Question about Coleman Sport & Outdoor - Others
My Coleman stove Coleman Peak 1 Liquid Fuel Feather 400 Stove wont pump the gas anymore so it wont aflame. it has been barely used so its still like a new one. seems that the gasket is misaligned,or something. Any help for this issue would be appreciated.
4 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: how to operate a coleman two burner stove using
If you are talking about the old type that runs on Coleman fuel, start by putting some oil in the hole beside the pump knob to make sure that the gasket is lubricated. Fill with fuel and pump it up, keeping your thumb over the hole in the end of the pump knob. When you have pumped up enough pressure, turn on and light the main burner, then secondary burner if necessary.
Posted on Jul 10, 2009
SOURCE: I need to replace the
Oven door will not close completely, therefore oven light is always on and the outside manual switch doesn't turn light off or on. The gasket around the window is brittle and coming away from its anchors in a number of places. I would think it needs to be replaced. Where is this part available? either on line or in Toronto, ON. M5R 3M6 Canada
Posted on Aug 14, 2008
SOURCE: Coleman Peak 1 Model 400
My Peak 1 is 30 years old, and the only time it ever happened was the first time I used it, and I overfilled the tank. It needs some air space to comporess ans the fuuel is incompressible. The ley to this is to keep the whole stove level when you fill it. If you hold it so that the fuel filler is level, it will over fill the stove -- that is why the fuel filler is on an angle. Granted it is hard to fill that way, but Coleman makes (or used to make) a special aluminium funnel that fits into the filler pipe that makes it easier. Actually this is true for any white gas Coleman appliance -- note that abolustely all of them have the filler on an angle.
Posted on May 15, 2009
What type fuel and oil does this take
My searches of the internet indicate that this appliance is a multi-fuel appliance.
It is supplied with a gas bottle - for use with butane fuel
(see http://www.dx.com/p/campsor-9-split-type-camping-oil-gas-fuel-stove-silver-red-126914#.U0we9nlOVjo )
Read the reviews on that webpage for reviwers experiences with different types of fuel. Diesel doesn't work, it seems, but kerosenr and unleaded gasoline (petrol) work ok. You may need different connector for gaseous fuel and liquid fuels.
Coleman Naptha fuel apparently works well.
I hope this information is some use.
14.April.2014
Apr 14, 2014 | Universal CAMPSOR-10 Split Type Camping...
What is a liquid gas stove?
A liquid gas stove is a type of stove that uses a fuel tank in order to operate. Liquid gas stoves are capable of burning different types of fuels like alcohol, white gas, automobile gas, and kerosene.
Oct 25, 2012 | Camping, Backpacking & Hiking
Do liquid-fuel stoves need to be primed?
Liquid-fuel stoves need to be primed, a process that preheats the fuel line enabling the stove to convert the liquid fuel into a vapor.
Sep 10, 2012 | Coleman Camping, Backpacking & Hiking
What is a liquid-fuel stove?
Liquid-fuel stoves perform best in cold temperatures. They most commonly run on white gas using a refillable fuel bottle that is manually pressurized with a fuel pump.
For camping with large groups, what is the recommended stove?
The recommended stove for large group camping I advise you to purchase the liquid-fuel stove.
I have use Coleman fuel in my stove..is that ok? Also can't get it started
The Optimus Nova is a multi-fuel stove. Coleman fuel will work in the Nova. Coleman fuel, generically called "white gas", is a chemically pure form of gasoline, same as what you put in your car but with less impurities.
The nozzles all liquid fuel stoves can clog from time to time. Follow the instructions in the manual for cleaning. If you don't have a manual you can find it at:
http://www.optimusstoves.com/seen/optimus-products/products/katadynshopconnect/optimus-outdoor-kocher/
Hope this helps.
Mar 29, 2011 | Optimus Nova Stove
Coleman Peak 1 400A fuel/air mix wont ignite
krimkramm, any luck finding a solution? www.spiritburner.com seems to be a great source of information if you are still trying to fix your Coleman 400A. If you would like to sell it, I am looking for one for my local Boy Scout troop. Send me an email at braddotroberson@verizondotnet after replacing the dots with a you-know-what.
Brad
Aug 10, 2009 | Kitchen Ranges
How to operate a coleman two burner stove using liquid fuel
Jul 06, 2009 | Coleman Sport & Outdoor - Others
Coleman Peak 1 Model 400 stove We have had this stove for 20 years at least. The last couple years a problem has begun and has gotten worse. The stove will leak liquid fuel all over the base which then...
I have heard two things that could improve your stove. I had the same "bursting into flame" issue last weekend while camping. First, move the black handle back and forth a few times. That is supposed to clean the jet. Second, take the generator off and hit it with a blowtorch. That should clean out the deposites on the inside. Or you can purchase new generators (just make sure you get the correct one).
Aug 03, 2008 | Kitchen Ranges
Sport & Outdoor - Others Logo
360 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
Vernon Taylor
David Payne
David Payne
john h
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
