Question about Cell Phones
My Samsung punch is turning off automatically even if its in full battery.. when i press a keypad, it will now turn on... hope to have a solution.. it is greatly appreciated.. thank you so much..
  • 844 Answers
Welcome to FixYa!
It is most likely that you have a sticky keypad or the metal switch pad underneath the keypad of the power button is broken.
What you can do is to clean the inside of the keypad and check if there are broken metal switch pad underneath the key pad that results to sticky keys. You will need a special cell phone star screw driver to open the front panel of a samsung which will expose the key pad and the switch pad underneath. Unscrew all the screws at the back of your samsung phone and gently lift the front cover.
It is also possible that the problem might be in the software installed on your samsung. In this case, you will need to bring it to a repair center since it requires special software for re-installation and a hardware. Samsung cell phones cannot be re-installed through a USB plug and play.
Thank you for using FixYa. Have a great day. Jas247
Posted on May 19, 2011
Testimonial: "thank you much.. it is a great help... ill keep those in mind .. gudluck and god bless.."
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
On my n79 the camera automatically turns on and off randomly and even the keylock get unlocked automatically and randomly every second,the phone get hanged up as the mobile screen turns even when the...
There may be some oxide coating below the keypads, try to open the keypad and dome-sheet beneath and clean the contacts.
Hope this will find a solution for your keypad issues.
Jul 20, 2017 | Nokia N79 Cellular Phone
Samsung s3310 keypad 789 not working Wat solution sir
SAMSUNG S3310i CALLING KEY & 2,5,7,0 KEYPAD NOT WORKING.PLS. GIVE ME SOLUTION.
Jan 08, 2011 | Samsung S3310 Phone
My samsung blue flip cell phone, everytime I press 369 or#....
If you notice the 3,6,9, and # are all on the same column. There is probably some corrosion under the keypad from a spill or moisture. If cleaning the membrane switches won't work try replacing the keypad (the electronic portion, not the rubber). Repost if you need instructions. I can put some parts up on ebay for you too.
Aug 17, 2009 | Samsung Cell Phones
Password problem- SGH-M120
If you have forgot your password, then flashing the ROM memory of your mobile in a mobile service center is the only way. Before that try with the default password of your phone. Refer your phone manual for it. Try 0000/00000/12345/1234/1111/11111 (any one of this may be default)
Aug 09, 2009 | Samsung SGH-D900 Cellular Phone
"C6000"
You have a bad FUSER assembly.
Jun 23, 2009 | Kyocera KM-1505 Copier
Keypad freeze
Did the key pad froze before you took the battery off? If so, it mean the keypad is damaged. If you have insurance, you may call customer service and have it replaced for a new one.
If it frozed after you shoot it off, you might call customer service from another phone and they might help you to unlock your phone.
Artgirl
Jul 17, 2008 | Samsung SGH-D900 Cellular Phone
No response from keypad input?
check your volume keys or any side keys that get stuck... or if you can open your fone check its keypad for any shortage...
Oct 26, 2007 | Samsung SGH-d407 Cellular Phone
Cell Phones Logo
96 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
