Question about Epson Stylus CX7800 All-In-One InkJet Printer
35mm scan not in focus
I can not get the scans to be in focus. I tried Auto, Home and Pro mode with no luck.
I had same problem. Slides were all slightly out of focus. My solution was to raise slide slightly from scan bed, and this would significantly improve focus. I used 1 to 3 thin (about 1mm) cardboard templates cut to the shape of slide and placed underneath. Not the ideal solution, but did work.
Posted on Aug 29, 2008
  • 876 Answers
You need to uninstall and do a clean install of the drivers (software). If you do not have the CD you can download the driver here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58773&infoType=Overview
Be sure that when you download a new driver and install it, that you turn off all running programs including your virus/security control. You can turn it right back on when the drivers are installed and you restart the computer. Good Luck.
Posted on Aug 14, 2008
I am trying to scan slides withan epson v300 photo. I get good quality but I don't get the whole slide. Is there a setting I need to change somewhere?
its possible you may not be using the slide adapter properly, try turning it around.
also, try turning off the auto crop feature or something like that in your scanning, you also may want to you pro mode instead of auto or home
Aug 11, 2010 | Epson Perfection V700 PHOTO Flatbed...
How to scan slides with Visioneer 9520 USB Scanner - it scans who
I have successfully used my Visioneer 9520 to scan 35mm slides, and they came out perfect. To do this, in my image editing software, I select File/Import/Acquire/Visioneer ScanManger Pro. This opens the VIsioneer scan manager window, where I select "Scan 35mm using:" and then I choose the desired scanning configuration, e.g., "35mm Better, 35mm Best, Custom" etc. See image below.
BTW: After several moves, I have lost my 35mm scanning template. Do you know where I can get another one, or do you know someone who could actually scan theirs and email the image to me? I could then create a duplicate from heavy black construction paper or card stock.
Jul 26, 2009 | Visioneer OneTouch 9520 Flatbed Scanner
Epson V100 Document Mat error
Please check if the option cable connected on the back of the scanner is seated properly.
If you are using epson scan to scan from your computer, try to scan using either professional or home mode and choose the correct settings.
May 03, 2009 | Office Equipment & Supplies
Epson 4490: where'd my "film" option go?
Make sure the lid is plugged in. There is a cord on the back of the lid that plugs into the back of the scanner body.
Feb 13, 2009 | Epson Perfection 4490 Office Flatbed...
Ford focus st on a 52 plate
Tony-
Sounds like the computer engine management has gone to bypass/limp mode (i.e.: it isn't doing anything other than providing the very basics for the engine to run [poorly!]).
You need to have the car scanned to determine which trouble code(s) have been set and hopefully point you in the direction of the cause.
The good news is that some of the larger auto parts suppliers now offer free diagnostic scanning, so get on the telephone and try and locate one of these, get it scanned, and go from there.
Hope this helps, good luck, and keep us posted!
-WB
Jun 09, 2008 | 2002 Ford SVT Focus
Nikon N55 Won't take picture in Auto Focus Mode?
There was a recall on the N55 due to auto focus problems. You can do a google search or nikon.com email the support team and they will send you the paper. This is what I did, I wasn't charged since I had the correct papers. I, however, used one roll of film and my focus went out again! Mine doesn't even work on manual... If you want to try that maybe you will hae better luck than me. GOOD LUCK!
Apr 28, 2008 | Nikon N55 35mm SLR Camera
Minolta Maxxum 7000i
Is there a micro focus switch on the lens
On my lens if switch to Micro Mode the Auto focus is disabled, Also it is a stupid question but you are using a AF lens and not a xi series or manual focus lens.
Sep 28, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Epson perfection 4990 photo scanner
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
Auto+manual focus ranges on the 850Z
The focus information is available at: http://www.ssdonline.com/... ...m?Productid=B111021F&affid=A01&urlid=B111021F
Sep 13, 2005 | Epson PhotoPC 850Z Digital Camera
Epson Stylus CX7800 All-In-One InkJet Printer Logo
266 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
