Question about GE JVM1850 1000 Watts Microwave Oven
No lit LED, No panel control. Vent fan, running
Unit was damaged due lighting strike. Nothing was running. Fuses
OK, AC at LVT . 27v at LED, Cavity & MGT TCO OK, Hood TCO
bad, replaced. Fan came on at plug in. Cannot shut of from panel.
Interlocks test OK.
  • GE Master
  • 9,098 Answers
We regularly repair these control panels for customers nationwide with our guaranteed $39.95 service.
Full details of our service are at http://www.microwavedisplay.com.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Posted on Sep 06, 2008
GE Spacemaker XL1800 JVM1850CH01 vent fan won't turn on
Unplug for about 5 minutes and allow to reset. If the problem persist, you might want to try replacing the control panel (the one that have all the numbers and timers). Good Luck!
Jan 13, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Hi. my micromark MM60106 oven seems to be dead ,no red light, no heat ,no fan. power is getting to the switch but nothing works, do I need a new selector switch
Try using the VOM
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Apr 02, 2013 | Microwave Ovens
Kenmore microwave 911 41479791 no power?
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Sep 24, 2012 | Microwave Ovens
My GE JVM1750DM blew an internal breaker or fuse when I attempted to remount a lamp lighting the stove top; it had fallen out of its mount. Where is the internal reset or breaker located, and how do
There are fuses inside the unit. No internal breaker. A lot of the time that damages the main circuit board too. Blowing the trace that supplies the power to the bulb off of the board. will probably need a new baord, or someone to repair that one.
Sep 24, 2017 | GE JVM1750DM Microwave Oven
GE Advantium 120 oven: Was boiling water and oven completely powered off. House circuit breaker is OK and not tripped. Plugged into another working outlet with extension cord to see if display came on. It...
You will need to remove the top grill vent first, then you can remove the screws coming in from the top of the grille vent then that will expose a screw holding down the control panel at the top. Remove the screw and remove the control panel. The fuse is located in a little 1" fuse holder just behind the front panel near the top.
Feb 05, 2010 | GE Advantium 120 Convection/Microwave Oven
I have a GE Microwave Model JVM1540LM2CS. It started making funny noises like a fan or gear grinding and then it quit working altogether. I have checked the circuit breakers in the house and have...
sounds like the mag fan went out and blew the internal fuse they are ceramic fuses 15 or 20 amp available at hardware stores ,if this blows again it could be the mag overheated,but the thermal breaker should have shut it off before this,thenit can also be your h.v. diode or capacitor shorted
Oct 10, 2009 | Microwave Ovens
We had a lightning strike near our home and our Ewave OTR microwave quit, nothing works but the light inside and the vent fan comes on automatically. We've been told that there is a fuse that can be...
If the light and fan work then it cannot be the fuse. When the fuse "blows", it stops the electricity totally from flowing into the microwave and nothing will work or respond. The fuse is behind the control panel and this requires several hidden screws to be removed. Also, you must be very careful of the 2000 volt charge that is stored in the wiring further into the compartment behind the control panel. Therefore, do not attempt to open the micro control panel without proper service knowledge.
Because you say the light and fan operate, the fuse (as I stated ) is not your answer; most likely the problem is in the control panel circuit board. The circuit board is like any sensitive electronic component that goes crazy when there is a voltage surge that strikes it such as lighting throughout the house wiring. The board needs to be replaced unless you can have an electronic wizz-kid test is out and repair it , or just by a new board. By the way, the board is not cheap and may be difficult to locate since I understand the the manufacture stopped producing it.
Aug 13, 2009 | Microwave Ovens
Where are the fuses located? The microwave just died, no power, lights, anything. There is power to the outlet though.
you have to remove the vent grill at top. take out the screw above your control panel. fuse should be in a housing behind panel. if not you have to remove mw wrapper to expose all componets
Jun 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE JE 1860. Someone ran the microwave for 15 minutes with nothing in it. Now it doesn't work at all , no power, no lights, nothing. Is there a fuse that may have gotten burned out? Is this...
There is a fuse and cavity thermal fuses as well as one on the magnatron that is supposed to reset itself.. The fuse is behind the control panel and the cavity fuses will require removal of the cabinet. Did you check for power at the plug?
Eric
Jun 20, 2009 | GE JE1860 Microwave Oven
I replaced the light bulbs but they still do not come on and the vent fan will not come on either?
the fan and the surface lights are run through the control via the touch pad. if you tried to replace the bulbs without unplugging the unit 1st you probably shorted the board. this can be checked by lowering the touch control panel by first removing the vent above it to access the panel screw. at this point you can observe the control for burn marks
May 17, 2009 | Hotpoint RVM1325WW Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
76 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
