Question about Sagem Puma Cell Phone
Hello I ve had my puma phone about 2 months. In the start gps work O.K. but suddenly it don t. When I start gps it writes "network problem". What I have to do? Thank you for your answer.
U av to get in touch with your service profider and they will text u the settings just accept when they send if they cant text u them they will give u the settings to install them manully hope this helps u
Posted on Jun 16, 2011
The internet light on my Acer Aspire laptop wont light up
Hello
Check if the the network connection is working. or if your don' have drivers for it.
Check if your Network card is working or Not.
1: you can check the driver if you can the driver install for the network card.
2: open CMD (Click start and search CMD)
3: write: Ping 127.0.0.1 (This will check if your card is working or no)
4: you will see the pinging 12.0.0.1
5: you will see at the bottom Ping statistics for 127.0.0.1:
6: if is says that received 4 and lost 0 then the network card work. If your see received 0 and lost 4 then the network card is faulty.
To Check the connection with the router try this.
1: open CMD (Click start and search CMD)
2: write: Ping 192.168.0.1 or 192.168.1.1 (This will check if your card is working or no)
3: you will see the pinging 192.168.0.1 or 192.168.1.1
4: you will see at the bottom Ping statistics for 192.168.0.1 or 192.168.1.1:
5: if is says that received 4 and lost 0 then the network card work. If
If you want to find everything about the connection:
2: write: ipconfig
3: IPV4 is your laptop IP (Internet Protocol)
4: Gateway is your Router IP (Internet Protocol)
5: Subnet Mask : 255.255.255.0 (Make sure its like this if different your need to contact some one)
5: Ignore the rest
Feb 07, 2014 | Computers & Internet
My Garmin Nuvi 255w no longer works. It just shows a message saying "System Software Missing". I use a MacBook. I don't know if that will change what I might need to do to fix this but so far...
Hello there,
The solution to this problem simply requires you to connect the nuvi to a computer. The start up files are corrupt, therefore causing it not to run properly.
You will have to download the web updater of garmin on your computer, then you connect the nuvi using the usb cable to the computer, then you update the software of the device using the webupdater.
That is how to solve the problem. Other than that, nothing else. Just try to get a friend with a PC to do this for you.
Hope this information helped. Goodluck Elect_Comp
Sep 02, 2011 | Garmin nuvi 255W GPS Receiver
I cannot recieve or send picture messaging when my aunt pays for the picture messaging. It always says "Sending failed. Unknown error. Retry?" and it never works. I even set the mms settings but...
Take it into the wireless retailer you got it from. They will help. It might just be your SIM card- mine was doing the same thing; they told me it was defective.
Best of luck,Juseppi
Jul 16, 2011 | Samsung Strive A687 (88516535667)
I have a 5 month old HTC Wildfire. I don't have access to WiFi and most often use Vodafone Mobile Connect to connect to the Internet. Suddenly, since the day before yesterday, whenever I'm trying...
Seems like your phone is functioning correctly.
You have disabled wi-fi so it is asking whether you wish to use Phone Data Connection instead. (Standard Practice when trying to access data services)
What you need to do is un-tick the option in options Use only 2g networks. (3g is the mobile data service) That should then allow you to access Mobile Data. (3g)
Also enable data enabled
Jun 17, 2011 | Cell Phones
I can't send or recive SMS mesages on my PUMA PHONE M1
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Jun 13, 2011 | Sagem Puma Cell Phone
All of a sudden, my Go 920 screen calibration is way out of sync, enough so that I can't select any buttons accurately. I have restored, reformatted, etc, but I can't even select the language...
Well, I can say this from a guy that has had several gps, in most cases Tom Tom is considered the low budget of the gps devices out there. If your lucky when you buy them and they work, feel lucky. They are considered disposable gps systems. I went through a few myself, until I ended up getting a megellian and works perfect, mor goodies, and never a problem in the last 4 years I h?ve had it. My advice, don't bother trying to fix it, because in a few months will happen again. Thanks Mike ( x truck driver)
Jun 09, 2011 | Tomtom GO 920 GPS Receiver
Hi have sonny w760i problem it's working suddenly, screen appear "no network coverage" then can't make call and can't choose network. Even though I select 'normal mode' at start up it still...
Hello and Welcome to FixYa!
Don't worry, once my W595 got the same issue all of a sudden, its a Firmware/software bug.
All you should have is your USB data cable (That comes with the new phone; named as DCU-65).
If you have it, then navigate to this link, download, install and run the software.
It a Software update utility, follow the instructions from the wizard. This will update your phones software. You issue will be resolved after a successful update.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Feb 17, 2011 | Sony Ericsson W760i Cellular Phone
I cannot store telephone numbers on my new Sagem Puma. Neither can I actively write any SMS - I can only answer.
ey i have the same problem now, can you tell me the solution? i love the puma phone but this problem makes me crazy... write me to juliosanz17@hotmail.com thanks
Feb 15, 2011 | Sagem Puma Cell Phone
Sagem Puma Cell Phone Logo
267 people viewed this question
Top Sagem Cell Phones Experts
Pavel Pranovich
Pavel Pranovich
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sagem Cell Phone Expert? Answer questions, earn points and help others
