Question about Patton SmartNode 4960 T1/E1/PRI VoIP IAD - 24 Channels Router (SN49604E24)
I have a couple of problems: 1) I am unable to connect to my smartnode 4960 via a webbrowser, however able to connect via telnet. I am unfamiliar with the commands etc, hence i would like to connect through the web browser. 2) this is the reason why I need to connect to the smartnonde. Current setup: Smartnode 4960 connected to network with SIPxFoundry PBX system in place. I would like to use the function of Autoattendant (AA) to attend to all incoming calls. I have configured the AA within the PBX system, and internally, this all works fine. Now when I push all calls from external to the AA, the calls are just dropped. I am thinking this is a codec problem, and would like to check which codecs are enabled on the smartnode. If you possibly could assist in helping me find a solution, this would be greatly appreciated! Kind regards Cliff
Web interface won't responde, but I can connect via Telnet
many routers are not compatible with Firefox or Chrome... have you tried using IE?
Jan 16, 2014 | NetGear FVS124G Router (FVS124GGE)
Belkin N300 - CISCO Clean Access Agent
All configuration can be done with the router GUI.
Firewalls: Server Side Having a server side firewall is the typical configuration on many systems. There is only one method for doing this, whether you use telnet or ssh: map a port to be forwarded to the server in the firewall router. It is not advised that you use telnet from the Internet for security reasons; that is usually why you have a firewall.Decide which method of connectivity will be allowed, and determine what port you will use to forward to this service. If there is only one server involved, you can use port 22 for ssh or 23 for telnet and forward them straight through to the server. But if there are several servers involved and they do not have public IP addresses, you will need to pick different ports on the firewall router and let the router forward those ports to the different internal servers.
Mar 01, 2013 | Belkin Surf N300 Wireless N Router
Access denied
yes, you should be able to connect to the console port using a roll-over cable RJ45-DB9, connect using hyper terminal or similar using the com port settings 9600,8,N,1
You can then configure the switch from the CLI...
Have you set the 'Login' command on the VTY lines in the switch setup and an IP address on the management VLAN to connect to.
You also HAVE to have a password enabled on the vty lines in order to connect via telnet.
hope this helps.
May 09, 2012 | Cisco Catalyst 2960-24PC-S Ethernet Switch...
Where is the password located at
Hey, the Netopia routers do not have a default username and password. If a password is already set up, you might need to reset the router.
In order to log into the router you need to Telnet into it.
If you are using Windows XP, you can start Telnet from Start>Accessories>Communications>Telnet
if you are using Windows Vista or Windows 7, Telnet is not enabled by default. You need to enable it first. You can quickly re-enable Telnet by following these steps:
Start
Control Panel
Programs And Features
Turn Windows features on or off
Check Telnet Client
Hit OK
After that you can start Telnet via Command Prompt. (or the Start menu)
then once you get into the Telnet Console, type in:
192.168.1.1
and the router interface will open up and let you chanfge settings.
[CLICK HERE] for the official Guide by Netopia.
Sep 23, 2011 | Netopia (3347NWG-ENT) Router (3347NWGENT)
After making changes in the config via telent the router hangs, this does not happen when the serial interface is used
Did you do anything that would affect the traffic between the computer you were using and the interface that you were telnetting too? For example If you changed the IP address or password from the Fa0/0 and you were telnetting to that router, the connection would look like its hanging, but would be disconnected.
Mar 28, 2011 | Computers & Internet
How can i communicate from my pc to the ups on the 9 pin serial connection
Taken from the MGE UPS SYSTEMS, Network Management Card Installation manual (34003641EN/AD)
Run Hyper Terminal on a PC running Windows (9x, Me, NT4.0, 2000 or
higher).
Connect the card to the PC using the cable supplied.
Set up the terminal with the following communication parameters:
9600 bauds. 8 data bits.
1 stop bit. no parity.
no flow control.
ASCII: "echo typed characters locally" option disabled.
Press the Carriage return key. The configuration menu is displayed.
Enter the password (MGEUPS by default).
The main menu is displayed.
Select one of the items in the configuration menu.
Via the serial link or Telnet
Select the "Agent configuration" command by entering 1.
Select the item numbers and modify all the IP parameters (address, mask, gateway).
Once all the modifications have been made, exit following the instructions on the screen.
Restarting the card Via the serial link or Telnet
Select the "Restart agent" command by entering 6.
Then follow the instructions on the screen.
Restoring the default parameters Via Telnet or Hyper Terminal
Select the "Reset configuration to default" command by entering 5.
Nov 05, 2010 | MGE UPS Galaxy 3000 UPS System
Cannot log in to the router via telnet.
Typically you cant telnet into these routers, You can only get to them via a web browser
Jan 23, 2010 | D-Link Computers & Internet
Adtran Telnet
Are you getting any failure msgs? Where are you telnetting from? Has your router been restarted? If you have web access turned on the router, you might be able to login via your browser, or you could directly connect to your router via a console cable to check your configuration.
Jun 23, 2009 | Adtran Total Access 850 Router...
Locked out of HTTP inside port on SG300 - telnet works
I was unable to supply a link to the manual for this product so I downloaded it to one of my sites to make it available to you. Here is the link:
http://www.dscmain.com/snaplink/sg_314_ug_revA.pdf
Please let me know if this helps...
Tim
Mar 23, 2009 | SG300 (SG0126US) Firewall
The smartnode Patton
Looks simple to me. Try it again and follow the steps carefully.
Mar 18, 2017 | Atto Computers & Internet
Patton SmartNode 4960 T1/E1/PRI VoIP IAD - 24 Channels Router (SN49604E24) Logo
44 people viewed this question
Top Patton Computers & Internet Experts
David Payne
David Payne
Are you a Patton Computer and Internet Expert? Answer questions, earn points and help others
