Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Black screen I turned on my computer and logged on and returned to my computer 5mns later to find the screen all black and the blue button on. I turned off the computer and resarted to no avail. Is there a back light that i need to change? Thanks for your help Nas.
    Novelist:
    Scholar:
  • 141 Answers
If it's a lap yes you do have a back light but that isn't necessarily the problem. Laps have fn (function) keys that you may have hit accidentally. Look at your keyboard for any keys that may look like they have something to do with the brightness which you would hit the fn key first then the brightness key. You could also try to boot to the bios screen and "set defaults". It's also possible you've turned on the fn key to use an alternate monitor. You may be able to boot into safe mode and bypass any changed settings should this be the situation.
If nothing helps shine a light on your monitor if its an lcd and it it's the backlight you will still be able to see a screen just not lite up.
Posted on Dec 11, 2008
My Samsung SyncMaster 740N occasionally turns itself off. Timing varies and the condition varies. Usually the screen just goes black - from seconds to hours after it is turned on - the blue LED remains...
This could be because of the 'eco' friendliness of the monitor. Basically a lot of monitors are designed to turn off into a low power state when not in use so to preserve power and life of the monitor. I would return the monitor as the sensors that control this seem to be broken in your monitor.
Mar 15, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
My Imac crashes. 10.6.4, 2 GB ram, 2 GHz core duo. I've started with a clean install and disabled (one by one) all start up apps. Out of the clear blue, the screen will go black & I have to turn it...
When you say "screen goes black," does the computer power down, or is it still operating? Does the sleep light come on? Does it respond to the keyboard and mouse? (Example: press the power button momentarily, wait a few seconds for the "Do you really want to shut down" message to appear, even though you can't see it, then hit the return key to answer "OK," and see if it shuts down.) Does the screen go black or come out of black if you tap the computer?
While your computer is working, go to System Preferences / Desktop & Screen Saver, the Screen Saver tab, click Hot Corners, and set a corner of your screen to Put Display to Sleep. Then next time your screen goes black, mouse your way into that corner, pause a few seconds, then mouse back out and see if your screen returns.
Jul 10, 2010 | Apple iMac 17" Desktop
Worked fine this am now black screen blue power button
This is usually the inverter/power board failing. If it's under warranty, you should return for repair/replacement, if not, you can search for online the inverter/power supply board - it can be as expensive as finding a good clean used monitor, so many people choose to not go the repair route.
Jun 05, 2009 | HP f1905e Monitor
Compter won't open windows
first try that safe mode option and do log in . when you successfully log in restart your computer . this happen mainly when there is sudden loss of power supply to the cpu. shut down your computer properly by pushing the power button on the cpu
Jun 19, 2008 | Computers & Internet
Dell AS501 flat screen monitor
The front panel switches seem to be the culprit.
If you are technically sound you maybe able to solve problem by opening monitor and clean front panel switches or replace them.
Samir.
Feb 28, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Aug 09, 2007 | SanDisk Sansa e250 MP3 Player
Monitor Display Problem.
Like most of these LCD monitors it is more than likely a PSU problem to do with the Electrolytic Capacitors, These in all probability will be faulty.. there are usually about 4 - 6 from 1000uF to 100uF replace ALL with same or better.
May 31, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
