Question about Garden
Can you advise me on setting the fuel/air aduster on my Stihl Ms180
  • 675 Answers
As a general rule...there are 2 setting screws...one labeled "L" and one labeled "H"...first off, you want to turn the "L" screw clockwise in all the way just until it stops(be gentle, as this is a needle valve and you can damage the needle if you use too much force). Next, you turn the screw counterclockwise out 1 1/2 turns as a starting point....start the engine and adjust the "L" screw just until it starts to sputter and then back off the screw until you get a smooth idle...next, you want to give the saw full throttle...you should have a smooth transition to high speed...if not then you will need to adjust the "H" screw in and out until you obtain a good slow to fast response...you may have to do this several times in order to obtain the best results
Posted on May 19, 2011
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Stihl MS180 chain saw wont start
How long since it was last used? Could be stale fuel. Flush tank, fill with fresh fuel and try again. May take a good dozen pulls to clear the fuel line. If not that then check spark by removing plug, connect to lead and hold electrode end to cycl head while pulling it over(might need a second pair of hands, don't do it if theirs fuel every where!) either that or it's flooded. Turn choke off, hold throttle wide open and pull it until it starts.
Sep 06, 2015 | Stihl Garden
Stihl FS 55R Service manual?
google stihl FS 55R & download a workshop manual that will show u everything u need to know
May 12, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Model number stihl rollomatic mini user manual
855-456-4299 try this#
http://www.hlsproparts.com/stihl-replacement-parts-s/79.htm?Click=28651&gclid=CNXP0_WbmcQCFQsxaQod1XgAug
Mar 28, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Will a complete engine from a stihl 017 fit into a stihl ms180 chainsaw.
you should be able to get the engine to fit. The 017, ms170 and ms180 are all part of the same family.
Jan 15, 2013 | Stihl Garden
Will a stihl chainsaw engine assembly from 017 fit in a ms180
those saws are part of the same family so there should be no problem putting the two together
Jan 10, 2013 | Stihl 017 Crankshaft Assembly W/ Piston...
Stihl ms180 repair manual
Hi, I found your manual on amazon, take a look: Amazon com Stihl ms180 manual. I hope I helped. regards
Jimmy
May 31, 2012 | John Deere Garden
Stihl ms310 chainsaw will only run on choke
You actually need the adjustment tool,looks lie a small screwdriver with a smal socket at the end of it.
Jun 02, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
