Question about Husqvarna Garden
I have a YTH2042XP and today it just died on me its done 118 hours and battery is fine oil and petrol is good but just dead when trying to start
  • 34 Answers
SOURCE: macbook pro start up problem
First remove the battery, then plug it into your AC adapter. Hold the power button for 5 seconds or until you either hear and beep or the activity light on the front of your laptop lights up. Start up normally.
Posted on Sep 16, 2008
  • 54 Answers
SOURCE: 2004 suburban 1500 battery keeps going dead
Something is obviously putting a drain on the battery, if all the things you had checked are good. If you disconnect the negative terminal on the battery touch it back, it should spark a little, but not alot. If it sparks quite a bit you know something is staying on that shouldn't. Possibly a glove box light, or if your truck has a light under the hood the mercury switch in it may have gone bad causing it to stay on. If it's taking 8 days to go dead you'll be looking for something small. I hope this helps.
Posted on May 10, 2009
  • 190 Answers
SOURCE: 1999 bmw 528i replaced battery and alternator
Replace your battery when its being tested there not testing it under a heavy enough load. A battery could have a dead cell in it and still show good on the charger. I've had that problem a few times.
Posted on Jul 07, 2009
Murphybanton
  • 2004 Answers
SOURCE: Dead battery or something more?
It could be the battery but I will advice you to check the Alternator/ Charging system too.
Good luck.
Posted on Sep 28, 2009
SOURCE: my Garmin 405 died today while i was running. It
my lap reset button is stuck on my Garmin 405 and I've only had it a little over a year. Help.
Posted on May 09, 2010
I have a 1999 Legacy. Died while I was driving. Oil didn't register on dip stick. Won't start now. It turns over fine. Has power, compression, oil & fuel pressure is good. Plugs are dry(Not saturated)....
Could have overheated because low on oil, the engine may not start until the computer is reset, a safty feature which keeps the engine from damage in such cases., Take it to a mechanic to reset the computer if you think the oil being low was the main issue.
Nov 01, 2013 | Subaru Impreza Cars & Trucks
Car suddenly stopped 30 minutes later runs perfectly
This failure could be the crankshaft position sensor. Overheating or an oil leak through the rear seal can cause it to fail intermittently. My SL500 failed to start after traveling a distance, but after sitting for an hour or so, it suddenly started. Replaced the CPS and all was fine. Also, a dying fuel pump might cause this.
Apr 20, 2013 | Mercedes-Benz Mercedes Sl 500 Class Sl500...
2006 Jetta 2.5 battery died, jumped car, radio won't turn on
Take it in to have a charge system check done on it, Your alternator is probally shot,
Nov 27, 2012 | Cars & Trucks
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
Lets try this again. Tahoe battery was dead for 24 hours. We jumped it off, ran fine for a 10-15 minute drive. Got home, it sat for 4-5 hours and had to run an errand. Tahoe fired right up, put it in...
Check engine light come on ? You should have some testing done ! Fuel pressure an flow testing , Scan tool data checked . Charging system , battery , connections , cables . What data does scan tool show for mass air flow sensor , what are the fuel trims at ? If you don't know what these are you need to take it to a qualified repair shop .
Jun 02, 2017 | 2001 Chevrolet Tahoe
Good luck.
Sep 28, 2009 | 2005 Nissan Titan
I just bought an 1993 mazda rx7 today but it wont start last
bastard things are prone to flooding im afraid, take plugs out,whizz it over for 30 seconds be patient and wait for half hour to give time to dry out, then a couple of squirts of oil in each plug hole, whizz it over for about 2 seconds,then a couple more squirts of oil in each plughole again,replace (dry) sparkplugs, leads on turn it over and it should go.ive suffered this twice this year (in the rain).
repeat if nescessary
avoid this problem by NOT RUNNING for LESS THAN 5 MINIUTS,as this is caused by a rush ov petrol because ecu thinks engine is cold so injects more fuel, then you turn engine off,this rush of petrol rinses the rotors clean of the oil they depend upon to maintain compression upon restarting, this is where the proceedure above works.
regards
dave
Jul 03, 2009 | 1993 Mazda RX-7
Got my mito last weak and it would not run after a few hours of cleaning carb/charging battery/clean plug fresh petrol it started fine the next i went to take it out it started fine but when i hit 3rd gear...
Spring for a new battery pal, your's is NOT doing it's job...if you put a volt meter on it you will see.....it's toast....Good Luck to you my friend....Tim
May 12, 2009 | 2000 Cagiva Mito 125 Evoluzione
Petrol is mixing with the gearbox oil
The pistons rings are worn out which is allowing the petrol to mix ,you must change the piston and piston rings in your bike...
Good luck...
Dec 09, 2008 | 1988 Suzuki DR 750 S
Garden Logo
50 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
