Question about Refrigerators
How do I defrost the fridge? - Refrigerators
  • 1,284 Answers
Hi, to begin the defrosting process, remove all non-perishable foods from the refrigerator. These items should be moved to a cooler that contains some ice in it to keep the items from getting warm. Next, turn the refrigerator's temperature down to 0 or Off depending on the model. If possible, remove any shelving from the refrigerator, clean it, and set it aside. Note that it is not necessary to unplug the refrigerator. Unplugging the refrigerator will turn-off any lights inside and it is advantageous to have lighting on when performing the defrosting process. Depending on the model that you own, either open one or two refrigerator doors and leave them open. This allows the flow of warm air to enter into the appliance and helps the defrosting process. While the doors are open, take some old cloth or paper towels and set them aside. Now you will need to wait approximately 2-4 hours for the ice to melt inside the refrigerator.
Posted on May 19, 2011
Maytag performa fridge model# ptb1753grw freezer freezing up and the fridge not getting cool. i defrost freezer remove the ice then the bottom fridge gets cold again. but it keeps freezing up again.
You have one or more of your defrost components that are bad. Defrost heater, defrost thermostat, and defrost timer or board depending on model are the 3 components.
Nov 02, 2017 | Maytag Refrigerators
I pushed my intex fridge defrost button yesterday and then plugged off the fridge and then again plugged in the fridge but till now the defrost button did not come back to its original position
Most fridges will stay on defrost for up to 30 minutes. Leave it plugged in and see if the button pops back out after the defrost has finished.
Sep 17, 2017 | Refrigerators
Fridge fine, freezer defrosting
What is the model number? I believe you may have a problem with a defrost heater, defrost thermostat or defrost control. Will need to manually defrost the fridge by placing hot water in the freezer area with the door shut and the power to the fridge disconnected for a few hours. Then we can try to find the cause
APPLIANCE 911
Dec 21, 2015 | Refrigerators
Fridge not getting cold...but freezer is working
the fridge gets its cold air from the freezer fan blowing it through small air passages between the freezer and fridge. when you adjust the temperature in the fridge you are increasing/decreasing the amount of air being let into the fridge. Two common problems that could cause the freezer to freeze but not the fridge getting cool is the freezer coil is frooze like a ice cube blocking the air going to the fridge or freezer fan is not working could be bad or froze up due to too much ice. If fan works after manually defrosting problem could be in the auto defrost mechanism. If fan don't work after manual defrost replace fan. Manual defrost by putting a pot of very hot water in freezer with door closed change water foten until defrosted.
Jan 02, 2012 | Westinghouse Avalon Refrigerators
Proline fridge/freezer the fridge is frosting up at the back but food is not cold enough
Hi.
You have a problem with the defrost system. Try disconnecting power overnight and allowing fridge to defrost. The problem will not occur immediately after defrosting, but will probably restart after few days, when the evaporator coils freeze again. In that case the defrost system must be tested and repaired.
The defrost system comprises defrost thermostat, heater, defrost control and fan. The parts that fail more commonly are thermostat and heater. Both parts are located behind freezer firewall and tested reading impedance with a multimeter.
A test on the defrost system can be done by performing a complete defrost manually (remove food and leave power disconnected overnight). If the fridge restarts working after defrost, then problem was the defrost system. In that case the problem may return after few days or weeks, meaning that one part in the defrost system is faulty.Parts must be tested.
If the defrost makes no change, then there is a different problem. The damper ventilation system , the temperature control or the refrigerant gas pressure may be the problem. When the problem is one of these faults you get the compressor is running regularly, but will stay on most of the time.
If the motor is humming and clicking most of the time, but not properly starting, then the problem is usually the starter relay/capacitor. Relay and capacitors can be replaced to fix the problem.
Here a tip explaining how to deal with a similar problem on a different fridge model: Fridge not cooling. Procedure is similar on your model.
You can find parts and diagrams for most appliances here:
Where do I find parts and diagrams for my appliance?
Regards.
Aug 08, 2011 | Refrigerators
Coil frozen over, freezer not freezing and fridge inefficient. msd2758gew
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. has one version..to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle. .
Nov 01, 2010 | Maytag MSD2758GEB Side by Side...
Where is the defrost switch on a Whirlpool refrigerator freezer side by side
there are acutall 3 defrost components on a fridge, the defrost timer, which automatically puts the fridge into defrost aprox every 8-10 hours for about 30 minutes, and then there are the defrost heaters which come on to assist the defrost process and there is a defrost thermostat which cuts in and then out. what exactly is the problem with the fridge please?
Nov 13, 2009 | Refrigerators
Freezer is frozen fridge is warm
Your model is most likely the Profile Artica style. Most times the defrost heater is burned out behind the rear of the freezer wall. Manually defrost and look at the defrost heater to see if burned out. That model possibly has the glass covered defrost heater and will be easy to spot if burned out because the element is inside a glass tube, If you replace the defrost heater also replace the defrost thermostat, Please send me your model number located near floor of the fresh food compartment door seal and kick plate, Thanks Sea Breeze
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge losing coldness
Defrost problem. Either defrost heater, defrost thermostat, or defrost timer is bad.
Sep 05, 2017 | Frigidaire GLRT184RA Top Freezer...
Defrost side by side fridge
no you can not. there are no separate defrost control for freezer and fridge. the evaporator is located in the freezer section and it is supposed to defrost automatically. what is the problem in the first place?
Feb 08, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
