Model RE44SZ21D when I switch TV on it maks a whinning sound like a hard drive not reading properly and switches back into standby. Sometimes it will start, (normally if not tried for sometime) stays on for about 15 mins then switches itself off again???
  • 5 Answers
Hello john.
this is a late suggestion,but if you still have the set & the proplem
in existence.
then i suggest you check with the lamp---situated on the right hand
side ,two screws to undo--once in further two screws--pull back the
casing clean with a dry cotton cloth & with that clean the cooling
fan just adjasent to the case.+ remember to leave the tv on standby mode for 3 minutes before you completely switch it off ,as this helps to cool down the lamp the fan at rear still propels while the tv is in standby mode.--------ASH
Posted on May 13, 2009
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Panasonic plasma keeps switching off to standby power
Possibly overheating. is the tv abnormally hot?
What is the brand and model of your tv?
May 10, 2008 | Televison & Video
LG 29" COLOR TV HAVING MODEL NO. RF29CA40 plugged in and switched to standby mode it starts making a clicking sound. I can't get it to switch on it just sits clicking away in standby mode
my tv exactly same problem , from what ive read our tv 's are not worth the ammount it would cost to fix , around 250 dollars, im gutted! il let u know when i find out properly
Sep 19, 2013 | Televison & Video
Tv wont switch on with remote or the button on top of the tv. The standby button is on (red). sometimes it comes on by itself and switches off by itself (onto standby mode) not sure of the model as its a...
It could be one of a couple of problems really, the first one may be that your analogue signal is being switched over to digital which is happening across the UK at the moment, buying a digital receiver would resolve this straight away. It could be a problem with the ariel connection to the TV, check that its all pushed in properly at the back of the TV. Failing this then its a problem with the TV set, the fact that the set produces a picture on other sources (dvd) implies that if it is a fault with the TV its with the ariel connection.
Mar 31, 2011 | Sanyo Televison & Video
Trans prob
You can NOT check ATF when the engine is off. It must be running. If the ATF is dark, brown, or smells burned, then you need to change it, but it is probably too late. When you turn the engine off, the fluid in the torque converter drains back and gives a reading much higher than real.
Jan 18, 2010 | 2001 Chrysler Concorde
Goodmans model gtvl32w26hdf. Switched itself off. have changed fuse, with not difference. blue standby light comes on, using remote press standby blue light goes off, screen remains black.
Good Day SIr, sound to me like your switching power supply is not working properly, there is an IC that controls the switching action of your power supply, this MAY be the reason why it stays off. locate the IC at the power supply section, replace it then test. There is also a possibility of open low value resistors near the switching transistor (very hard to locate). hope this helps.
Sep 23, 2009 | Televison & Video
TV/DVD unit locked in Standby mode
Did you check the casing for a reset button (sometime it an itty ***** hole)
Hope this helps
Trap
Jan 25, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Tv stuck in standby
Your problem is in the switch mode power supply or the horizontal out circut.
sometimes the small CHOKE that feeds the base of the horz. out transistor has a cold solder joint.
resolder both ends first.
Thanks Guy9
Jun 10, 2008 | Televison & Video
Rear projection tv picture problem
Sounds like a tuner or Video output problem. What make and model set do you have.
Jan 09, 2008 | Televison & Video
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
