Washing machine inlet/drain problem
Washing machine drains water while letting water in, therefore never enough water to wash; control panel has been replaced
  • 5,911 Answers
You may have a simple problem known as "siphoning". Have you checked your installation/ In particular, the drain hose? the following link explains how to check and correct a siphoning problem with a washer:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Usually when a washer drains as it tries to fill, its a drainage problem of some type. You may have a simple problem that is easily remedied. You may not require anything, but pulling the drain hose up out of the standpipe and repositioning it to ensure there is a proper air gap for drainage. I hope this helps you.
Posted on Aug 14, 2008
Why Does all the Water Drain while the machine is washing and soon the entire water drains even though its in wash
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
Apr 05, 2015 | Washing Machines
I have a silver Inesit WIDL 126 S washer dryer. Whenever the wash cycle completes, it then lets in some water from the inlet. Then stops. I tried draining it, it drains, then lets in water from the inlet,...
A device called a solenoid open and closes when activated by the control board (circuit controller). If debris collects inside of the chamber when it is open or closing, it can leak or simply shut down. This device will open upon command and allow water to enter or exit. It takes its orders from the command center and if it is damaged, plugged, or no longer capable of switiching on and off, it needs replacement.
Mar 12, 2014 | Indesit W 123 Front Load Washer
Washing marchine will fill with water and then drain off
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jan 24, 2013 | Washing Machines
Not enough water for washing cycle
Jan 21, 2013 | Hotpoint Washing Machines
Washing machine failour
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 11, 2013 | Washing Machines
When starting a wash cycle the water never fills up and therefore doesn't wash, just keeps "rinsing"
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Thank you for using fixya.
Sep 15, 2011 | Admiral AW22 Top Load Washer
Indesit washing machine wmb714425 no life no electric no panel lighting up changed fuse,checked socket both ok help
Aug 26, 2011 | Washing Machines
NEED SETTING WASHING MORE THAN 1HOURS VENUS VW600E WASHING MACHINE
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
The slow inlet flow and clogged draining can slower the time of the wash and so both the inlet and outlet must be cleaned and flushed.
Aug 09, 2011 | Electrolux Washing Machines
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Richard Roth
Richard Roth
