Question about Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop
Jenn-Air Expressions cvgx2423b manual request
I have a Jenn-Air Expressions cvgx2423b model with the same problem of one burner not working and have reviewed the solutions and found the igniter part # 71002724. Now I need instructions for the DIY repair as a manual is now unavailable through the manufacturer. Any suggestions on where to get a manual or assembly instructions without using a technician?
Thanks
    New Friend:
I have a Jenn-Air Expressions cvgx2423b model. One of the knobs fro the burner is stuck in the middle and will not rotate to trun off. So I have to shut down the gas each time. Any body has an idea what is the problme
Posted on Dec 14, 2009
  • moradis Dec 14, 2009
I have the same model with the same problem. The replacement is simple. Remove the burner cap (no tools needed) Take a large crescent wrench and remove the large center nut holding the burner assembly in place. The ignitor will slide out of the assembly once it is removed. Good luck
Posted on Nov 08, 2008
SOURCE:
Suddenly my Jenn air gas cooktop ignitors (all of them) do not click and spark, the model is CVGX2423B. I suspect it might be spark module fails, is that right?
It sounds like you need a new spark module which controls all of the burners. It is part number W10475147. It costs around $115.00!
Sep 01, 2013 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Fisher and Paykel cooktop model # CE901 will not work at all. Went dead suddenly. All five burners dead. Electricity to the unit is tested and fine. Any ideas to trouble shoot?
Yes, it is the spark module. It needs to be replaced. Sometimes it's easy to reach and sometimes not. I am trying to get my hands on a Jenn AirJGD130ADB Repair Manual becasue I have the same problem.
Aug 12, 2013 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
How to remove the top panel of the cooktop?
To remove the top so that you can replace the electrodes, you just need to pull all the burner grates off and knobs. Then remove all the burner caps and rings off so that all you're left with is the cooktop and the burner bases. There are screws going into each burner base. Remove all the screws and the burner bases will pull up and off and then you can pull the top of the cooktop up and off.
Feb 13, 2013 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
3 of the 4 burners clicks and sparks when I try to
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jul 27, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
1 burner flares and sputters
Hello. Chances are that something on the stove boiled over or got poured into that burner. take it off, soak it overnight in water with dishsoap added, then rinse it and let it dry before reinstalling it. Repeat the soaking in soapy water if necessary until the flaring, sputtering and black soot is gone. regards, Joe
Dec 14, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Turn on one burner, second burnertrise to light
hi.gud day...tnx for question.im gerbee here in the phillipines, the problem of the the unit is have an dirt or water,& oil coz why the unit is not stoping cliking sound.the best thing to is clean the area were the problem it is,first unplug the unit & turn in off the gas line for the safety..get the vacium & bottle of thinner...first remove all the knobs of the control valve(make sure to remember how to remove the knobs coz if turn back as how you remove it). then drops some thinner located on valve switches(knobs position) 5-10ml,,,then put the vaccium in the place were u drop the thinner to suction the thinner,oil & some dirt.try 2 times for good result...after this if is not work n nid to call an expert tecnician to dismantle & clean the micro swicth one by one(no nid to replace the parts)
tnx gerbee
Sep 12, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-air ccg2520 burners will not ignite - no clicking- cn anyone help
check for power by pluging something else in, did it get somthing spilled in it, compressed air blown under knobs removed should doit or just wait for it to dry out are all the burners affected
Jul 01, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Jenn-Air Gas stovetop
try to clean the burner and then try it.
Sep 21, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-air CVGX2423
Is it clicking? No...bad switch. Yes...check ignitor gap on that burner. The gap or the wiring is bad if it doesn't work.
Jun 08, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air Gas Cooktop Model CVGX2423
you will need to contact your certified local service tech.you might have a distributor problem at yor ignitor box.if the problem is not with your ignitors.
Jun 30, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop Logo
767 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
MARLON KELLER
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
