Question about Sagem Cell Phones
I have a Sagem CK1 incar handsfree device. It will no longer connect to any bluetooth enabled cell phone.
SOURCE: Bluetooth Connection issues
i have also had this problem, i have found that if i get the person to send me something first, there name will appear on the list of bluetooth list, when trying to send them something all you then have to do is click on there bluetooth name and it tends to connect. hope this helps.
Posted on Jan 08, 2007
SOURCE: bluetooth enabling
Have just had an email from Garmin - they have emailed me a firmware upgrade, and it now works perfectly! Email me on itsthekings@gmail.com if you want it. Cheers.
Posted on Dec 30, 2007
Nitraghav
  • 18 Answers
SOURCE: bluetooth handsfree connectivity
Bluetooth handsfree profiles are needed by N 72 which is missing by default in N 72 you will have to install bluetooth profiles. Please refer to nokia website for details on how to install bluetooth profiles
Posted on Mar 08, 2008
  • 103 Answers
SOURCE: Bluetooth Connection to Mazda Handsfree Is No Longer Handsfree
hi,
bluetooth connect is only going to work for up to 30ft in distance so if you go to far from the car it will disconnect because it lost the bluetooth signal.
please rate me. thank you.
Posted on May 22, 2008
SOURCE: samsung bluetooth device pass key ?
key 0000
Posted on Oct 08, 2008
Connect sony dr-tn200 bluetooth headset to samsung mx-h620 hifi
Bluetooth is a short-range (33 feet/10 meters) wireless technology that allows two Bluetooth-enabled devices to connect wirelessly and communicate between them. If your son's Samsung MX-H620 HIFI is not Bluetooth-enabled, the two devices will not be able to connect in any way. If the headset were corded (it is not because it is Bluetooth) you could plug its cord into the headphone (LINE/AUX IN) jack on the Samsung. if the Samsung system is not Bluetooth, the only option is to find a suitable Bluetooth adapter to make it Bluetooth-enabled. However, you can use the Sony headset to listen to music or make phone calls from Bluetooth-enabled devices that you own such as phone, tablet, iPod, iPad.
Dec 29, 2014 | Samsung Radio Communications
Samsung c3050 mobile not connecting to bluetooth handsfree device
There probably is a special procedure for connecting the second device. Consult your user manual for the headset and be sure to follow the steps precisely.
Dec 17, 2011 | Samsung C3050 Cell Phone
How do I connect my blackberry cel phone to my bluetooth ce0678
Hi, you can use this instruction to pair your blue tooth with your cell phone:
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Good luck to you..
Feb 01, 2011 | Cell Phones
Will not connect to my sonyericsson w995
i checked that your phone is compatible wd the parrot handsfree bluetooth.
turn-on your bluetooth of your phone
turn on bluetooth of your parrot handsfree see manual where the buton is located
From the phone:
* Go to MENU / SETTINGS / CONNECTIVITY / BLUETOOTH / MY DEVICES / NEW DEVICE
* Phone will search for available bluetooth devices
* Select Parrot Product from the list
* Enter Passcode "1234" and go to OK
* Accept the pop-up
* Devices are now paired and connected
fleche.gifSending contacts via Bluetooth
Jan 29, 2011 | Parrot Hands-Free Car Kit with LCD Display...
I purchased a Jabra bluetooth that fits on the sun visor how do I connect with my black berry
Go to options menu on BB bb_icon.gif and locate Bluetooth.
- Enable Bluetooth.
- Then turn on Jabra 250 and Hold down the Multi-Function Button until you have a SOLID BLUE LIGHT on the LED on the headset. This could take up to 10 seconds and will take place after the LED has ceased to flash.
- Click add device on your BB.
- BB will search for your earpiece. 0000 is your passkey to add device
Jan 15, 2011 | Jabra Cruiser InCar Speakerphone Black
How to activate k750i bluetooth hand free
Activate blutooth from the main meny/setup (tool symbol), then navigate to the far left meny tab (communication) and turn ON your bluetooth radio, and enable the "visible" status for your phone. Then turn on your handsfree device, and the phone should either find your hands free or vice versa. Many handsfree devices will ask you to enter a pin code once it has connected to the phone to allow connection, so be sure to have the code ready.
Oct 20, 2010 | Sony Ericsson K750i Cellular Phone
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
How do I connect my motorola bluetooh headset S9 to my LG Vu920?
When using your S9 for the first time, follow these
steps to pair (connect) to your Phone:
Important: If you are pairing separate Bluetooth
devices for handsfree calls and streaming music, it is
recommended that you pair your S9 with your
handsfree device (phone) first.
1 Ensure the Bluetooth feature is enabled (turned
on) in your phone.
2 Turn on your S9 by pressing and holding (|) button
until the indicator light flashes three times in
blue.
After a few moments, the indicator light will be
steadily lit in blue to indicate your S9 is in pairing
mode.
3 From your device, perform a Bluetooth device
discovery/search. .
When pairing your S9, use
the following steps to perform a device discovery
from your phone:
After accessing the Settings Menu, go to bluetooth.
to add a new device, tap [New].
1. Tap [New] key to search the device that can be connected and which is
within range.
The phone lists Bluetooth devices it
finds.
b Select Motorola S9.
c Select OK or Yes to pair your S9 with
your phone.
d Enter the passkey: 0000
e Select OK.
When your S9 successfully pairs and connects to
your device, the indicator light displays blue with
10 quick purple flashes. If wearing your S9, you
will also hear an audio tone indicating successful
pairing and connection to your device.
4 To verify your S9 has successfully established a
handsfree calling connection with your phone,
dial a phone number you want to call and press
the Send key on your phone.
When successfully connected, you hear ringing
on your S9. A Bluetooth Handsfree Phone (HFP)
connection is now established with your phone
Jul 13, 2009 | LG Vu CU920 Cellular Phone
How to connect a sonyerricson bluetooth device with my k800i
From the Menu screen, select Settings. Scroll across to the Connectivity tab and select Bluetooth. Select Turn On. To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree. Your phone will then look for a handsfree device to connect to. Press and hold the 'call' (big) button on your bluetooth device. First it will blinks once, keep holding, then it will turn to steady blue. This is the 'pairing' status. When the phone found your device, select the device and enter the passcode (usualy 0000 (4 times zero))if required. The steady blue light on the device should go off and blinks every couple of seconds. Next time you switch on the bluetooth device it will be automaticaly recognized by the phone.
Jun 14, 2009 | Sony Ericsson Bluetooth handset pink...
hi,
May 20, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
49 people viewed this question
Top Sagem Cell Phones Experts
Computer Repairing
Computer Repairing
Kazim ERGUNEY
Kazim ERGUNEY
Pavel Pranovich
Pavel Pranovich
Are you a Sagem Cell Phone Expert? Answer questions, earn points and help others
