Diagram of 24 pin and its function to a mother board
  • 393 Answers
24 pin socket in motherboard is used for connecting the power cable from the PSU.
Image are given below..
Motherboard connector.
PSU connector..
Thanks for using FixYa.
Posted on May 19, 2011
2 Suggested Answers
Teh_shivers
  • 104 Answers
SOURCE: power conection
yes
Posted on Dec 15, 2008
Fan is working without 4 pin ATX pin but not with 4 pin ATx
Fans are Controlled by Temperature Control Setting of the Mother board. So the Fan controller is a function of the BIOS of the Mother Board...
Jul 17, 2014 | Intel Computers & Internet
I cant find where do i connect power switch there no slot indecated on the board help me pls.
Hello Friends,
If you are ask mother board power option. There are two power option every mother board, one option is SMPS power and sec option is Power Jumper. SMPS two power socket indicate 24 Pin and 4 pin also same option 24 pin and 4 pin socket available in mother board. Second option is 9 pin jumper socket hear connect to HDD power, reset power, cabinet power, power LED, and +5v DC. So you open PC and see all section and solved you problem.
Thanks.
Aug 22, 2013 | Gateway Computers & Internet
Need a new power supply for a soyo mother board Crown model fp-
All you need to know is if your motherboard has a 24-pin or 20-pin power connector. You can just count the pins if you don't know. There connector is located on the motherboard. It looks like this: moondogwst75_3.jpg
So if it's a 24-pin, order a 24-pin power supply. If it's 20-pin, order 20-pin. Hope this helps!
Aug 28, 2011 | Computers & Internet
KK266 mother board (IWill) need a wiring diagram, usb is not being identified
Antec doesn't make mother boards, they make enclosures. The standard USB connection on the board is a 2x5 pin connector, with 1 pin missing. The end that has the missing pin, is the end that the cable shield is attached to.
Mar 24, 2010 | Antec Computers & Internet
Do you have a diagram that would show me step by step how to install the new power suply I bought for my computer.
Their is really no diagram to show you how to hook up your supply.
You only have a hand full of plugin connections.
Your 24 pin connection to the mother board, you may or may not have a 4 pin 12 volt video connector, which has to be connected if on the board., and your fan connections.
Everything else is controled thru the motherboard.
Nov 25, 2009 | MGE 400W Power Supply (QG) Power Supply
HDD and reset light on intel p4 82845 mother board
Hi pc_ski,
Download the manual for your board, click on this PDF link.
http://download.intel.com/support/motherboards/desktop/D845GLLY/ADLY_English.pdf
See page 64 first for the layout of the front panel header. The block you need to refer to is letter C. Here you'll see where pin one is located at.
Go to page 65. Table 32 shows the pin assignments for the front panel header. Pin-1 & pin-2 is for the HDD & pin-7 & pin-8 for reset switch.
Have more questions? Post here.
Good luck pc_ski!
Mike
Mar 22, 2009 | Intel Desktop Board D845GLAD Motherboard
Mother board layout diagram
Here is the support webpage for you model which may show you some things. It doubt that it will give you a wiring diagram.  To receive that you would have to know who made the mother board, then cross over the board numbers.
http://h10025.www1.hp.com/ewfrf/wc/product?product=3771735&lc=en&cc=us&dlc=en&submit.y=3&submit.x=8〈=en&cc=us
Jan 06, 2009 | HP Hewlett Packard Pavilion a6510t- Intel...
D845epi mobo has flashing green light after power supply replacement
Unplug the power then unplug the 24 pin power connection from the mother board and take paper clip bend it so you can insert it into the holes where the green and the black wire are next to each other, Next you will need a multi meter. Set the multi meter to read dc volts 20 take the red lead and put it into the purple wire hole of the 24 pin connection and the black lead in to the hole with the Black wire on the 24 pin connection. the reading on the Multi meter should read 5.0 volts if it does not and you get a reading of 6.01 or higher then the Mother board has been burnt out and you will need to replace the motherboard and power supply I have been a onsite tech for E-machine for the last 5 years and this has been an ongoing problem with the power supply.
Nov 02, 2008 | E-Machines eMachines Desktop PC
HP DESKTOP COMPUTER
If computer is not powering on then open u r cpu and check the SMPS i.e Switch mode power supply which converts AC to DC it gives a output of 5v & 12v in that the 20 pin or 24 pin connector which is connected to the mother board remove that and short the wires Green and Black and make sure to remove all the power connectors i.e,hard disk,Cdrom or cd writer or DVD writer or any other device and one more connecto which is a four pin connector which is connected to the mother board please remove and test the 20 or 24 pin connector by shorting green and black and behind the smps u have a power cord of ac 220v just plug it and switch on if smps fan rotates that means it's fine then the problem willbe on the mother board just try this
Jul 30, 2008 | Computers & Internet
How to connect Remote to computer
Hello Nairy, Install infrared module onto IrDA connector, and enable function from the BIOS setup. Make sure you have the correct orientation when you plug into the motherboard. Location: Towards rear of motherboard, next to first PCI slot, on AGP side. The number one pin is closest to rear of board. Pin Configuration: 1. +5V 2. NC 3. IRRX 4. GND 5. IRTX 6. NC Please let us know how this works for you, and if we can help you in any other way. Best regards, nightdiver
Sep 20, 2006 | Acer AOpen AX 59 Pro II (91.87810.402)...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
