Question about Kenwood Sirius KDC-MP819 CD Player
I have remote RC 505 -- I'm new user - unit went into protect mode and it doesn't respond to remote. With unit face closed I don't know where to find model designation to see correct model. It has CD and Sirius capabilities.
  • linda_reeve May 19, 2011
    I'm feeling that this is a case of operator (me) error. I'm hoping there's a simple way out of it.
  • 675 Answers
If the unit is in protect mode then there may be the possibility that the speaker wires may have a short circuit in them or that the amplifier section may be damaged....you can remove the radio from it's sleeve and check the wiring behind the unit...this also would have to be done to see the model number and serial number...it should be on either the top or bottom of the unit...the speaker wires for this unit are the white, gray, green, and violet...each with another of the same color but has a black stripe in it...the black stripe is the negative side of the speaker wire....you can disconnect these wires, then turn on the unit to see if it comes out of protect mode...if it does, then there is either a bad wire somewhere in the car or a bad speaker...if the unit stays in the protect mode, then you will have to take the unit in for repair, as this indicates a circuit failure
Posted on May 19, 2011
Rc-9 remote only works if within 2 feet of bose lifestyle 12
Replace its infrared emission LED. It is weak, and so the signal out from the remote control too.
Nov 18, 2012 | Bose RC-18S Remote Control
Remote rc 1030
it must be your remote has been broken (just like my remote on tv) better to buy a new remote or buy a universal remote control.
thank you for using fixya
CHARCOIS
Oct 31, 2008 | Denon AVR-2807 Receiver
Canon RC-1 remote
The Rebel XT must be put in Remote Control mode for it to work:
Feb 22, 2008 | Canon RC-1 Remote Control
I previously owned a Harmon/Kardon and used a sensor that was placed on the front face of the receiver as a signal to use the remote control in the downstairs living area. I don't know where to put...
It's impossible to tell from here if your sensor is even compatible with the new Denon but if you look at the manual you will find mention of RC-616 and RC-617 on page 19; and a REMOTE CONTROL IN on the back of the unit.
Sep 20, 2011 | Denon AVR-1907 Receiver
Can't turn on and off without manually going to unit. Have remote rc18sr. System still rocks, however went online to try for a new remote, i guess this is obsolete.
Marantz RC18SR Remote Control RC-18SR
Item condition: Used
Time left: 21h 0m 48s (Feb 17, 201111:51:43 PST)
http://cgi.ebay.com/Marantz-RC18SR-Remote-Control-RC-18SR-/180627142815?pt=LH_DefaultDomain_0&hash=item2a0e37789f
Marantz RC18SR Remote Control RC-18SR Item condition: Used Time left: 21h 0m 48s (Feb 17, 201111:51:43 PST)
Feb 16, 2011 | Marantz AV-560 Receiver
Airwell Spilt Level system does not respond to use of remote and can only be operated by manually switching on and off.
When you press a button on the RC, does a arrow appear in the top right corner of the RC?
Jun 06, 2010 | Heating & Cooling
Hi, My philips 42'' plasma won't turn ON. I went to turn it on and the ''on'' button flashes red 7 times 4 seconds apart
I just had the same problem. I downloaded a service manual and give this a try http://www.servicemanuals.net . Turn on your TV and with the remote do the following Key in the code “123654” via the standard RC transmitter. This get you into a customer service mode and you can check your error codes.
After I got out this mode my TV worked. I think the TV was stuck in protection mode for some reason and by entering the service menu's it reset it.
I then entered the SAM Mode
How to Activate SAM
Via a standard RC transmitter: key in the code “062596”
directly followed by the “INFO” button. After activating SAM
with this method a service warning will appear on the screen,
you can continue by pressing the red button on the RC.
It will give you more info.
The TV worked fine after I exited these menu's.
I also did a software update as per the user manual and the TV seems to be working fine again.
Hope this helps
Sep 09, 2009 | Philips 42PF9631D 42 in. Plasma Television
My beko tv has a system setting on BG. I need to change it to L but it won't change. How do I change the system setting?
I need the same solution. My own system is setted up to 'I' and I want to change it to 'BG' but it doesn't work.
Jul 18, 2009 | Beko 142746 TV
Remote control problem
The IR sencore is bad. you probebly let something run down the screen when you cleaned it.
Feb 21, 2008 | Televison & Video
Kenwood Sirius KDC-MP819 CD Player Logo
109 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
