Question about Sony Playstation 3 (PS3) Console
PS3 wont read any discs
All of a sudden my ps3 quit reading discs. was working fine and now wont read any disk at all. Is there anything I can do to fix this?
    Master:
  • 848 Answers
You need an torx 10 screwdriver and a pretty small philips screwdriver like you use it to fix glasses or other stuff with extremely small philips screws. then you need another philips screwdriver, a bit bigger than the small one.
1. in the first step, you have to go to this page:
www.teknoconsoles.com
there you can download a video tutorial which explains how to open he console. its pretty good, everyone should have no problems to open the damn thing.
then you have to download another video tutorial. its named "cleaning the lense". it explains how to open the bluray drive.
2. time to open the console
follow the video tutorial until you have removed the bluray drive.
3. time to open the blu ray drive (you really have to be careful here)
follow the video tutorial until you see this:
http://techon.nikkeibp.co.jp/english/NEWS_EN/20061116/123...
lets call the side of the drive, where the disc slot is "the lower side" and the left side on the picture the "upper side".
on the left and the right side aof the drive you see two long black plastic "things". you normally should be able to move them up and down a little bit. but in the most cases with broken drives, you will see that you cant move the right black thing.
this is the reason:
if you look at the big metal "border" which holds all the laser stuff and the lense etc, you see that there are 4 "screws" which hold the thing - two on the lower side where the disc slot is and two at the upper side.
when you exactly look at the upper right side of this metal thing (its the upper left side on the picture), you will see that it is not in the right position. you have to put your finger on the upper right screw and push it down ("down" in this case really means "down" and not in direction to the disc slot!) you have to be careful but you have to use pressure, too. then you should hear a sound like "CLICK" and it should lock in his right position.
now you should be able to move the right black plastic thing up and down a little bit!
after that you can put all the things together again (like in the video tutorial).
now everything should work fine!!!
but maybe you can insert a disc but it wont read it and you wont get it out again. if that happens you have to push the eject button for 10 seconds. then you should hear some noises inside the drive, the disc will come out and after that everything should work!
Posted on Aug 14, 2008
    Master:
  • 382 Answers
Try to reformat the HDD and restore it to factory settings,this should help then try to update the software of ps3..Also if u can try to see if theres any dust on the lens part and clean it..If all this doesnt work and if your ps3 has warranty then try to claim it for replacement..Thank you...
Kind regards!!...
    Master:
  • 623 Answers
You have a burnt chip take it to sony or any service center cant fix this yourself
  • 2,326 Answers
You might try to clean the lens using a lens cleaner. If that lens cleaner does not work, it could be that the lens became defective and will need to be replace.
You can also try to open the device and see if that lens mechanism went back to the home position. If it did not, you will have to rotate the small plastic gears by hand to the home position.
Let me know if you need further assistance.
  • 876 Answers
Here is website you might try . It is a forum with questions and answers just like you are looking for. Good Luck.
http://www.gamespot.com/pages/forums/show_msgs.php?topic_id=26477989
  • Sony Master
  • 6,487 Answers
You can try updating the software of your PS3 that should fix that problem...
Good luck....
Wont read disc
This is quite a common problem with the PS3 and is caused by a problem with the laser on the Bluray drive which is malfunctioning and can no longer read the game disk properly.
The PS3 uses a dual laser system. This consists of either a dual refractor type lens or two entirely seperate lenses depending on which pickup is fitted to your particular system. One laser is for reading ordinary DVD disks and PS2 disks and the other for Bluray and PS3 games.
The symptoms you describe are quite typical of a failure of one or both of these lasers.
For more information on how to resolve the problem please have a look at this FixYa Tip on the subject.
Many thanks for using FixYa.
Sep 05, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: disks are not reading. The ps3 is working fine oth...
This is quite a common problem with the PS3 and is caused by a problem with the laser on the Bluray drive which is malfunctioning and can no longer 'see' or read the game disk properly.
May 18, 2010 | Sony Playstation 3 (PS3) Console
PS3 makes clicking noise, wont read disk...
The only thing to do is get it checked. If you got yours a while after it came out you have a bad lazer. (thing that reads discs) you have 2 get it fixed. Play n trade is who i reccomend. google them. PS: my gamertag is NEROROTT I have all call of duties + a few others like borderlands
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
PS3 disc display does not appear when any disc is inserted
this iis quite a vague descryption im guessing that it is a 40gb ps3, sometimes they have this problem and dont read disks, ehm if your ps3 is still in its garuntee then you should contact them and sort it out
May 17, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont read the gaming discs
and of course you tried those discs on another ps3 unit and they worked fine right?
you know that Blu-Ray lens in PS3's, they die too quickly. Try a CD Lens cleaner first, if that doesn't fix it, go for warranty - contact manufacturer.
Nov 26, 2008 | Computers & Internet
Ps3 won't read any disks.
PS3 is The amazing device by sony but it has some common problems like Disc read error, unreadable disc etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Nov 03, 2008 | Sony Playstation 3 (PS3) Console
Wont read disks
the same think happen to my but with different game rsv2
it won t read any discat allif you know something about please help
May 03, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont read games discs
ts a problem with the latest download update. sorry to say but its a job for sony as long as its still under warranty. just phone them up explain the probs your having and they will send you a new (normally reconditioned) unit out. sony's replacement service is very good.
Feb 12, 2008 | Sony Playstation 3 (PS3) Console
Ps3 does not recognise any disc
man i too have a proble mm mine ps3 stopped reading ps3 disc but it reads only ps2 and other disc. but wont read ps3.. disc i tried getting a new one but it didnt work
Dec 12, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
60 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
