Question about Symbol MC9090 Barcode Scanner
We have a problem with reading out ascii chars 029 (group seperator) and 030 (record separator). Do you know why these chars aren't read out with the MC9090 and can you say us how we must do the configuration of these scanner so that the MC9090 is reading out these ascii chars? Thanks in advance.
thesuperdude
  • 97 Answers
SOURCE: Do I need to purchase the Device Configuration Package?
Depending on what application your client will use, you will need to configure the scanner in which ever way suits your customer.
If you use a telnet client kind like wavelink, you can configure it from there. If you planning on using some other application that has not scaner api's, you will need to use datawedge which is available as a free download from symbol support.
The DCP is normally available free of charge, however motorola has changed the downloads policy for dcp and depending on the version, you may need to provide them with information of the terminal and request the download.
I hope this helps.
Posted on Mar 26, 2009
thesuperdude
  • 97 Answers
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
thesuperdude
  • 97 Answers
SOURCE: Cannot read symbologie/BarCode: i25(interleaved 2
You will need to configure the telnet emulator from your pc first and download it to the terminal after.
Check the version of telnet emulator you have. To do this, go to the options menu on the emulator and click on about wavelink.
Register yourself on www.wavelink.com and download the same client version as installed on the terminal. (Don't forget to download the Active sync version.
Tweak all the configuration parameters on the emulator once you have installed it on your pc also enable i2of5 symbology and then download the config only to the terminal.
Batstar
  • 122 Answers
SOURCE: geting ascii chararter
Hold down ALT and Pres 179 then release ALT and the character will show up. Or you can hold down Shift and press the Button above Enter, also has a \ on it.
Posted on Jun 19, 2009
SOURCE: first time connection?
The MC9090 does not require any installation.
All it requires that you have ActiveSync installed on you PC. That can be downloaded directly from Microsoft. got to www.microsoft.com and just seach for activesync.
Just make sure that the MC9090 is configured to comminicate via USB
Settings >> System >> USBConfig
Make sure it is set to [USB Client Mode].
Also
Settings >> Connections >> USB to PC
Make sure that [Enable advanced network functionality] is ticked.
If you need any more help dont hesitate to contact us
www.biastechnology.com
helpdesk@biastechnology.com
Posted on Sep 11, 2009
How to test compressor on refrigerator
take an ohmmeter set on the RX1 or the lowest resistance setting,take either lead from the single pin on the compressor and touch one of the other pins,then touch the other pin you will read between 7 and 11 ohms,then touch the 2 pins that are side by side you will read the sum total of the first 2 readings of about 11 ohms,don't worry if readings aren't exact then from each pin separately touch one lead to a bare spot on the compressor body to each pin,you should NOT read ANY resistance from ground(coimpressor case) to each pin or the motor/compressor is internally shorted
Aug 27, 2012 | GE Refrigerators
HC 112, NO 805
I don't know what the standard is for your state,but that doesn't
sound bad at all, for a 1994 spec vehicle.
How would they know timing was an issue?
I suggest your exhaust converter is worn out
May need a clean air filter
New O2 Sensor
Assume spark plugs aren't too old &
no ignition misfires?
Egr Valve ?
May 23, 2012 | 1994 Toyota Corolla
DVD portion was intermittent on reading portion & now does not work at all. VCR side records fine & tuner works ok. Was there a problem with these units.
Like all DVD Players & Recorders the Laser only has a certain life span before it burns out. Some last longer than others and most aren't cost effective or viable to replace.
In your case it's even worse beause you'd have to replace the complete DVD Mechanism.
http://www.encompassparts.com/products/?JVCLG-EAZ41878721
Please leave feedback
Cheers
Andy
May 14, 2011 | JVC DR-MV150B DVD Recorder/VCR
Jeep charokee has no engine fire,check crank position sensor it was loose wires were fraid i replaced sensor still no fire
Firstly, you need to extract your vehicle's diagnostic codes - this will identify where the problem lies.
Instructions (using ignition key method):
Codes are shown by the Check Engine Light (CEL) on the dash. 1. Turn the ignition ON-OFF, ON-OFF, and finally ON again (without starting) 2. Codes will be emitted via CEL on the dashboard display. 3. Read codes as described below. Reading codes: Each code consists of two groups. The first group of flashes indicate the 'tens' digits. The second group of flashes indicate the 'ones' digits. A short pause separates 'tens' and 'ones' digits. A long pause separates each trouble code. e.g. Long flash, Long flash (short pause); short flash, short flash (long pause).....then repeats... The above flash sequence indicates Code 22. If you are able to get your codes, post them here and I can assist you further. Cheers, "If this has helped you in any way, please place a testimonial"
May 13, 2011 | 1993 Jeep Grand Cherokee
Is it possible to to convert charrcter datatype into integer datatype
If you want to get the ASCII value of a character, or just convert it into an int (say for writing to an OutputStream), you need to cast from a char to an int.
