Question about Canon PIXMA iP4600 Color InkJet Photo Printer
I have replaced all the cartridges, done cleaning and deep cleaning countless times and nozzle checks but still it does not print properly and the print check pattern does not print properly either. I use compatible cartridges and always have done and have only had this problem recently. I have purchased my cartridges from a different supplier this time but still the problem persists.
SOURCE: 3e Black cartridge won't print
Sounds like it is a recall time I am having the same problem
Posted on Apr 20, 2008
My cyan cartridge wasn't printing and nothing worked - until I tried Deep Cleaning 7 times in a row as suggested by HMlBarryLSal - it worked a treat, many thanks HMlBarryLSal
Posted on Apr 24, 2008
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
  • 12 Answers
SOURCE: iP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Posted on Jan 21, 2009
  • 85 Answers
SOURCE: Canon Pixma IP3500 prints B&W with white streaks
as i can suggest you that it can be the problem of head clogged internally where you insert your black cartridge .and the other main cause is while you give a head cleaning command to get the cartridge cleaned it sucks or pulls  the ink from the cartridge in such a huge quantity that 3-4 cleanings make the cartridge totally empty .due to this the ink gets very low and the printouts come with streaks.many a times setting the print mode in best makes the copy perfect.but the printing gets too slow in that best mode.
Posted on Feb 26, 2009
MY printer prints blank pages
probably an ink cartridge problem..Try executing nozzle check on the maintenance tab on printer and faxes then check the results if it prints properly. if there is still a problem deep cleaning is recommended and if it doesn't work then its the time to replace both black and color ink cartridges.
Oct 02, 2014 | Canon Pixma MP500 All-In-One InkJet...
Printer printing but nothing appears on page?
Hi, Make sure that the cartridges are not blank. Clean the print head properly and check the nozzles. You may have to replace the cartridges.
Oct 17, 2011 | Canon PIXMA MX310 All-In-One Printer
I have a canon multifunction MX700. Suddenly, my black ink stopped printing. Printer prints in other colors. I have turned the power to both printer and computer on and off, have checked the USB cable,...
Dear Adrienne,First make sure that the black ink is not empty. If you are sure the black ink is full enough you need to check the print head condition. The print head may be clogged or faulty.
To fix the clogged print head,please perform the following step:
  • Print the nozzle check pattern, access the following menu on LCD: Menu>Maintenance>Nozzle Check. The good nozzle pattern should like below sample image.
  • If the print head nozzle missing some color (i.e Black) the perform print head cleaning: Menu>Maintenance>Cleaning. Then print the nozzle check pattern again. Note: you may repeat this step up to 3 times.
  • If the problem still remain,then you should perform Deep Cleaning: Menu>Maintenance>Deep Cleaning.
If you have perform the above steps but the problem still the same,please check whether the black nozzle missing partially or totally. The faulty Purge Unit (ink pump) may cause the same problem. I mean the purge unit does not work properly so the ink cannot flow. Good luck :)
Regards,Xanda
Oct 05, 2011 | Office Equipment & Supplies
My hp dj9000s printer is switched off since 6 month, now I switch on it shown error message for Lc, Lm ink cartridge. (cartridge is ok I replace with new one but error is same)
If an inkjet printer has not been used for some time and several print head deep cleaning has been done and it still does not print properly then the nozzles in the print head are blocked.
Inkjet printers need to be used frequently to prevent nozzles blocking with dried ink.
You need to replace the print head to get the printer functioning again.
But these print heads are expensive to replace, it may be better to buy a better and a later model printer for not much more costs.
Feb 25, 2011 | HP DesignJet 9000 InkJet Printer
My canon iP3500: Black print comes out patchily, despite many attempts at deep cleaning, Each time I deep clean, a couple of pages come out with the black print OK, then it goes patchy again.
It sounds to me like your cartridge nozzles are clogged. That's more common with recycled or refilled cartridges, but it can also happen with new cartridges if they are older. If you just purchased the cartridge you could try to return it. Otherwise, I would try to continue deep cleaning and nozzle checks until it starts to print. It takes a lot of ink, but sometimes that's the only way to get it to print. Usually it will work eventually. Do a nozzle check in between each cleaning and deep cleaning.
Feb 06, 2011 | Canon PIXMA iP3500 Printer
I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
1. Make sure that the power is turned on.
2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
(2) Press the Black or Color button.
The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
3. Check the print head condition.
When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
See " Printing the Nozzle Check Pattern".
If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
If the problem is still not resolved, replace the FINE Cartridge with a new one.
See " Replacing FINE Cartridges".
If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
You need to prepare: a sheet of A4 or Letter-sized plain paper
2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
3. Open the Paper Output Tray gently, and open the Output Tray Extension.
4. Print the nozzle check pattern.
(1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
The nozzle check pattern will be printed.
5. Examine the nozzle check pattern.
See Examining the Nozzle Check Pattern.
Examine the nozzle check pattern, and clean the Print Head if necessary.
1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
See " Cleaning the Print Head".
(A) Good
(B) Bad (lines are missing)
(2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
(A) Good
(B) Bad (horizontal white streaks are present)
Post back!
Oct 26, 2010 | Canon Office Equipment & Supplies
Have Pixma MP760. Problem with magenta print nozzle, which is not functioning properly. All others functioning fine. Repeated cleaning has improved the print colour but still patchy on the nozzle check...
Are you using aftermarket/refilled cartridges? To do a complete cleaning of the nozzle, you need to use a new OEM ink cartridge. Run the deep cleaning at least 3 times. This will clear the nozzle. You will eventually have the same problem with the other nozzles as long as you continue to use aftermarket/refilled cartridges. The inks used in them are not as highly quality controlled as the OEM inks so you will end up with clogged or partially clogged nozzles. The new OEM cartridges method usually clears the problem.
Let me know if this clears the problem. Thanks.
Mar 19, 2010 | Canon Office Equipment & Supplies
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
Canon pixma ip4200 colours are yellowy orange on teh photos - dont match on screen colour nozzle check shows the second of the cyan lines as very faint
(Had already done two deep cleans)
1. removed all print cartridges keeping them together and upright
2. qtip (cotton ball on a small plastic stick) soaked in generic nail varnish remover {alcohol based)
3 cleaned print head where cartridge sits repeatedly until no more ink came off on the cotton wool
4. did a deep clean twice
printer then functioned properly
Dec 04, 2008 | Canon Office Equipment & Supplies
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
117 people viewed this question
old marine
old marine
