Question about Seagate 160GB 3.5" External USB Drive 160 GB Hard Drive
My external hdd segate 160 gb sata not show in setup. its only some sound inside 'cut-cut'
  • Seagate Master
  • 32,281 Answers
Try connecting this USB hard drive to another computer.
The clicking sound is known as the "click of death" the read write head is banging back and forth and is a sign the hard drive is faulty.
Posted on May 19, 2011
Can't setup OS in SATA HDD in Intel d945gccr
Hi.
XP will not install until you go into the BIOS and find the menu page (probably by moving across the top level of tabs) where the SATA hard drives are configured. On that page you will see the ports and at least one, maybe all, will be Enabled. Close to that will be the port mode, usually setable individually for each port. Choices may include IDE (or PATA) Emulation, SATA, AHCI. Set your port to IDE emulation. Now look at the bottom for the key to Save and Exit - often the F10 key, press that key and select OK, the computer will restart and you should now be able to install Windows XP without any problems.
To get into the BIOS you have to press the Del or Esc key when you first turn the computer on.
Regards.
Feb 04, 2013 | Intel D945GCCR Motherboard
CUHD80U2E-72 external hard drive not recognized
If the HDD in the case isn't damaged, you can remove it and use a USB 2.0 to IDE/SATA Cable. Take a Look at this : http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276554
Jan 26, 2013 | CompUSA 80 Gb Hard Driveexternalusb...
Shows up as "Initio Combo Device Class" not a "Disk Drive"
RESOLVED the ISSUE...!!
Hi, Yesterday I get into similar problem of having my USB Drive ( WD passport Elite 320gb ) not being detected by my PC and as soon as I connect to it, Initio Combo device class drivers gets loaded and Drive do not show up in the device list...!!
I tried several options.1. Freezed my hard drive for 12 hrs in the freezer. It did not help me today.2. I have opened the USB drive shell ( becareful, I have damaged it.. see the instructions before you try t ). You can find the 2.5' HDD inside and there will be SATA to USB bridge adapter. I was having doubt on this bridge unit as I read through several blogs.3. luckily I have a unused 2.5' Laptop HDD. So I have removed this bridge unit carefully and tried to connect to my HDD. If the bridge is good, my HDD must be detected right away..But it is the same problem.. It did not work.. Hence I have confirmed that it is the bridge problem..
4. I bought a Rs. 250/- ( 5$ ) 2.5 SATA casing that is available in the market to use the 2.5' SATA HDD through USB. ( actually I do not know where I can buy only the bridge..hence bought the entire unit..which is still cheaper )
5. From the new unit, I have the USB to SATA bridge, which I have connected to my WD HDD SATA USB hard drive... Bingo.........It is detected by OS and I have started copying my important data immediately...
6. This Unit comes with a casing ..hence you may continue using this case... But some units may not fit well..still the bridge is usable..!!
I GOT all my data..with just Rs.250/- ( $5 ) ..I am happy to try this on my own..!!
Good luck with your drive..!!
Jan 01, 2012 | Western Digital My Book Essential 500GB...
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
I suggest to review a few points detailed as under: -
- K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
- Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
- Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
- Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
- Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Jan 27, 2011 | ASUS K8V-MX Motherboard
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very...
You can get free online remote Support by mailing this problem to googolplexcorporation@gmail.com .
This may be due to two problems
1. Due to Virus
2. Due to Insufficient RAM .
You can mail for free remote Support for Viruses
Hard disk upgrade
I faced the same problem i asked to the ibm people they said that non ibm hdd's are not supporting x3400 servers and they are hanging when we work with non ibm hdds. when I use segate 1 TB sata hard disk the server working fine the only problem is little bit slow for booting and programme running, this not a broblem. so pls use 1 TB sata hdds with your x3400 servers.
Jan 15, 2010 | IBM x3400 Server
How Find out Segate 160 gb HDD Warrenty
you can find it by serial no of HDD. You can call in segate service center & provide the serial no to them.
Dec 18, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
Segate FreeAgent 750GB external hard drive
my iqube extenal hard drive is not working was dropd down, I have tryed plag and play and it shows the light and fun inside working and when you staart uyou can ear like its start but stops after few seconds
Oct 15, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Seagate 160GB 3.5" External USB Drive 160 GB Hard Drive Logo
107 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
