Question about HP ProLiant ML350 G6 (487932001) Server
I just plugged in a second harddisk in my HP Proliant ML350 G6 but the server cant find the drive?
  • toni76ab May 19, 2011
    Umm, but there are no jumpers, i thougth about that it i need to set it up A's a slave.
    But i Got no jumpers to set it up A's a slave.
    The harddisk only fits i to this server, so i Cant format it when i dant see the drive.
    Hi, i have contacted HP and got a utility to enable the drive from windows.
    I wil try that out later.
    President:
  • 1,961 Answers
Make sure you select the jumper on the hard disk into a slave setting and the hard disk is formatted into windows format.check the jumper settings first and post back for further suggestion.
Posted on May 19, 2011
  • Danilo Baraquiel
    Danilo Baraquiel May 19, 2011
    hello what operating system you are using?If it windows then you can try to detect the hardware by manually detect the hardware using the add hardware option.to do this click the start button then select the control panel then click the add hardware.then follow the instruction from the wizard.
    If your hard disk is not new,try using another computer then detached the hard disk installed.connect the hard disk you want to reformat/use.booth the system and see if the mother board can detect your hard disk...format the hard disk then it is now ready to use...If the motherboard did not detect the disk,the disk is defective and cannot be use..
  • Danilo Baraquiel
    Ok!
    Just let me know how it goes..
I have an HP ProLiant dual quad core ml350 how do I find out what generation it is
The HP ProLiant ML350 G6 6th generation
you can visit www.hp.com
Feb 05, 2016 | HP Computers & Internet
I have a hp proliant ml350 g6 but i can not hear any sound there is no where, where i can connect external speakers to what should i do
Most servers don't come with a sound card. There is no use for them in a work environment. You would have use an add-on card.
Jan 26, 2013 | HP ProLiant ML350 G6 (487932001) Server
Cant get any sound from my g6
Hello you can download the drivers here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3884316&lang=en&cc=us&prodTypeId=15351&prodSeriesId=3884315&taskId=135
By selecting your current operating system.
But here seems to be no drives for the sound.
Good luck
I have a HP Proliant ML350 G6 running MS Small Bus. Server 2008. It will freeze up 3-5 times a week which holds up work loads. What might be the cause of it freezing up so often? Thanks,
HEAT, is a big factor. That is a mighty Xeon Server Quad Core CPU and when it gets to work it gives off heat.
You need to make sure that the chassis is well ventilated, install some fans to keep it cool. Clean the heatsink and surrounds of dust. Use a vacuum cleaner.
Also scan the system for Malware and Virues, these pieces of code simply get the computer to do a whole lot of nothing usefull to you. Find them and delete them. Usually a good cleaning will get it operating efficiently and effectively, giving you a responsive and productive computer system.
Take care!
damnor01
Jun 10, 2011 | HP ProLiant ML350 G6 Xeon L5506 Quad Core...
How to install hdd in pro liant 150 G6 as i got it without hdd and i can't find out how to install it in the blank ? thanks
HP Proliant 150 G6 has a hot-swappable harddisk cage in the front. Open the front cover and you will be able to slot in the hot-swappable hard drive.
Jun 13, 2010 | HP ProLiant ML150 G2 Server
I can´t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
HP ProLiant ML350 G6 (487932001) Server Logo
355 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
