Question about Lexmark T632 Laser Printer
How do i find out what my current page count is on the Lexmark t632
  • 37 Answers
Print a menu page:
press menu right button until utility menu is displayed, then press select (lcd display print menu), press select again and the printer print the menu page, where you can see all the parameters.
Posted on May 19, 2011
Reset maintenance count
T632 reset maintenance count: Press and hold down the "select" and "return" keys while powering on the printer, hold these buttons until the display reads " 80 Scheduled Maintenance, press the "go" to continue past this message and access the configuration menu. Press the menu button until the display reads "reset Maint Cnt" on the second line of the display and press the " select" button. the top line of the display should nnow read "reset maint cnt" and the second line will read "reset" and pressthe "selcect" button. this will reset the counter to exit out of the "configuration mode" cycle the power.
Jan 16, 2014 | Lexmark T632 Laser Printer
T632 reset count
Enter diagnostic mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when Performing Self Test displays on the operator panel.
Once you're in diagnostic mode, go to Printer Setup > Page Count.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count screen.
Jan 30, 2013 | Lexmark T632 Laser Printer
T632 printer error : 34 short paper. What does that mean? Don't see 34 as a valid error code.
This error message means that the printer has determined that the length of the paper in the source specified on the second line of the display is too short to print the formatted data. For auto-size sensing trays, this error occurs if the guides are not in the correct position.
Please try to do the following
? Press Go to clear the message and continue printing. The printer does not automatically reprint the page that prompted the message.
? Make sure the Paper Size setting in the Paper Menu is correct for the size paper you are using. If MP Feeder Size is set to Universal, make sure your paper is large enough for the formatted data.
? Press Menu to open the Job Menu and cancel the current job. Please see also the media guidelines on the user manual p.29
For further assistance, please contact Lexmark Technical Support.
Aug 02, 2011 | Lexmark T632 Laser Printer
How to clear the Lexmark T632 maintenance counter
on power up press and hold go and return buttons. When registration menu appears, scroll to printer setup hit select scroll to page count hit select reset counter to 00000
Feb 09, 2011 | Lexmark T630 Laser Printer
Prints on my Lexmark T632 have a dark line running from leading to trailing edge of the paper. Toner cartridge replaced but didn't help. Lots of toner scattered through out the printer.
Great job on replacing the toner cartridge. Most probably problem's on the fuser or the charge roll. They may need to be replaced. But also check maintenance count to see if you have already reached the 300,000 prints. It affects the print quality when you have reached the limit.
Jun 24, 2010 | Lexmark T632 Laser Printer
With my lexmark t632 the pages are printing with toner all over and I need to clean it but how do I go about that?
Hi. Try this. Remove the cartridge and use a lint free cloth to wipe it clean, should issue persists it could be something else causing it .. most likely the photoconductor, worst case if fuser. Hope this helps.
Mar 12, 2010 | Lexmark T632 Laser Printer
I have reset the page count and it still shows 300,000 copies the fuser was replaced twice
There are two types of counters one is the permanent page counter and other is the Maintenance Page Counter this one is the one that needs to be reset. If you are trying to erase the permanent page count that can not be done.
Feb 04, 2010 | Lexmark T632 Laser Printer
T632 lexmark getting dirt on printed pages
Hi Krimlakh,
Try replacing the toner cartridge first. Usually when this happens the waste hopper of the toner cartridge is full and start to leak on to the page.
Rgds
S88
Dec 18, 2008 | Lexmark T632 Laser Printer
Print head replacement lexmark t632
You will have to remove the top cover, both side covers and the rear door and redrive to get to it. Once these covers are removed you will need to remove three screws to release the printhead and disconnect a couple of cables.
I usually have to clip a couple of zip ties and use needle nosed pliers to get the cables out.
It is do-able if you are patient.
Nov 24, 2008 | Lexmark T632 Laser Printer
Lexmark T632 Laser Printer Logo
211 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
