Question about Viking Kitchen Ranges
Downdraft fan won't operate - model VPIV 1600
Whirlpool SC8720EDB cooktop stove independent vent switch is not starting downdraft exhaust fan, but the exhaust fan works fine when left side burners were turned on
Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
Aug 02, 2017 | Whirlpool Cooktops
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Jenn air downdraft fan 2e speed doesn't work
Probably the switch or a burnt out resistor.
Mar 18, 2014 | Cooktops
No gas on viking professional. ignitor works downdraft does not
There are solenoids that turn the gas on to a burner. If they're bad it won't supply gas to the burner. There is also a mother board on that model that could also be the problem. When it comes to this brand it's difficult to diagnose without being there. If the downdraft is not working then I would guess that the mother board could be the problem...sorry I couldn't help more.
Aug 27, 2011 | Viking 37 in. VGSU163-6B Gas Cooktop
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
JVB37H1BB downdraft ventilation system stuck
Folks, I have experienced the same problem several times - in all of my cases the problem was solved by simply opening the back panel and taking out the motor assembly and re-aligning it. Check out this URL for a blow up of what's inside and parts list - http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130126
The problem is that the arm tends to slip out and therefore won't raise or lower the hood anymore. Be careful when aligning it can be a little tricky - carefully observe the how the motor works outside of the housing via the switch and you will get the idea.
Jul 26, 2010 | GE Profile JVB67HWW 36" Telescopic...
After using the broiler a sound like a fan starts
This is a cooling fan. Normal operation.
Jun 05, 2010 | Kitchen Ranges
CFM's pushed out by blower for jennair S176W range
hi there,
initially downdraft ranges from 6oo CFm to 1600 CFM within the pushbutton control.
CFM means (cubic feet of evacuated air per minute)
Hope this initial info/idea helps.
Let me know for further clarifications,
Jun 04, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Fan has difficulty turning, buzzes
Hi
Tha model is a Maytag.
There are a few things to check here, and it's best always to use the proces of elimination.
These are the things you need to check:
1.MOTOR, DOWNDRAFT
2.BLOWER ASSEMBLY
3.SCROLL, BLOWER ASSY.
4.CORD, POWER (MOTOR)
as you mention before sometime run and sometimes do not run.
youll have to start by checking those items and make sure they are not damage or obstructed. I have some wiring diagrams for that model, if you would like for me to email them to you, please let me know.
I hope that will help you
Eddie Rentas
Tupper Lake NY
Jun 22, 2008 | Jenn-Air JED8430 Electric Cooktop
GE Profile Telescopic Downdraft JVB37HBB
mine just did this this morning..a few months ago the button to make it pop up stopped woring so i just started using the wires to operate it...this morning it got stuck uo...i took off the electrical cover and found a burnmark on my circut board...it seems a diode fried or something...im still looking for a replacement
Jun 08, 2008 | GE Profile JVB67HWW 36" Telescopic...
Kitchen Ranges Logo
133 people viewed this question
Top Viking Kitchen Ranges Experts
wrtsjr
Level 1 Expert
Ismael Rodriguez...
Steve Allison
Steve Allison
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
