Acoustic solutions lcd26nk750hd. after about 5-10 mins of tv being on picture flikers off and left with sound,have tried loads of scart cables
WebTeligent
  • 42 Answers
SOURCE: Acoustic Solutions TV
Try: http://www.viewpia.nl/html/downloads/viewpia_multilanguage_LCDmanual.pdf
Posted on Nov 09, 2007
SOURCE: Samsung ws28v53n
Just found out from Samsung UK that my boards have blown and will be expensive to replace. He also made me aware that the new LCD TV's have a life span of 3700 viewing hours which is only 4 half years, not made to last like the old tv's.
Posted on Feb 29, 2008
SOURCE: i have got wharfedale lcd
Sounds like you either have a bad card or a bad HDMI cable. Scarts are not the most dependable when it come to HD imaging there is alot of converting going on espically if the TV isnt NTSC standard to begin.
Posted on Mar 08, 2008
SOURCE: ps3 sound setting for Acoustic Solutions tv
go to PS3's audio settings, click HDMI, then manual now untick all settings e.g pcm 41khz etc. and only allow dts and dolby, this fixed it for me :)
Posted on Apr 27, 2008
SOURCE: Acoustic Solutions TFT LCD TV - Red Lines
Get it repair
Posted on Apr 02, 2009
Polaroid led tv ssdv311-11 sound but no picture, connected thru cable box
The TV electronics for the picture may have failed. Do you get any picture ever, like when you turn it on, or when you connect a DVD to it?
If you do then replace the scart cable with a good known brand. Cheap scart cables often do not have all the pins connected up.
Dec 21, 2013 | Polaroid 1521-TLUB LCD TV
Sound but no picture
ok make sure all the cables are plugged in properly and into the correct slot, Check all the channels and make sure that it is not on AV If this doesn't work try new cables or scart leads, if you use a scart lead plug it into a differnt location E.G Some T.V's Have more than one scart lead socket
Feb 06, 2010 | Televison & Video
Acoustic solutions LCD37NK750HDF TV sound ok but no picture.
If there is no picture, just black screen.. then the cold cathode (backlight) on your monitor is busted. Or its ballast transformer is burnt out. Replace it to work again.
Nov 26, 2009 | iLO LCT32HA36 Television
Sound only ,no picture when vcr connected,checked connections,codes ,input etc no luck
How have you connected the VCR..vis Scart or UHF cable?
Has your tv got more than 1 scart socket if connected this way.If so, have you tried using a different scart inputon the tv?
Has the tv got picture and sound when vcr is not connected?
All these answers help with the diagnosis :)
Oct 17, 2009 | Sanyo DS31520 31" TV
Acoustic solutions lcd 22''tv turn it on then it turns it self of
Acoustic Solutions 32 lcd hd Tv screen has green/blue contrast shadows all over the light images on the screen. I have tried changing all the picture setting to no avail.
Aug 22, 2009 | Televison & Video
How to wire acoustic solutions AS134
how many cables shud link up to the tv with the acoustic solution model AS134?i have the colour coded pins plugged in to the speakers left,right,back left,back right and center which plug in to the subwoofer box.how ever i then only have 1 cable left which has a red pin and a white pin that i assume go into the AUX left and right pin ports?the cable then splits into another 2 red and white pins.do these pins plug into the left and right output on the tv?am i missing any cables?help would be appreciated.
Jul 19, 2009 | Acoustic Solutions Audio Players &...
Acoustic Solutions 26'' HD TV cannot play PS3 blue ray films
I have recently brought the same TV and had the same problem but I've mangaed to find a soultion.
The automatic setting for Blu Ray on PS3 is Full HD (1080p) but the Acoustic Solutions TV is HD ready (720p). For PS3 games it will automattically change settings for you to 720p. This is why this works straight away but Blu Ray doesn't.
Solution
You need to plug in your PS3 using the scart contection, then on the ps3 menu go to settings > display settings > HDMI. You will then need to attach the HDMI cable and manually set up
HDMI by checking the 720p option and deselect 1080p.
That should then play Blu Rays too. You don't lose too much quality as 720p works nearly as well as 1080p on smaller TVs.
Rich
Feb 18, 2009 | Televison & Video
I have got wharfedale lcd 42in and a wharfdale dvdr24hd how do you set up the hdmi cable to get clear picture i have tryed taking out the scart lead out and left the hdmi cable in but i only get a picture ...
Mar 06, 2008 | Televison & Video
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
