Question about HP LaserJet P2015n Printer
Hp p2015. my ip has become 0.0.0.0, how do i reset it
  • HP Master
  • 32,281 Answers
To configure this model HP Laser as a network printer, please click on this link and follow my instructions ;-
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Posted on May 19, 2011
Hello , I need to know if hp-laserjet p2015 printer have a "built in" network card ? if not how can i share it between two computer by using a switch ?
HP Laser jet P2015n & P2015dn models having network facility, there is no option to add on network card for this series.
1. Install the printer locally through USB in one system and share it to others if its non "N" printer.
2. You can connect use network to USB convertor to print thorugh network. pl see the link for one of the sample product..
http://uk.shopping.com/Conrad-USB-2-0-NETWORK-ADAPTER/info
Sep 20, 2011 | HP LaserJet P2015 Printer
I replaced a hp laserjet p2015 printer with another hp laserjet p2015 printer but it can't print.what's the problem,pls help me
This HP printer is comes with the USB cable. To install the printer software, you need to install the USB driver compatible to your printer and then it will ready to print.
Dec 08, 2010 | HP LaserJet P2015 Printer
How to clear event log in HP LJ p2015 ?
Use the embedded web server.
Type the IP address of the printer into your browser.
the event log should be somewhere in there.
Aug 18, 2010 | HP LaserJet P2015dn Printer
I have 2 HP LaserJet P2015 with the same IP Address and have tried re-setting one back to factory settings by holding down the go and cancel buttons when switching the printer on, but it is still keeping...
Hi Sue_sams
If you know the IP address of the printer then you should be able to do a reset via it's internal GUI.
1. Make a note of the printers IP (if you print a status page by holding GO for 5 seconds it should give you this).
2. Open up Internet Explorer. Where you would normally type www. type the ip address of the printer (make sure there is nothing else in front) and hit enter.
3. Click on the 'Networking Tab' and give the printer the IP that you want it to have.
For further help a PDF of the manual can be found here. Details of the Embedded Web Server are on page 54.
Hope this helps and good luck!
Scott
Feb 01, 2010 | HP LaserJet P2015dn Printer
HP P2015 Intermittent paper jam lite on solid.
Remove the covers and thoroughly clean the inside of your printer. Vacuum it out and wipe it down. Then examine the sensors and their wiring connectors. Intermittent problems are difficult at best. I suspect a thorough cleaning will eliminate it.
Nov 09, 2009 | HP LaserJet P2015 Printer
Laserjet p2015dn i am trying to set it up and i can not find the password to access the config menu
Hi in LJ P2015 there is no way to set-up password.
Press and hold download green button for 6 to 7 seconds(Not more than 7 seconds) and release it will print self test configuration page on third page netwrok configuration page three is a option called IP Address put that IP Address in the browser it will open printer page and you will be able to browse the printer.
Dec 29, 2008 | HP LaserJet P2015 Printer
HP LJ printer printing slowly
try to change the driver on the network definition
Nov 21, 2008 | HP LaserJet P2015 Printer
Printer status offline
I just ran into the same problem. The computers on the network that were running XP were showing the printer as "Ready", but all of the computers running Vista were showing the printer as "Offline".
After trying a number of solutions that I found on other message boards, I accidentally discovered that the problem was an IP address conflict. It seems that the server changed the address on the printer, which didn't bother the XP machines but brought the Vista machines to their knees.
Press and hold the blue button (HP called it the "Go" button) for 5 seconds, which will print a configuration report. In the TCP/IP section you will see the IP address for the printer. Next, open the Printers window, right-click on the P2015 and click Properties. Click the Ports tab. Find the port that is checked and click the "Configure Port..." button. If the "Printer Name or IP Address" field differs from the IP address on the configuration report, change it to the one on the report. It took a few seconds after hitting OK for the computer and prrinter to link up again, but that solved the problem for me.
Sep 08, 2008 | HP LaserJet P2015 Printer
HP LaserJet P2015n Printer IP adress
To Me it looks like your printer is set to automatically select an available IP address. If there is no IP available you get the 0:0:0:0 You need a static IP set up for the printer, this will make sure that no one can use the IP. If this is a company printer, get IT to set it up for you. If its your home network you can set this by yourself by either connecting your printer via usb and using the software from HP or if you have an IP you can log into your PC by entering the IP address in the address bar of your browser. You should get the HP page up for your printer. Set the IP from there in the networking section. I hope this helps a little
Aug 18, 2008 | HP LaserJet P2015n Printer
HP LaserJet P2015n Printer Logo
397 people viewed this question
Seeker5211
Seeker5211
