Question about Hotpoint Ultima WF840 Front Load Washer / Dryer
Hi I have a Hotpoint WM D940G washing machine and after selecting the wash cycle needed nothing is happening. Then after a short time it is saying on the display No water check the supply if you then leave it to run the diplay will change to dashes and displays the F01 error code. I have checked the water supply and the wires and connections inside all of which seems fine. I have also unplugged the machine and let it stand all of which have not helped. Would you be able to say if it is likely to be the control board at the top or the main power board at the bottom of the machine as I am unsure which part to buy. Thanks Gary
    Brigadier General:
  • 6,277 Answers
For most Indesit (Hotpoint and Ariston) models 'F01' often refers to the 'motor triac- check connections' but for a number of faults apparently poor PCB connections are often the cause so try this/these first. If you are not electrically confident and competent yourself, which you appear to be, you need to employ the skills of a partner, friend or service engineer ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 19, 2011
How do I get into check the pump for blockages on my hotpoint wmud942 washing machine, the key symbol is on all the time with door locked, when a programme is running the pump starts but then when it
I would suggest you fill the washer with water externally up to below the door level and run it in one of the short wash cycles. I would assume it will progress further into wash. This would suggest the inlet water circuit has a fault. I am hoping the laundry water tap was turned on when you were running the washer.
Best to replace the inlet valve and see. Worth spending the 20 quid.
Hotpoint WMUD 942 UK Washing Machine Valve
Sep 07, 2014 | Hotpoint Washing Machines
My new hotpoint washing machine on occassion is showing fault F-01 can you tell me what this means I have not been able to wash a load becuase this is showing up. Sometimes if i switch it on and off again...
You say 'new'- if it is still under guarantee do nothing other than contact the vendor as soon as possible! The reason for saying this is that for most models of Indesit (Hotpoint and Ariston) washers (you do not say which particular Hotpoint model yours is) 'F01' decodes as 'motor triac short. check motor and module connections'. This obviously is a job for the service engineer!!!
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
May 07, 2011 | Hotpoint Washing Machines
Hotpoint Electronic 800 WM 12 Aquarius won't rinse
If it won't rinse because it won't fill, it's most probably because the cold water inlet valve is faulty. Many machines will only rinse with cold water....No cold water.....No rinse!! Not a big job.....Nomess
Apr 13, 2010 | Washing Machines
My hotpoint wf540 will not start a cycle it very quicly steps to wash light showing but nothing happens door locked light is not illuminated.Just prior to this fault the fuse in the mains plug had blown.I...
1st you need to know if power is getting to machine, Next could be door interlock switch faulty the fact the fuse blew indicates possible short circuit/ excess current draw occured also check motor brushes assuming machine fills with water 1st
Nov 05, 2009 | Washing Machines
Hotpoint 800 wm 11 goes through cycle but won't spill or drain
hi there maybe your waste pipe might be blocked from washing machine or mqaybe there is a blockage somewhere else in your plumbing which does happen queit alot? hope this helps
Jan 11, 2009 | Hotpoint First Edition FEW12 Front Load...
Machine not spinning after a power cut
machine can be reset unplug from the wall for 5 mins that will reset com board.
Jan 07, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WM A54
about the same level of difficulty as zanussi. however on some wma series the bearings are not available seperately - new drum and tub- so check first
Sep 14, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WF840 Front Load Washer / Dryer Logo
134 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
