CD drawer will not open. Have tried unplugging but did not work
  • jlucress May 19, 2011
    How do I get it opened without damaging the drawer?
  • 17,129 Answers
Possible failure of the drivve unit or the loading mechanism of the CD unit. It can also be due to failure of the belt in the drive.
Itt is important that the CD unit is opened to check on the mechanism to see if there is a jamming of the drive, a failure of the motor or loading motor drive IC.
Posted on May 19, 2011
    How do I get the drawer opening without damaging it?
How to open cd drawer
Oh my God, the answers I\'ve found on the net on how to get the CD drawer on a Crosley CR247 open are all nuts. Mine wouldn\'t open yesterday and I dismantled the whole damn thing to get the tray open, but that isn\'t necessary.
First of all my unit was making noise when I hit the eject button but the drawer wouldn\'t open. I knew there was no CD in the tray. Powering down and all the other foolish answers I found didn\'t work. There is no small round hole in the front to do a manual eject. Trying to pry the door open won\'t work and you\'ll just damage the unit. Here\'s what you need to do. And do it all GENTLY. There is no need to force anything!
Take a small, pointed steak knife out of your kitchen silverware drawer. This is all you\'ll need to get the drawer open. First let\'s identify where we\'re going to put that knife blade. The CD drawer says "CD RECORDER" and there are 3 lines on each side of that label. Where you\'re going to put that knife is below the 3 lines on the left, to the left area of those lines (see picture). This is the location of the drawer lock.
If you still hear noise when you push the eject simply push in the knife gently as you push the eject button. The drawer will open if you got the right spot.
If you hear no noise, or your unit is dead and you want the CD out, or if you\'re just afraid to stick the knife in the unit, unplug the unit. Gently push in on that spot until the drawer pops out a little bit. Now you can gently open the drawer by hand.
You can see the drive belt and pulleys (see pic). Mine was still intact but needs replaced. Here is also the info I got off of the back of the CD (see pic). Might not be able to find a replacement belt but at least you can get the thing open. Good luck.
jim Maarrttiin@msn.com
Mar 04, 2014 | Crosley CR247 Shelf System
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Feb 18, 2013 | Audio Players & Recorders
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
Cd skips at beginning of cds
the data on compact disks usually starts on the outside of the disks and spirals to the center. My guess is that the laser unit that reads the data is malfunctioning. It moves on a rail from the outside of the disk to the center. About all you can do if try to clean the laser unit or lens assembly. If you can get to the laser lens, blow it off with canned air. If you can not get directly inside, open the CD drawer and shoot the canned air into the machine through the drawer openings. I suggest that you open the CD drawer with the open button then unplug the machine. At that point the drawer should be open and you will have some access to blow off the CD reader.
good luck cleaning the CD reader!
Jan 28, 2010 | Sony CDP-CX300 CD Player
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
CD drawer will not open or close
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
CD drawer won't open
hi, try opening up the cover lid, and manually give a mild push to the tray, must be some small jam, or the eject belt or gear,.let me know
Dec 28, 2007 | Teac GF-300 CD Shelf System
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
Nov 19, 2006 | Teac PD-H300 CD Player
55 people viewed this question
 Grubhead
Grubhead
