Question about Proform 980 CS Treadmill
I have a 980 treadmill and I cannot get the tread centred. I run 5 days a week for 40 mins at 11.5 km/h. However, recently, my tread spends all of its time on the right rail, and has begun peeling as a result of rubbing. Everyday I have to tighten the rear bolts for my run or it will slip. I cannot centre it for the life of me--I've followed instructions here and do to one side what I do to the other... It also now needs significant tightening or will slip within 15 minutes. Makes a great deal of noise off centre. Sort of to the point where I want to have it professionally serviced but don't know who to go to.
  • 77 Answers
Sounds like your belt has stretched to the point where you need a new one. These are typically easy to install yourself. See Treadmill Parts for a quote.
Posted on May 20, 2011
I have recently installed treadmill motor brushes but now treadmill is not calibrating,calibration takes start and when calibration comes to check the slow speed it stuck there and keep calibrating it
Hi There, Please check that you have the small feedback connectors snug and proper. Some treads have them on a front or rear roller and some also have a motor feedback. Or - Try to power down and back up and try to run treadmill normally, not in cal mode, and see if the unit responds to your speed selections correctly. During "calibrations" the upper board (usually) is looking for a specific feedback signal, if it cannot be found it usually stops the tread, but in cal mode it may sit there waiting for it's feedback sweet-spot before continuing. What make, year and model of tread?
Jun 02, 2016 | Exercise & Fitness
Tread belt not turning on
please LUBE the deck belt with WD-40 or grease . and try to loose a little the deck, the idea is to lift- 2-3" max.
Of course is time too, to maintenance Motor
Feb 12, 2015 | Nordic Track NordicTrack C2200 Treadmill...
Pro-form 980, regardless what button I hit the speed goes to 12
1) test the speed sensor, for open or faulty, see the adjustment. Clean if and tight the connector very well
2) tight the ribbon cable for keypads , and clean it
3) replace batteries,and clean the contacts baterries very well
4) adjust the Reed swtich, test for open or faulty, clean it and tigh the connector very well see the diagram
5) Run the software calibration for troubleshooting, diagnose, and fix it.
Jan 22, 2013 | Proform 980 CS Treadmill
Motor getting hot 340 cs
Dear Sir:
Please RUN the software calibration for easy diagnostic and troubleshooting.
Your motor can be defective for various reason;1) ball bearing 2) Brushes 3) winding defective 4) Dirty 5) Lubrication, etc.
sincerely. God bless you.
Apr 07, 2012 | Treadmill Doctor Weslo Cadence 340Cs...
How do I adjust the tracking epic t 40 treadmills
there are screws on the back, use an allen wrench, one quarter turn at a time. To move it right, tighten the left, to move it left, tighten the right.
Sep 19, 2009 | Epic T 40 Treadmill
Kettler treadmill "silikon wartung"
Hi eirik,
Your treadmill needs lubricating.
Get a an aerosol with silicone lubricant and spray it under the belt & on top of the ground board.
Then turn the belt by hand (treadmill switched off!) until you've lubricated the whole belt.
Next leave the machine running for 5 minutes at 5 KM/H (3 M/H) without any load on it.
That should do the trick.
Mar 29, 2009 | Kettler Exercise & Fitness
Need owner's manual for ifit.com treadmill
1. When walking on the treadmill the belt abruptly stops.
2. As the speed increases so does the noise. Is this associated with the belt tension? Tightening the belt causes the belt not to move at all. What might be the solution to 1 & 2?
Dec 12, 2008 | Exercise & Fitness
Proform 980 CS Treadmill Logo
146 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
