
gasoline and 2-cycle engine lubricant in a clean 1 gallon
container approved for gasoline.
Recommended fuel:
This engine is certified to operate on
unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mixlubricant with gasolineaccording to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US)'
Sep 12, 2014 | Homelite Garden
I just purchase a homelite leafblower ut 09510 175mph, do i need to mix oil and gas for fuel?
Yes, you will need to mix up some fuel with two cycle oil. See your owners manual for the proper mix ratio. Keep this fuel in separate container from your lawn mower gas.
Sep 04, 2011 | Homelite Garden
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
I need to know the correct ratio of fuel mix for homelite blower/vac
It is 50:1. That is 2.6 Ounces 2 stroke oil/ US Gallon or 1.3 ounces of oil / 1/2 US Gallon. I recommend synthetic and adding Stabil brand gas stabilizer to the mix. It helps greatly.
Dec 03, 2010 | Homelite Mighty Lite Blowervac
I need to know the proper gas oil mix for the 42cc engine
50:1 is the correct fuel to oil ratio. Be sure to use a modern synthetic oil made for chain saws, and premix the fuel and oil in it's own can-- shake the can thoroughly just before filling the saw each time. With the very lean fuel to oil ratios used today, it is important to keep the oil in suspension to prevent engine damage. Hope this helps!
Aug 05, 2010 | Homelite ZR10926 16" Chain Saw
Need to know petrol - oil ratio for mixing 2-stroke fuel for Electrolux-Partner B300B garden strimmer. The manual gives every kind of technical and other info the user is never likely to need; except this...
Hi There, I'd recomend using Stihl Two Stroke Oil. Mix it at 50:1. Its the best stuff you can get. Never let me down yet, used in all my chainsaws and strimmers.
Rich
Aug 15, 2009 | Garden
I need to know the gas to oil ratio on a Homelite Versatool I inherited.
heres a link for homelite service manual
http://www.odref.com/homelite/string-trimmers/service%20guide.PDF
pg 4 states that fuel/oil mix is 50;1
2.5 oz per gallon
Thanks.
Jun 28, 2009 | Homelite Garden
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
