Question about Sony Playstation 3 (PS3) Console
Blue tooth headset
Hi, when I connect a blue tooth headset it makes a horrible high pitched scream, other players online can hear this. how can I get rid of this noise. the headset is PS3 compatible. cheers
    Sergeant:
  • 359 Answers
You have a faulty bluetooth headset. Replace with another headset.
I have 3 of them that I rotate around and they work great!
Posted on Aug 14, 2008
SOURCE:
After i paired a bluetooth headset with my Nokia E5, it disconnects / connects every 30 - 45 secs. When I make a call or listen to music when bluetooth is connected the line crackles so much that you...
some units cannot handle blue tooth. Check to make sure yours is blue tooth capable. If it is, check your settings both security and blue tooth to ensure there is no conflict. Also check the headset for compatability ratings. Sometimes that is why there is interference.
Jul 04, 2011 | Nokia E5 Cell Phone
I have connected the headset Blue-tooth with my laptop there is a blue tooth connection but no sound (music).from my media player (windows) I can change the numbers but there is no music. Hetset DR-BT21G...
It seems your laptop Bluetooth could be 1.1 version and headphones are 2.1 it won't work. I would suggest wired headset or get a 2.1 the difference is 1.1 doesn't not allow high quality sound 2.1 does allow stereo sound. here is a sample IOGear USB 2.1 Bluetooth Micro Adapter GBU421
Mar 02, 2011 | Sony DR-BT21G Wireless Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Unable to use new h500 headset
The H500 is a monaural headset, thus good for phone calls only, not for listening to stereo music. You haven't specified which Motorola phone you own. Check in its user guide if it is able to handle stereo bluetooth headsets (i.e. if it bears the A2DP and AVRCP bluetooth profiles), which are suitable for music streams. If your phone is able to handle them, go to the mall (or store, or even online), buy one set which suits you better, pair them with your phone and enjoy!
Just my 2 cents... Carlos
May 23, 2010 | Motorola Mobility H500 Wireless Headset
Hi i have hust turned my laptop on and it is making a biig noise and it is not stopping it comes on when u turn it on what should i do
Are you getting a high pitch screaming or a grinding noise? The Fan on the heatsink sometimes getting clogged with dust and over time this can cause the computer to turn itself off. Dependant on a high pitch scream this could be a number of problems, memory modules loose or faulty?? Would need more info about the type of sound..
Nov 07, 2009 | Medion md40298 Notebook
Loud Noise
IT will give the noise because of the following reasons
  • Due to signal distortion and also that you mieght be useing faulty bluethooth head set .
  • It also occur due to low bettry chargeing
Things to do !
  1. check your blue tooth head set with other Motorola cells
  2. replace your blue tooth head set
  3. clean the connector of the blue tooth cable
Please Rate !
Sep 05, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Steam Button
Your iron pump is faulty the high pitched sound is normal.
Rdgs
Alan
Nov 27, 2007 | Rowenta Perfect Iron
Blue tooth adapter and hs850 headset on my computer
Yes, you need the blue tooth driver. The one that comes with your blue tooth "toggle". Although my laptop said "blue tooth compatible" I still needed a toggle. They are fairly cheap to buy and go into a USB port.
Sep 17, 2007 | Motorola Mobility HS850 Consumer Headset
Sony Playstation 3 (PS3) Console Logo
67 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
