My computer was knocked forward it went bang and then smelt of burning - I have been told that it might be the internal powe pack can you help?
  • 32,281 Answers
If your desktop computer went bang from the back of the computer and the burnt smell comes from the fan grill of the power supply then the switch mode power supply definitely failed. The bang and burning smell was probably one or more of the capacitors that has exploded inside the power supply.
You can replace the switch mode power supply, make sure you purchase one that has the same total wattage or higher wattage.
There is a chance that when the power supply failed it may have caused a voltage spike that could have damaged some other components. You won't know until you replace the faulty power supply.
Posted on May 19, 2011
Will not start
It seems that something was burned out trying to make the starter turn. The problem could be the starter and/or the solenoid.
Go to youtube and enter, "how to check a starter" you may have to remove it to check it. I could tell you how. But it is better if you see how it's done for yourself. Also check the fuses.
Mar 21, 2014 | 1987 Chevrolet Corvette
Smoke washing machine drum
the motor might have burned out have a tech t check this out
Jan 27, 2014 | Bosch Washing Machines
Not firing on number 7
sounds like it could be a burn plug wire on the number 7 plug
Dec 16, 2012 | 2000 Cadillac DeVille
I have a front load washer by Kleenmaid KFL800. I heard a bang and then smelt burning so I think it has blown up but I can't get my washing out cause the door will not open. Can anybody please hel
As a general rule if you unplug from the mains power the solenoid that keeps the door locked will de energise and the door will be able to be opened but careful there could be plenty of water waiting to help wash your feet!
Jan 26, 2012 | Ariston Technologies Ovens
I noticed a burning rubber smell from the drivers side front of the car today, i had only driven a few miles and its the first time ive smelt this, however possibley connected? or not? for the last month...
You may have lost some support on the silencer (muffler)
Some are like a rubber doughnut which might possibly account for the burning rubber smell if its coming into contact with the hot exhaust.
The banging noise is possibly the loose silencer flexing as you pull away.and coming into contact with the bodywork
Need to get the car on a ramp for confirmation
Oct 13, 2017 | 2002 Jaguar X-Type
My power switch has burnt out.
It is more than likely NOT the switch that has been destroyed. I am quite sure the switch could handle 1A without burning out.  What has more likely happened is you have damaged  some internal components. You will not be able to tell which ones by their appearance alone.  Is there a fuse on the board? check to see if that has blown.
Apr 02, 2009 | Vestax Pmc06proa Thin DJ Scratch Mixer...
Lexmark x6170 went bang ?
A bang and a burning smell on any electronic equipment means you need to place the device in a bin and got out and buy a new one ......
Jan 21, 2009 | Lexmark X6170 All-In-One InkJet Printer
No Picture on Wharfedale tv
Appreciate the direct "Ask Me".
Your son's description of "...bang and smelt hot..." could indicate a number of possibilities:
  • power supply section;
  • vertical section;
  • horizontal section .
Since it has still sound, then the power supply is a least likely possibility. The "...bang and smelt hot..." is also significant. It tells us that we can visually check which component burst and burned by opening the rear of the unit for a look and see. Further diagnosis would of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 26, 2008 | Televison & Video
Left side don't play/ right side is perfect
You sound like you have a wire connection problem but to find out try using a spare pair of speakers or try headphones. Try to rule out any wierd system problem, but I don't think that is your problem. Since this problem went away and then came back reduces the likely hood that it is a power issue so I would go with wiring issues or connection problems. While you are playing music. Move the cable, bend it, and reinsert it a few times. Give the cable a work out. If it comes back while this is happening, you have an open connection. You will need to replace the speaker wiring.
Sep 08, 2007 | Harman Kardon SoundSticks II Computer...
Computers & Internet Logo
David Payne
David Payne
