Question about LG LHT854 Theater System
I'm seeing a code "WL
I'm seeing a code "WL - MIC I" and "MIC OUT" intermittantly and it's breifly interrupting playback from Aux Audio and while DVD is playing. Everything else works fine, Any ideas?
  • erlandlunde
    erlandlunde Mar 03, 2012
    Did you fina a solution?
I have the same problem with an LG HT 305SU and i don't know how to solve this problem, any help please?
Posted on May 25, 2011
WL MIC I and MIC OUT code
Are you seeing this code displayed on the front panel of the reciever? Are you trying to use a microphone? Is this error causing your receiver to malfunction?
Oct 17, 2013 | LG Audio Players & Recorders
Tip
Set up, volume, and manual issues
I got my EAKAR100 for $5 at a second hand/thrift store. Kind of expected it would just work or not. 'Nuf said. But after having no luck with the set-up, I took a long second look. Here's what I discovered:
The manual is VERY minimal... if you don't have one, don't waste much time looking for one.
What I did wrong: The microphone has one wire that splits into TWO leads, each having 3 RCA plugs (Video & L/R Audio plugs... also a 3rd "pigtail" lead that is for an optional extra microphone for duets). Although the two main leads were clearly labeled, I had put the one for the TV input socket, into the DVD output (and of course the other lead was plugged in wrong, too). Oddly enough, this DID produce music AND lyrics from the DVD player; but I had no sound from me, singing into the mic. My excuse for this obvious error is the manual had a diagram for installation that showed the SHORTER of the two leads going to the TV. It doesn't. Luckily mine had blue tape labels on the leads. I switched them and though I continued to get music and lyrics, alas: still no microphone. (I tried new battery, and yes, the red "power" light lit up on the mic.)
Up until now, the music had been playing at a reasonable volume, but I then tried my mic w/o the music plugged in. As I began talking ever louder into the mic, I thought I could hear it on the TV, so I cranked up the TV volume from 11, up to 26; and suddenly the mic was delivering my vocals out the TV speakers. I would not have learned this w/o unpluging the DVD, because if I hadn't, I would never have cranked up the TV volume high enough to hear the mic.
The microphone's own volume control was minimal (almost imperceptible; low to high), but there were clearly 3 functional reverb-settings, controlled by the other button on the mic.
I re-attached the plugs at the DVD player and selected a tune. I had music, lyrics, and my voice, with some distortion depending on my volume, and the TV's, and distance from my mouth to the mic, but it was manageable.
However! the balance between the volume of my mic, and the music from the DVD was such that I was being drowned out by the music. I could find (via manual, online Electrohome website, my little brain's theories) NO way to adjust the BALANCE between these two sound sources.
As for the DVD menu, and song selection: The music arrangements are awful. VERY disco-style, even for the Christmas Carols!! The kids songs are bad too, but not as tacky. My DVD player is old, and teeny (the TV by the way, is a pretty new Vizio VL320L), and the DVD remote is very obscure in its button assignments and descriptions --- even with DVD movies. But maybe the Karaoke disc is awkward in itself, too. So, getting from the menu, to a particular song was haphazard at best. What worked best was pressing "Go To" on my DVD remote. That produced a header that read: "01/30 ... 1/1", which turned out to mean "song #1 of 30 songs; [and] folder #1 or 1 folders". By highlighting the song number field, using the left/right arrow buttons, and then entering a number "24/30" for example, and then pressing "OK" , the song would start up. My DVD's "pause" button worked, but many other buttons did nothing except cause a hand-icon (like the hand in a crosswalk light) to show I should "stop".
Sorry to be so long winded, but I don't know what small comment might be of help to any of you. I, myself, was groping through the dark all the way. Good luck.
on Mar 13, 2014 | Electrohome EAKAR100 All-in-One Handheld...
External microphone thinkpad t41
Control Panel, Sounds, look at Recording devices (depends on the OS you are using, you didn't mention, Vista, XP, 7,8?), Mic. Your Headphones jack, when in use, will cause the internal sound to disable, depending on OS the mic setup is a bit different but you should find it in sounds, recording devices.
Nov 12, 2012 | IBM ThinkPad T41 2373 Notebook
Sharp ar-164 - Displays "h4"
this error means:
heat roller abnormally low temperature.
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 25, 2012 | Sharp AR-164 Copier
2000 jeep wrangler won't start, good crank, no bus
Check fuses first, but could be needs new CPU
Jun 14, 2012 | 2000 Jeep Wrangler
Why won't wireless mic turn on the "Ready" light on receiver?
Make certain the mic and the receiver are in the same exact frequency band. There are stickers on both products that list the frequency band.
Apr 27, 2012 | Shure UT2 / 58 / PG58 Professional...
Hi, I recently reformatted my hard drive and installed Windows 7. Before that, I had windows vista and my mic worked fine. Now, windows 7 picks up the mic and says it's enabled and it's not muted,...
Check the web-site of the manufacturer of the computer (and the motherboard) to see if they have updated device-drivers for Windows 7.
Are you sure that you've plugged the microphone into the 'pink' ("microphone-in") socket?
Open the "sound-mixer" application, and check that the "microphone-in" is not muted,
and that the slider is pushed to the maximum level.
Try a different microphone.
Jun 07, 2011 | Computers & Internet
I can hear other people but they cant hear me
If you can hear and you can't hear others, then it's clear that the problem is with the Microphone, you'll need to replace it or you'll need to get it repaired. Not just the mic, it's also possible that there's problem with circuit which interrupts the functionality of mic. This won't be a problem that you can do it yourself if you are not familiar with mobile repairing. You'll need to visit a service center or a mobile repair shop and get it fixed.
Let me know if you need further help.
Thanks for using FixYa.
May 26, 2011 | LG Cell Phones
LG LHT854 Theater System Logo
348 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
