I need a manual for a Zanussi Turbodry WDT 1072
    Brigadier General:
  • 6,277 Answers
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on May 19, 2011
I need manuals for zanussi turbodry zww 1202
Go to
http://www.manualslib.com
Then type in the manual you need..
Hope this helps
Ellen
Feb 04, 2015 | Zanussi Washing Machines
Zanussi turbodry wdt 1075 washing machine fills & drains but does not perform wash cycles or spin cycles drum does not rotate
Quite probably the motor brushes. Disconnect from mains. Tilt machine backwards as far as possible. On motor, disconnect wires to brushes. With a multimeter, check continuity between brush and any segment if the commutator. If open circuit, replacing the brushes should do the trick. Also visually examine the commutator for damage
Aug 17, 2014 | Zanussi Washing Machines
My zanussi WDT1072 does not spin the clothes dry any more. What could be the causes?
Check the drive for friction, it must move freely with your hand movement. If not it is possible that the bearing or accumulation of dirt has caused this to happen which can result in LOW RPM and thus the speed is less for drying .
Click On : Bearings
Jan 23, 2013 | Zanussi Washing Machines
Where can I find a manual?
You may view/download the manual here.
Mar 14, 2012 | Zanussi Washing Machines
Zanussi jetsystem turbodry 1200 door wont open
its the doorcatch,turn power off, remove lid and put hand in machine where doorlock is situated feel about and try open catch, repair or replace?
Jun 24, 2009 | Zanussi ZWF1420W Front Load Washer
Washing Machine trips circuit breaker when Drying
This will be the dryer heating element needs replacing.
Hope this helps.
Jan 21, 2009 | Zanussi WDA1055W Front Load Washer / Dryer
What is E 40 on Zanussi Turbodry 1200?
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board
Nov 24, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi Turbodry 1200 spin problem
if this washer is used alot then it will more then likely be the carbon brushes which u will need to take the lid off undue 4screws out where it joins front to the back screws at the back to the bottom and 1screw either side of the bottom where the panels join together behind a little cap which will have an hole in the middle of it to get it out u will then be able to get to the motor to replace the carbon brushes
Nov 22, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanussi WJS 1397W
possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Jul 11, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
