Question about HP DeskJet 3940 InkJet Photo Printer
Hi there. Can you tell me if HP 3940 printer can be connected via a serial cable? Our system will not work with a USB connected printer. Thanks
  • HP Master
  • 1,381 Answers
Hi hoshos6666
According to the manual , this unit runs only with a USB connection :
http://h10032.www1.hp.com/ctg/Manual/c00392271.pdf
Best regards ,
fanaudi
Posted on May 19, 2011
  • 823 Answers
I checked the specs on your printer and it has only one type of connection which is USB. You can get a gender changer and convert from USB to serial but it may not be optimal.
If you have a router and/or modem that has both USB and ethernet connections, you might try putting it on a home network and access it that way?
You can also get an external hub with 2.0 USB ports that has a serial cable choice of connection.
I want to install HP deskjet 3940 in my computer
Do the below steps.
1.Connect Printer cable(usb cable)to Computer&Swicth ON the printer.Printer driver cd also put in your cd/vd drive.
2.Start-device&Printers-Add Printer-Add a Local Printer-Select Port as USB001-Next-Have disk-Select yor Cd/dvd drive(Put Printer driver cd in your Cd/dvd drive)-next-next-Finish.
Jun 11, 2011 | HP DeskJet 3940 InkJet Photo Printer
I cant install my hp deskjet 3940 into my computer
Hi, Please try downloading a new driver for your hp deskjet 3940http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=in&lang=en&product=445449&
go to the above link and download the driver relevent to your operating system.and then try to install it.
remember not to connect the usb cable before installing the driver.
Good Luck.
Apr 01, 2011 | HP DeskJet 3940 InkJet Photo Printer
How to download the installer for hp deskjet 3940
You have not mentioned the PC make and Operating system
First step is to find out the system type of your PC.
Click on START button
Right click on Computer and left Click on Properties
From the New Window Check for System Type : It will be mentioned as 32 bit operating system or 64 bit operating system. ( Remember this )
Click on the link below to download the drivers.
When the page open's - Choose the Operating system and click on Next Button.
Click on Drivers and Product installation option and click on HP Full Feature Software and Drivers
Click on Download button on top and click SAVE ( Remember the location you save the file )
You need to run the downloaded software.
Disconnect the USB Cable from printer before you start the installation as the screen will prompt you when you connect it.
Download Drivers
Hope this is helpful and will help you in installing the printer software.
Thank you for contacting FixYa
*Please rate this solution with thumbs up
Nov 19, 2010 | HP DeskJet 3940 InkJet Photo Printer
My printer is offline and I can't get it back to online
If the printer is connected via USB cable, try the below steps.
1. Click start ->Run.
2. In the Run window, type "devmgmt.msc" (without quotes), click OK.
3. Device Manager Window will pop out, in this screen at the bottom you will see "Universal Serial Bus Controllers"
4. Click on the(+) sign next to "Universal Serial Bus Controllers" and look for "USB Composite Device".
5. Right click on "USB Composite Device" and select Uninstall.(Read Note)
6. After the the device is uninstalled, disconnect the USB cable from the back of the computer.
7. Restart the computer, after the system is booted plugin the USB cable.
8. You may need to wait for sometime for the device installation to get complete.
9 . Then try to print a word document.
Note: Before uninstalling the "USB Composite Device" right click on it and select properties to confirm whether that driver is for the printer.
Thanks & Regards,
Rizwan
Jun 29, 2010 | HP Photosmart C6100 All-In-One Printer
Can i connect hp laserjet 4p via usb ??
I have a similar situation. Trying to print from a HP LaserJet 4 using a parallel cable to USB. It will not recognize the printer. What is the installation setup or what is the trick to get it to print?
Jan 13, 2009 | HP LaserJet 4 plus Printer
Urgently help me printer not recognized.. hyd
hi!good pm...hope this will help...
try to check the USB cable connected to your cpu & printer,see if its inserted properly...or try to plug the USB cable to other USB socket...if this does solve your problem,get another USB cable & try it...
Feb 08, 2008 | HP DeskJet 3940 InkJet Photo Printer
Not printing
Try changing the USB cable then if doesn't work uninstall printer the unplug. Install drivers first then plug in the machine.
Try this hope it works for you
Thanks J
Sep 26, 2007 | HP LaserJet P2015dn Printer
Printer won't print
switch of the printer first remove the usb cable from the printer and uninstall the printer driver nad remove printer from device manager also. to go to the device manager do these steps first right click on my computer and then go to properties and the click on hardware tab and then click on device manager and go to universal serial bus controllers just click on + tab it will expand and it will show the list of connected hardware select usb printing support and right click on and uninstall then restart you system. after coplete boot run the driver software and connect the usb cable when it will prompt you and switch on the printer. it will install your printer
Sep 22, 2007 | HP DeskJet 3940 InkJet Photo Printer
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Sep 12, 2005 | HP Jornada 520
Connection with my iPAQ 3660
...USB and Serial cradles and cables from... http://www.pdasmart.com/ipaqparts3600.htm http://www.amazon.com/exec/obidos/A...1&link_code=as1 http://www.bizrate.com/buy/noncat_p...--37673232.html There are probably other sites, but these are a few from a quick search... Otherwise, yes via IR if the PC your synching with has IR functionality... BT and WiFi also, but you need to establish a partnership via USB/Serial/IR first... Go to this site and download the Reference Manual, etc... http://h18000.www1.hp.com/support/f...te/48_1334.html You can get the latest version of ActiveSync from... http://www.microsoft.com/windowsmob...tivesync37.mspx __________________ "When all else fails, read the instructions..."
Sep 12, 2005 | Compaq iPAQ H3660
HP DeskJet 3940 InkJet Photo Printer Logo
116 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
