I am having ONIDA OXYGEN THunder 29'. When DTH connection put into AV1 port sound, picture are OK but colour not coming. When put into AV2 (front panel) everything is OK. Please advise
4 Suggested Answers
kitt98
  • 26 Answers
SOURCE: AV1 AV2 hook up
you should find them by seeing if you can find ports that are colored yellow, red and white
Posted on Apr 01, 2010
SOURCE: onida ky oxygen thunder (DVMC) service menu code
how to go service mode with rc115/D
Posted on Jul 29, 2011
gopakumarg43
  • 74383 Answers
SOURCE: What is The Cost of
Hello
The cost of most of the 29 inch tVs will come between Rs400/= to Rs550/= OK
Posted on Sep 03, 2011
AV1 red, white and yellow cable ports not working. I use digital satellite service for my television through a box from my provider which only uses the AV1 port? I checked all the wires which were working...
Your post is a little confused (or I am!), why would a digital box only provide a low resolution output which is what the composite standard is - yellow video composite red/white=stereo audio.
You also say that you checked the wires, so you've seen the picture and heard the audio on AV2? So why not use AV2? There is no reason to use AV1 other than you may be using the other inputs for other equipment.
Check that the output from the cable box really is composite and not component, and if it really is composite check the AV colour system in the TV menu is set to Auto (or NTSC if you are in USA, PAL in Europe)
I think you (or I) may have misunderstood how to connect it, can you have a look at your cable box and see what the output sockets are labelled and report back/clarify also detail what your cable equipment is please?
thanks
May 17, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
My audio and my picture are on two different channels like i can see the movei on av1 but i cant hear it but if i turn to av2 i can hear it but not see it
sir, check the cable which is connects TV and DVD player Audio Video cable ... both should locate at AV1 port in TV and DVD... else AV2
Mar 04, 2011 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Hi there, I am getting some problem in connecting my DVD player to LCD TV on AV2 port. If I connect the same to AV1 port,it works fine but that port is already in use for my set top box so if I want to...
I expect if you look at the menu you will find that AV2 is set up as S-Video or Component etc. etc. Set it up as composite or RGB. The same as AV1.
Jan 20, 2011 | Televison & Video
AV1 AV2 hook up
Apr 01, 2010 | LG 42LC2D 42 in. LCD HDTV
When i turn the tv on i get sound but just a black screen
Try pressing the menu button on the remote to see if the menu comes up.
If it does it's possible the light and colour have been turned right down, find the option on the menu and turn it up.
Also check no cables are unplugged at the back of the tv, picture is usually yellow make sure it's in tight. Check other end as well so sky box or DVD player.
If you're using an AV port on your tv try using a different one, so switch form AV1 to AV2.
Jul 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
Problem of Audio in Philips TV, Model - 21RF VardanSL
check option bites find it on crt or back cover to enter serv mode coll following comands
062596 menu or display the data will appear select options and set by vol and ch keys
Jul 10, 2009 | Philips 32PW6506 32" TV
Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
Mar 20, 2009 | Sanyo DS13204 TV
DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Jan 11, 2009 | Sony DVP-NS330 DVD Player
AV1 / AV2 Connections don't work
No picture or dark picture
Check R516 (56Kohms, 0.5w) or R517 (27Kohms, 0.25w) for high
Will not come out of standby, no picture
If at power on voltage on pin 37 of the micro drops low then reverts to 5v suspect memory chip ICA07 (Toshiba 23319016)
No picture No sound
Faulty IC TDA6107q on crt board
No picture on e-e, I.F output ok
This was due to switching chip IC3901 (M51292FP) on the scart panel
Nov 26, 2007 | LG 32LX3DC 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
