Question about Tag Heuer Aquagraph CN211A wristwatch
Can i wear the watch in the sauna and steam room
Watch stopped working
Some "water resistant" watches aren't. Besides, why wear a watch in the shower?
May 12, 2013 | Sector oversize r3251202025
Watch stops or loses time every time i wear it.
normally automatic watch need to wear at least 8hrs in a day ,then it works for next 30hrs.if it stops or loosing time, it indicates that needs service with lubrication .
Feb 23, 2010 | Navy Seal Luminox Dive Watch
I bought a fossil ss blue am3733 on a cruise ship. It has worked perfectly untill the battery died a momnyh later. No one i Dothan ,Al knows **** nabout fossils. I lost my casio in the keys and had a rolex...
All I can say is: RELAX. You are tooooooooo winded, so, need some RUSSIAN lads to calm you down. For a while take a sauna. If you can withstand 110C, you are the man. If you can beat me (175C) you are out of this world. Good luck.
Feb 05, 2010 | Fossil AM3733 Wrist Watch
Getting moisture under the face of the watch just from wearing. This is not putting it in water at all
This usually happens when the watch is carried from low temperature to the room with higher temperature and it's called condensation. You need to dry out your watch and check if all the gaskets are in tact, flexible and lubricated. Don't leave it for a long, as later those tiny drops of condensate will sit down on gear wheels, causing them to rust and as a consequence will stop the watch working. Any watch repair shop will be able to help within a matter of an hour.
Rate me, plz.
Jan 11, 2010 | Relic Watches
I have an automatic watch that i don't wear that
Does it work when you wear it? If it does on those occasions then no harm no foul!!
Oct 06, 2009 | Rolex Daytona 116528 Wrist Watch
Guess Steel Water resistant is not water resistant!!!
Water resistant does not mean water proof. You should never wear this watch while bathing, swimming or in sauna.
Any watchmaker will be able to remove any condensation and dry out your watch - no matter you are in the U.S.A. or Romania.
Find your nearest watch repair shop and ask for help.
Rate, please.
Jul 20, 2009 | Guess G66355L Wrist Watch
Does anyone have a manual for a datejust rolex
No, there isn;t any downloadable manuals for Rolex watches, but operation of Rolex Datejust is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in date setting position,
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Feb 03, 2009 | Rolex Datejust SS
Larger clasp
Unfortunately, I do not think this is going to be an easy fix. You may want to take it to a local independent watchmaker. Gucci may sell larger clasps but they may be difficult to find even from them directly. I have looked at the watch you have. It it was solid gold a Jeweler could just make it a touch larger.
Looking at the clasps the options i see is
Have the bangle removed and wear it on a leather strap,
Possibly remove the clasp where it says gucci and have the pins laser welded so that the clasp stays in a fixed position similar to a bangle.
mike --consumerwatchguide.com
Jan 02, 2009 | Gucci 1500 YA015512 Watch
Fix my watch
you will need to open it let him dry and clean it.
if you not sure how to do it take it to a watch repair person.
Jan 24, 2008 | Seiko Titanium SMY042 Wrist Watch
Wrong time
Your watch is an automatic watch which means it winds itself as long as you are wearing it. If you don't wear it for several days it will stop working. To solve this situation buy an automatic watch winder to keep your watch in while you are not wearing it and it will keep the correct time.
Dec 28, 2007 | Rolex Daytona 116520 Wrist Watch
Tag Heuer Aquagraph CN211A wristwatch Logo
174 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
