Question about Dell Dimension 4700 PC Desktop
I just purchased a Rosewill armor case to put my demension 4700 into. I need the pin configuration for the front panel plug since the one from the case is broken down into some individual plugs
5 Suggested Answers
SOURCE: connecting front panel leads of generic case to 4600 motherboard
-MrSlickShoes
Posted on Mar 20, 2009
ajx13
  • 110 Answers
SOURCE: Dell's Secret to a j9c2 Connector
b578360.jpg This are the details you need. Please rate if useful.
Posted on Jul 28, 2009
BLAZZ81
  • 281 Answers
SOURCE: My 5150 would not start after the USB cable
the front panel's usb ports may have broke, Unplug them to test..
Open pc and look for the wires coming from the front panel,
follow the wires and look for the one that plugs into the front usb port, and unplug it from the mother board not the front panel,
If the pc starts then!! yes a new front panel will work 100% or just keep front usb's unpluged... if not it could be the mother board,
Posted on Mar 29, 2010
micromatikal
  • 2777 Answers
SOURCE: I have a Dell Dimension 4700 with M3918
That Xonar is an amazing card, as an aside are you able to do bitstream successfully to your receiver? Dolby HD and DTS HD successfully? If so I may just end up getting one of these cards :).
You should be able to do what you are looking for by just almost "breaking" that 10 pin straight line connector in half. I believe half of it is the AC97 and the other half is the HD connection, you can't really hurt anything by trying it one way or the other. Just try hooking 5 out of the 10 pins onto each row of jacks and test. You should also need to enable the FP headphone support in the Xonar software, it will look something like this screenshot here... as long as it is detecting the front panel jack correctly:
I hope that picture shows up large enough....
Posted on Sep 19, 2010
Motherboard pin outs
loco is you building your own computer ? .first one ? read documentation as come with motherboard.
Apr 08, 2013 | Computers & Internet
How do I remove the front cover of the Rosewill Challenger? The instruction manual isn't very helpful on this and I can't get it off.
take the side panels off both sides. there are clips where it holds the front panel. push those in to loosen and the front panel should come off.
Mar 09, 2011 | Rosewill CHALLENGER ;Black Gaming ATX Mid...
Mobo on my rosewill armor mid tower wont function. have repalced mother noard an gpu I do not know what to do it turns on fans spin but no mobo activity
Make sure that your power connectors into the motherboard are all firmly connected. I had the same problem, the solution was that the CPU , 4pin molex connector was disconnected.This connector may initially be 6 or 8 pins but the 4 can be separated from the others. This should solve your issues.
Feb 18, 2011 | Rosewill ARMOR Gaming ATX Mid Tower...
Power botton will not turn pc on.
I suppose your power switch has broken or the wires inside has gotten of position such that power cannot reach.
Feb 10, 2011 | Rosewill ARMOR Gaming ATX Mid Tower...
I have purchased a Thermaltake V3 black case and am trying to install my M2N68-LA motherboard. The motherboard has a combined 9 pin header for power switch, power l.e.d. and hdd l.e.d. which was one plug...
1) The 9-pin header you are referring to, is the Front Panel header.
(Processor to the top, Ram Memory slots to the right, the Front Panel header is at the bottom right corner on the motherboard)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00906129&lc=en&cc=de&dlc=&product=3397528
The plastic piece on the front of your computer is the Front Panel.
(Sometimes referred to as a Bezel)
Make a drawing, and notes as to where the individual wires go from that Front Panel header plug, (One-piece plug), to the Front Panel.
Follow the wires from the plug to the Front Panel.
Mark down where Each wire goes.
You may have to take components off of the Front Panel, in order to see exactly where Each wire goes.
For example:
You may have to remove the Power On button/switch assembly from the Front Panel.
It may have the Power On LED light, Power On button, (Switch), and perhaps the HarDDrive LED activity light, in this assembly.
The wires are color coded.
Generally, but not always, when two wires are used in conjunction with each other, (Example, Power On switch, or Power On LED light), the wires will be twisted together.
One wires insulation may be of a solid color, and the other wire may be white, with a stripe in the color of the solid wire.
Example: Wire with Red color, and wire twisted with it may be White, with a Red stripe.
See if these two wires go to the Power On switch.
End of example.
Follow each twisted pair of wires back down to the Front Panel header plug.
(One-piece plug)
See which socket holes the individual wires go to.
Mark it down in your drawing, and notes.
Mark where the individual socket holes plug onto each pin, in that Front Panel header. (9-pin header)
When you are finished, you will have a pinout for the Front Panel header on the Asus M2N68-LA motherboard, and will know where the individual wires go from your ThermalTake V3 computer case.
For the LED lights there is a Positive pin, ( + ), and a Ground pin. (Power On LED, and Harddrive activity LED, for example)
(Ground. Also referred to as the Negative pin. ( - )
This is DC Voltage)
If you have the polarity backwards, (Positive wire of the LED light is going to the Ground pin, Ground wire of the LED light is going to the Positive pin), the LED light will be dim.
(When operating)
Switch the wires around.
If you have questions, or need clarification of what I have stated above, simply state in a Comment.
(Believe upper right of your page)
Jul 01, 2010 | ASUS Computers & Internet
Get no power with intel d875pbz in rosewill tu155 case
You don't have the power switch connected where it belongs. There's one set of pins where all the front panel connections go. This information is from the manual for this board, available from Intel here.
Hope it helps. Thanks for using Fixya!
Feb 12, 2010 | Intel D875PBZ Motherboard
Power Up ATX Mid-Tower case TC3j-4032 P Wiring
The front audio in this case does not support HD sound. To get it to work you must instal the "HD Sound Application" that came with your hardware and disable the "Detect Front Panel Jack Detection" option. You'll have to manually switch between the two inputs.
Mar 09, 2009 | Computers & Internet
Which way should I plug in the cord for the front panel buttons?
the manual is available from this link.
it will contain diagrams of where to put the cables.
http://www.asrock.com/mb/manual.asp?Model=A780GXE/128M&s=AM2%2b
Feb 26, 2009 | Rosewill R103A ATX Mid-Tower Case
Motherboard pin config
All motherboards have a print beside the pins, Speaker= "speak", "pwr s" =powerswitch, "HDDled" red light on front, rst = reset switch [not allways used] "pwr led" Green led, the case wires are usualy marked on the plug ends with the same , "hdd" "reset" and so on. The power switch will work both way's around however the led lights wont. You will not hurt anything if they are the wrong way around, they just wont work so if you dont get lights just reverse the polarity. If by chance the case wires do not have labels the just trace them to the case front panel and plug them into the corresponding board pins. Regards mistyman
Aug 28, 2007 | Systemax Ascent PC Desktop
Dell Dimension 4700 PC Desktop Logo
93 people viewed this question
Alun Cox
