Question about Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner
ACER 9410CD/DVD-ROM driver not found.
Hi I inserted a CD/DVD and I am getting a message stating that No IDE CD/DVD-ROM drive is found. Please check your devices or driver settings and replace any real mode CD/DVD-ROM driver with the 32-bit driver supplied by Windows.
how do i reinstall driver ? thanks!! Vicki
  • 1 more comment
  • jrskylin848 Oct 04, 2008
    Hi I inserted a CD/DVD and I am getting a message stating that No IDE CD/DVD-ROM drive is found. It says i have to restart the burner.
    how do i do that?
  • zoestephenso Mar 25, 2009
    i have same problem with my acer aspire 5100 series laptop dont know how to uninstall druvers or even intstall 32 bit driver provideded by windows or even how to obtain it
  • Anonymous Mar 16, 2014
    lenovo 2949 DVD/CD-ROM driver download
  • 476 Answers
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Posted on Aug 29, 2008
Please insert disk message arrives always whenever i put blank disk to copy files from my computer
Posted on May 08, 2009
I connected my ide lg dvd rom using ide to sata adapter in my mother board as my mother board does not have any ide connection. so since ti gets detected during boot time but does not shows up or does not...
make sure that the cdrw/dvd is getting enough power test all leads that are attached to the cdrw/dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 02, 2011 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
DVD ROM cant read any cd or DVD
Try uninstalling the drivers and rebooting.
Jul 02, 2008 | Computers & Internet
When i turn on my e system 4213 laptop. keeps coming up with error message operating system not found. please help
Hi make sure you have no usb pen drives, floppy disks, or cdroms inserted then switch on the machine. If you still get the same error then your hard disk drive has malfunctioned or corrupted. If you have a restore cd or DVD insert this and restart the machine you may get an error message stating your hard disk drive is not found if it has malfunctioned.
Sep 10, 2009 | Acer Computers & Internet
Acer aspire l100 dvd problem
your DVD ROM's lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working agaain but be careful remember that no power should be attached to ROM.
pls rate me
thankyou
Feb 14, 2009 | Acer Aspire L100 PC Desktop
CD Drive not working at all
If its the only CD Drive on that IDE cable it wouldn't be set as slave, would be on Master.
Yes you can go to http://www.driverguide.com you can download updated drivers for IDE and SATA on your PC.I checked on Acer support but there website isnt't working correctly for me.
Try updating the drivers, and try both drives again one at a time.
Jan 07, 2009 | Acer Aspire™ T180 PC Desktop
Hard drive and dvd rom stopped working after changing to cd-rw, the ide cables have to unplugged to get any response from hard drive or dvd rom
Have you done the proper connection ? Please check out the Power & Data cable inserted firmly in Hard Disk, and DVD rom, after then check out the jumper is inserted correctly.
Unplug the Ram for 5 minutes and then try to start PC. Hope this works. Let me know the status after then.
Oct 09, 2008 | Apple Computers & Internet
ACER 4520 CD-RW/DVD-ROM its pops up insert disc
you can try two solutions
1) go to device manager and uninstall the primary and secondary ide controller under the IDE ATA/ATAPI controllers and than restart the system and than chk it if that works out
2 ) if the first option doesnt work try to update the firmware of the drive
Sep 09, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Acer T690 dvd not recognized
is this an ide drive? have you look for the jumper, single drive on one ide have no problem, but for two drives, one must be slave and the other a master. configuring your ide connections may fixed the problem.
May 20, 2007 | Acer (91.48T37.003) CD-RW/DVD-ROM (Combo)...
Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner Logo
500 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
