Question about Kohler Home
I have 5 kohler pressure assist toilets with flushmate 503 series tanks in my home. Several of my bowls have minimal to no bowl rinse. My water pressure is more than adequate. I recently changed a flushmate tank on one of my toilets that does rinse well and noticed a hole knocked out of the porceline just to the right and to the back of the hole that the flushmate delivers its supply of water to the bowl. On installation or construction is there a hole that needs to be knocked out to allow water delivery to the rim for an adequate bowl rinse. The water delivery and pressure to the bottom of the bowl is great. I believe it would flush a brick if placed in the bottom but the bowl rinse is terrible. We have to keep a pitcher in each bathroom so water can be drawn from the faucet to rinse the sides and front of the bowl. thanks...Ken
  • dherzog126 Nov 18, 2011
    are these 1.4gpf or 1.6gfp toilets? It should be printed behind the seat on the porcelain.
There are two holes in the top of the bowl where the tank attaches. As you indicate, one hole delivers water to the jet at the inlet to trap passageway, and another smaller hole to direct water to the rim.
I have seen in some cases the gasket that seals the tank to the bowl block the smaller rim-fed hole. All you need to do is knotch the gasket where the hole is located and re-install the gasket so the knotch is located over the hole. If you have any other questions please call the 800 phone number on top of the Flushmate.
Posted on May 19, 2011
  • Jim Hirschauer
    Jim Hirschauer Dec 01, 2013
    I used this fix on 3 powerflush toilets in my house and it worked great. My toilets actually rinse the side of the bowl now!
I have a 2yr old Kohler K4634 toilet. After flushing the water level drops about 1 inch in the bowl after the bowl filled. This causes a lower level in the bowl than is recommended. The main issue
check to see if waster continues to run into the bowl after the plunger has returned to stop water flowing. If it is a slow leak then replace the flush washer on the stopper plunger.
Oct 01, 2014 | Kohler K-4634-RA-0 Cimarron Toilet Tank...
How can I remove the Flushmate 503 to access the mounting screws at the bottom of the tank?
You will need to remove the china holding tank from the toilet bowl by removing the nuts on the underside of the china tank.
After you have the tank off the bowl, remove the two plastic lock-nuts used to mount the Flushmate into the china tank and slide the Flushmate out of the china tank.
After you install the new tank-to-bowl bolts & washers, reverse the process to reinstall the Flushmate unit and remount the china tank.
Mar 01, 2013 | Home
Flushmate 503 sprays water out of top of tank, apparently coming for under the flushmate system. The valve doesn't seem to leak. Iahve pressure tested it.
Turn off the water supply at the wall, flush the toilet to relieve the pressure inside the Flushmate, and call Flushmate Consumer Services at 800-533-3460 M-F, 8:00 - 4:30 ET.
They'll need to know the serial number and approximate date of installation of the Flushmate.
You could alos fill out a confidential "contact" form on the contact page of the Web site, www.flushmate.com.
If yu need to use the toilet in the meantime, you can "bucket flush" it by pouring 2 to 3 gallons of water into the bowl. This will generate a standard siphonic flush and won't give you the pressureized extractiopn but it will keep the toilet usable until a Flushmate support tech can diagnose the issue and provide a resolution.
Aug 17, 2011 | Sloan M-101526-F31 Flushmate?® Complete...
Flushmate Ser. 503 has a leak. how do I change it???
please explain: do you mean leaking into the tank or running into the bowl?
Jul 27, 2011 | Sloan M-101526-F42 Flushmate?® Complete...
The bowl will not hold water. This is the second toilet we tried because Kohler thought it may be a faulty tank but same problem. Everything works correctly in the tank but after flushing the bowl will...
the tube that goes from the fill valve to the fill tube may not be installed correctly. the water must be going in the tube and not the tank. also it is a water conserving toilet so it uses less water also it is a comfort height toilet and to make it taller the bowl is extended so the water may seem even more shallow.
Jan 18, 2011 | Kohler Highline - Comfort Height Two-Piece...
Water in bowl. water level almost below where bowl saris to widen! , Kohler cimmarron - Toilet tank is full, all water flushes out of tank when flushed it's been this way since we installed it
If I understand correctly, your water level inside the bowl is 3 or 4 inches from the top of toilet seat?
Sounds peculiar to have that water level since you would get splashing etc.
That is not sanitary, and would be a code violation.
Look at side profile of tank.
Look at porcelain behind bowl and you can see outline of "s trap."
This is the internal trap that each toilet has built in.
Purpose of trap is to a) set water level inside bowl and b) just like a sink trap, seal pipe from sewer air from entering home.
Photo shows trap on sample toilet, with line showing approximate level of water inside bowl.
Since photo is at an angle, the line appears to go downward instead of level. Again the line is approximation, and photo intended to show where you can look on your toilet.
Your tank should have similar s-trap feature. From the feature on your tank, you can see what level water is intended to be inside bowl.
Some more expensive tanks, outline of s-trap is not apparent.
If the water level is so high that you experience unsanitary conditions, this is a code violation, and toilet should be replaced.
Quick web search turned up Kohler contact page: http://www.us.kohler.com/general/contact.jsp
KOHLER Customer Care at
Phone: 1-800-4KOHLER (1-800-456-4537)
Hours: 8:00 AM - 5:00 PM (Central Time) Monday to Friday
You can refer Kohler to this link on Fixya so they can clearly understand issue.
Jan 09, 2011 | Kohler - Toilet - Two-piece - Highline -...
Tank serial # looks like this? S 00 K 4520 ...
that is a Kohler model 4520<br /> the other numbers are for manufacturer codes.<br /> <br /> is this an older toilet? Kohler discontinued that model.<br /> <br /> <a href="http://www.designtool.kohler.com/us/detail.jsp?item=9654702">http://www.designtool.kohler.com/us/detail.jsp?item=9654702</a>
Aug 31, 2010 | Cadet Manufacturing American Standard...
Just hooked up new pressure asist tank & bowl,turned on water to it,and it want flush.what i mean about want flush, is it will flush but water does'nt go down,as if it's not staying open long enough.
Sounds like you have a clogged drainline or vent-stack. Fill a large bucket with about three gallons of water and dump it quickly into the bowl. If the drainline/vent is clear, the toilet will "flush" like a gravity toilet and the water will drain from the bowl almost as fast as you can pour it in.
If the water level in the bowl slowly rises (as if it's about to overflow) and then slowly drains, you have a clog somewhere.
All toilets, regardless of their flushing mechanism, require a clear, unoibstructed drain/waste/vent system to extract waste.
If the toilet "flushes" with the bucket of water, you may want to call Flushmate tech support (the number is on top of the tank) or check out the installation and troubleshooting videos at howto.flushmate.com.
Hope this helps.
Aug 18, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
FLUSHMATE TOILET BOWL WON'T HOLD WATER
The Flushmate system won't cause or contribute to water draining or leaking from the bowl.
Negative back-pressure in your drain/waste/vent piping could be siphoning the water out or you may have a crack in the bottom of the bowl or trapway that's allowing the water to leak out.
If the floor under the toilet (actually underneath it) or around the edge where it's caulked to the floor is wet, your bowl may be cracked. If not, your plumbing system may be siphoning the water.
Either way, you can exclude the Flushmate from the equation and focus on the porcelain fixture and your drain/waste/vent system.
Hope this helps.
Jun 06, 2010 | Sloan M-101526-F Flushmate?® Complete...
Home Logo
479 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
