Question about Toshiba Office Equipment & Supplies
I have a Toshiba e-Studio 283, and when I turn it on it comes to ready state but it wont work. If I press the "Interrupt" button it starts working normally. I have done the NV Ram Reset but the problem still remains. Anybody can help ???
  • 653 Answers
SOURCE: toshiba 160 error code
For error code C44, it indicates Heater abnormality.
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
If happen again, then u need to check the thermistor. Replace it if necessary. If themistor replaced but still happen again, then u need to proceed to check themostat--> heater-->Mainboard-->Switching regulator.
Posted on Mar 09, 2009
  • 653 Answers
SOURCE: C44 problem Toshiba eStudio 166
If u cleared the status, and it happen again, then u need to check following:
1. thermostat
2. thermistor
Posted on Aug 24, 2009
  • 4 Answers
SOURCE: toshiba e-studio161 - windows7 64 bit
For Vista there is only a 32-bit driver. I've already tested, it doesn't work
Posted on Dec 09, 2009
SOURCE: 'm searching for a driver works with toshiba
how we can connect to labtop pc
Posted on Jan 16, 2010
canontech
  • 1219 Answers
SOURCE: please sir you said that to reset the copier
Its a copy key
Posted on Jul 07, 2010
My Toshiba e-Studio 2506 shows the error "Call for Service C413", what can I do to solve this problem? Help me please!
perform the following:
1. Turn ON the power while [0] and [8] are pressed
simultaneously.
2. Key in "2002", then press [START].
3. Change the current status counter value "3" or "4" to "0",
then press [OK] (to cancel [C413 / C414]).
4. Turn the power OFF and then back ON. Make sure that the
equipment enters the normal ready state.
Sep 27, 2016 | Toshiba Office Equipment & Supplies
Toshiba e 233 is error code C410 how to clear
Thermistor or heater abnormality at power-ON
(1) Turn ON the power while [0] and [8] are pressed simultaneously.
(2) Key in "400", then press [START].
(3) Change the current status counter value "1" or "2" to "0", then press [ENTER] or [INTERRUPT]
(to cancel [C410]).
(4) Turn the power OFF and then back ON. Make sure that the equipment enters the normal ready
state.
Jun 25, 2016 | Toshiba Office Equipment & Supplies
How to reset Toshiba studio 2505 error c4b0
simultaneously.
3. Rewrite the displayed counter with "0" and then press the
[OK] button ([C4B0] clear).
May 15, 2016 | Toshiba Office Equipment & Supplies
Toshiba studio 2007 error coad c413 how to reset coad
Thermistor abnormality during warming up or in ready status.
simultaneously.
Mar 04, 2016 | Toshiba Office Equipment & Supplies
How to reset error code C452 in the Toshiba e studio 2006
simultaneously.
3. Change the current status counter value "62" to "0", then
press [OK] (to cancel [C452]).
Jun 13, 2015 | Toshiba Office Equipment & Supplies
Call service 1300887600 code C44O
Check and clean the thermistor. Replace if required. C440 occurs due over heat.
Change the current status counter value (08-400) "5", "7" or "9" to "0"
- The error occurred during warming-up: "5"
- The error occurred after the equipment has become ready: "7"
- The temperature detected by the main thermistor is 230 C or higher: "9"
- The temperature detected by the edge thermistor is 280 C or higher: "9"
Reset Procedure of C 440 is.....
(1) Turn ON the power while 0 and 8 are pressed simultaneously.
(2) Key in "400", then press START.
(3) Change the current status value to "0", then press ENTER or INTERRUPT (to cancel C 440).
(4) Turn the power OFF and then ON. Make sure that the equipment enters the normal ready state.
Oct 13, 2012 | Toshiba e-Studio 350 Copier
There is a display message that comes up when you press the job status button that is flashing "Check the direction or the size of the paper on the bypass tray and press start", we are not trying...
try to format its HDD :
turn it off..
hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again or enter . Wait for it to say "please reboot the machine", turn it off and back on. Hopefully this will work..
Jul 05, 2011 | Toshiba e-studio 455 Copier
I wont to put a password in toshiba studio 166 copier
press [1] and [*] together and then turn on the copier after the beep enter 100 then [start] type 18 then [start] press [200%] twice then type 100 and then [interrupt] and then turn off copier ,whit this code department control function will be turn on.
now press [8] and [start] together and turn on copier enter your code and then press [interrupt] and turn off your copier.
May 11, 2011 | Computers & Internet
How do I fix fault code C448 on the Toshiba E Studio 3500C?
C448 means you have a fusing unit malfunction. The fusing unit is the part that gets hot just before the paper comes out of the machine. You can try clearing the code using this reset procedure:
(1) Turn the power ON while [0] and [8] are pressed simultaneously.
(2) Key in "400", then press the [START] button.
(3) Change the displayed current status counter value "32" to "0", then press [ENTER] or [INTERRUPT] (to cancel C448).
If the code comes back you are going to need a fusing unit.
Oct 22, 2009 | Toshiba Office Equipment & Supplies
Counter reset
I found it.
To get into service mode press the clear key. Press interrupt.  Press 0.  Press interrupt.
All counter reset codes start with the number 24.  So put that in first and press the start button.
Then type in a 1 press start.
Then type in a 2 press start.
Do this for numbers 3-11 and 13.
That will reset all of the counters on the copier.
Turn off the power once you're done.
Sep 13, 2008 | Office Equipment & Supplies
80 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