What's casting? Casting is when we explicitly convert from one primitve data type, or a class, to another. Here's a brief example.
public class char_to_int { public static void main(String args[]) { char myChar = 'a'; int i = (int) myChar; // cast from a char to an int System.out.println ("ASCII value - " + i); } }
In this example, we have a character ('a'), and we cast it to an integer. Printing this integer out will give us the ASCII value of 'a'.
Nov 04, 2010 | Answer Racing Ion Motorcycle Jersey 2010
Need codes for my ''oneforall'' remote so I can use on my emerson tv and vcr combination tv.
Emerson TV Codes 004-006-012-023-024-025-026-027-028-029-030-031-032-033-034-035-036-037-038-039-041-042-043-044-046-047-123-124-162-171-177-179-191-196-208
Emerson VCR Codes-012-014-015-021-024-025-026-029-030-031-032-033-034-036-037-038-039-040-041-042-044-045-046-047-065-105-113-116-117-130
Mar 24, 2010 | Televison & Video
Need to get code for 3-1 remote # 1519001
TV Brand 3-in-1 Code Radio Shack Cat. No.
Akai 098
Anam 068, 180
Anam National 055, 161
AOC 019, 030, 052, 137
Candle 030, 046, 056, 186
Capehart 052
Citizen 030, 039, 046, 056, 060, 092,
186
Concerto 056
Contec 158, 180, 185
Craig 161, 180
Crown 039
Curtis Mathes 030, 039, 060
CXC 180
Daewoo 019, 039, 091, 092
Daytron 039
Electrohome 039
Emerson 039, 158, 177, 178, 179, 180,
181, 182, 183, 185, 236, 270,
280, 282
Envision 030
Fisher 154, 159
Fortress 093
Fujitsu 179
Funai 179, 180
Futuretech 180
GE 021, 027, 029, 047, 051, 055,
174, 178, 282
Goldstar 001,019, 039,056, 106, 178
Hallmark 178
Hitachi 038, 039, 056, 095, 097, 145,
151, 173, 227
Infinity 054
JBL 054
JVC 053, 169
Kenwood 030
Kloss 046
Kloss Novabeam 024
KMC 106
KTV 039, 180, 280
Logik 016
Luxman 056
LXI 047, 054, 148,154, 156
Magnavox 020, 024, 028, 030, 054,
096, 186, 187
Marantz 030, 054
Memorex 016
154 16-229
178 16-254
16-263
16-280
MGA 019, 030, 150, 155, 178
Mitsubishi 019, 098, 155, 178
Mitsubishi Unified 150
MTC 019, 030, 056, 060, 091
Multitech 217
NAD 156, 166
NEC 019, 056, 170
NEC Unified 030
Onwa 180
Optonica 093, 165
Panasonic 051, 054, 055, 162
Penney 018, 019, 021, 030, 039, 047,
060, 135, 149, 019, 020, 024,
028, 030, 054, 186, 187
Phillips 000, 054
Pioneer 038, 166
i think this will help you a lot.
Aug 03, 2009 | Televison & Video
How to write a record with pointer variables in a file in c++
if understand your question correctly , you don not work the pointer value but the contents the pointer is referring to.
Hope that makes sense
char* pointer = "some message";
pointer = 0x04556 *pointer = "s";
Regards
GeWiz
Apr 13, 2009 | Intel Computers & Internet
I want a c program for reading a image
FILE *fp = fopen( "file.bmp", "rb" ); This opens the file
unsigned char buff[10];
size_t n = fread( buff, sizeof(buff[0]), sizeof(buff), fp ); This reads 10 bytes from the file.
10 is obviously just an example, but you can read the documentation to find out how big a BMPHEADER structure is, and read that number of bytes instead. Having got that, you get vital information such as
- the width and height of the image
- the number of bits in each pixel
- whether there is a colour table in the file.
You then skip the optional colour table (say by using fseek), then you can start looping reading image data, based on your knowledge of the width, height and bpp of the image format.
Mar 17, 2009 | Computers & Internet
Symbol MC9090 Barcode Scanner Logo
131 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
