I am unable to uninstall Scrapbook factory deluxe from one of our users computer, It seems as if the user deleted the installation files
    President:
  • 1,607 Answers
If you still have the installer of Scrapbook Factory then just install it again and then uninstall it.
Hope this helped! =)
Posted on May 19, 2011
ImageBrowserEX won't load past 80%
It is important, that you ALLOW in the InternetOption of IE the ActiveX
- Run ActiveX controls and plugins
Nov 28, 2012 | Canon Powershot Sx240 Hs 12.1 Mp 20x...
I just got my creating keepsake scrapbook designer v.3 i installed it, still have the version 1.5
hi, aejedennis:
You could try uninstalling version 1.5. click start, and click on "control panel" on the start menu. When the control panel window opens, click on "add/remove programs" This will open a window with a list of programs installed on your computer. Find Encore Creating Keepsakes Scrapbook on the list. There may be listings for both versions. Click on the listing for v1.5, and it will expand. The expanded listing should include a button you can click on labeled "remove" or "Uninstal". Click on it and when a window opens to ask if you really want to remove the program, click on yes. It might ask you if you want to keep your saved files, click yes to that if you mind losing stuff you have saved using the program. You might have to install v3 again.
Jan 17, 2011 | Encore Creating Keepsakes Scrapbook...
When i download yahoo messenger 10 it says, "Yahoo messenger is unable to download files needed for installation. please check firewall settings and retry installation."
You need the following OS to support Messenger
Windows 2000 / XP / 2003 / Vista / XP64 / Vista64 / Windows7
If that is not an issue read on.
Make sure your IE is up to date (IE 8) - even if you run another browser as default. IE is coded with Yahoo Messenger
If you do use another browser - check that IE is not set to 'Work Offline' under 'Tools' and has a red X through globe allowing it Internet access
The problem is probably due to a mal-function of the uninstall software.The Yahoo Messenger uninstall software is notorious for leaving files and fragments behind creating conflicts with the incoming software
Close all programs when uninstalling / downloading and uploading.
If you tried to uninstall the old Yahoo Messenger program from the Control Panel and failed to back it up with a visit to the 'C' drive, you may have old software conflicting with the incoming software trying to share the same folder. These conflicts will be enough for the firewall to hoist a red flag
If you have Vista the whole Messenger folder should have been removed during the uninstall.
Check
Start
Sep 22, 2010 | Yahoo Messenger
Hi there this my problem "Yahoo! Messenger is...
Check
Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger. - The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
If you have Vista you may be denied being able to delete folders - in this case you will have to disable the 'User Account Control'
Start > Control Panel (Home) > User Accounts and Family Safety > Add or remove user accounts > Continue > Go to the main User Account Page > Turn User Account Control On or Off > Continue > Uncheck control box > OK
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_ccleaner/
Re-start your computer
Download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
May 20, 2010 | Yahoo Messenger
Unable to run messenger
Its a pity you chose to re-install - a simple toggle of the connections from 'Direct' to 'Proxy' was probably all you needed.
As for your current installation problem:-
You do not need to adjust your firewall for uploading Messenger
Check
May 07, 2010 | Yahoo Messenger
Unable to install software
Are you able to go to my computer, then to c:/ drive, then go to program files. Look for the uninstall file.
You can also go to start menu, search, type in the file name and search it, once found, delete everything listed.
The 3rd way is to go to start menu, go to run, type regedit, then find H_KEY_LOCAL_USER, then scroll down until you find the software tab and then click the + sign to expand the list with all your software. Once you find the program file, right-click on the file and delete it.
Then go back to the main list, go to H_KEY_LOCAL_MACHINE, find the software tab, and find the program and delete it. Then exit the program, reboot your pc, and now the program will be gone.
Mar 13, 2010 | IdeaSoft Greeting Card Factory Silver...
Microsoft office word not installed for current user
dear sir
first uninstall the program & delete the temporary files
ex: START>RUN> type TEMP please delete all the files in that folder
after that restart your system
now install the program after that dont remove the program CD from your computer.
then open ms word. it will take some extra files from CD.
now you can run the program directly
regards
murali
Dec 09, 2008 | Computers & Internet
I have purchased the Scrapbook Factory Delux version 4.0 and when I try to install the CD it only progresses to a point and then displays an error Messaege( ERROR 1335 The cabnit file "Data1.cab" required...
now u have what do ur Scrapbook Factory Deluxe cd i corraped so u have now to do serch in google for the software or torrent download of this softwere with keygen with crack download it
here is one link to download this software
http://www.torrentz.com/78648f6d84165773429b9ed88cae5c961a573db0
just download iso make cd & enjoy
Feb 26, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
