Question about Olympus PEN EPL1 Digital Camera
I just got my camera and i cant film for more than 2 minutes how do i fix this? I've tried auto, film setting, art filters etc. Please help me. Thank you so much.
    Scholar:
  • 59 Answers
This is certainly a memory card issue, try with a bigger an most important Faster one !!
If your card is not fast enough, the camera buffer will eventually be full because it can't pour the data in the card fast enough, thus stopping the video.
Hope this helps
Posted on May 19, 2011
Have Minolta 440si. It was 'dormant' w/o battery for several years. Wanted to use. Loaded fresh battery and film. No shutter operation at all. But,display is visible and auto film load and rew
If it has been stored for so long, the internal battery, which maintains the settings etc and is charged from the main battery, is probably defunct.
May 25, 2017 | Minolta Maxxum 400si 35mm SLR Camera
Tip
Stuck Film Advance in Manual or Auto Wind 35mm Cameras
I've been seeing a great number of posts from people requesting help with a stuck film advance feature on their 35mm film cameras (you remember "film", right?) Normally, there are just a couple of things you can try to fix this issue before you'll need to find a professional to repair your camera - if it's even worth it. On that note, a lot of people still have film cameras for nostalgia purposes but there are still some hold outs that enjoy film. Finding a repair shop for an older camera isn't impossible but they are getting scarcer. Google "FILM CAMERA REPAIR" and see what pops up in your area!
MANUAL ADVANCE CAMERAS:
There's a complex number of actions that must work properly in order for you to advance the film in your camera using the manual advance lever. Gears, shafts, bearings and springs come into play and like a clock, they need to mesh together or the advance mechanism comes to a screeching halt. Well, you'll be the only one screeching, most likely but you get the point. If any of those parts break or become unaligned, or if some foreign matter like dust or dirt gets into them, the same thing happens. However, there are sometimes a few things you can try that might prevent you from sending in your camera for professional repair. I caution you about opening your camera yourself unless it has no real value to you because the interior of a 35mm SLR camera is pretty complex, even more so that a clock. Chances are you'll do more bad than good. With that said, try these options:
Film Jammed - Won't Advance
Sometimes the film will jam in the canister, or in rare instances, isn't actually as long as it's supposed to be and can reach the end of the roll before the camera indicates it has. If you suspect this has occurred then push the film release button and try to wind the film back into the canister before opening the camera. If you don't care if the film gets exposed feel free to do this in the light. It's much easier!
At times the film may also pull lose from the canister and roll completely on the take-up reel. If this happens you'll need to take the camera into a completely dark room with the light-proof film container, remove the film manually from your camera, roll the film up and put it into the light-proof container, close it tight and then seal it with electrical or duct tape. Also let the lab know this has happened so they don't pop up the container and expose your film thinking it is still in the canister.
Advance Lever Stuck
If the actual film advance lever is stuck and won't move, about the only option you have is to open the back of the camera and be sure nothing has jammed in the gears or sprockets of the take up reel or film path. If that doesn't fix the problem try pressing the film release button, wind the rewind lever a bit and see if the advance lever engages again.
If the lever just flips back and forth with no tension at all then something inside has broken and your chances of repairing it yourself are almost none. Most film cameras are getting on in years and will just naturally begin to break down over time. There may be no option to even fix your camera unless you find a similar model for parts and send that along to the repair shop. Make sure you get the parts camera back as you may need it later! If you like tinkering and the camera isn't one you'd miss if you couldn't fix it, then you could always give it a shot yourself. You can pick up a set of jeweler's screwdrivers and pliers from the web or Radio Shack for under $20 and find old film cameras on EBay or Craigslist at a decent price. Just be sure they don't have the same problem as your current camera does!
Grinding Noise When Advancing Film
This is most often caused either by a broken part, metal shavings or dirt/debris in the winding mechanism. Again, if you feel comfortable doing it yourself and it's not an expensive collector's model, you can try to repair it yourself. Hunt down a PDF service manual for your camera on the using Google web (a lot of collectors share them) and it should show you how to remove the cover to see the winding mechanism area. Look for debris in the gears and springs and remove it with short blasts of canned air but be sure you hold the camera so any debris falls out and not further into the camera. You can also use Q-tips dipped in alcohol to remove any debris, but don't use water, and let the area dry completely. Once you've done this, you'll need to apply a light lubricant to the area but only if it was lubricated before you cleaned. Use thin white lithium grease or an oil or grease used by clock repair shops and apply it with a toothpick as you don't need much. DON'T USE WD-40! It will do more damage than help.
MANUAL ADVANCE CAMERAS WITH MOTORDRIVE ATTACHMENTS:
These are manual wind cameras like the Minolta X-700 or Nikon FM2 that have an attachable motor drive that winds the film for you. Pretty much the same suggestions previously noted can be tried with a couple of exceptions:
Check the batteries and contacts in the winder making sure they're clean and not bent or broken. You can clean battery contacts with a CLEAN pencil eraser or alcohol and a Q-tip. Blow any dust and debris out of the compartment afterwards.If you still experience problems remove the winder and be sure the coupling that locks into the bottom of the camera to wind the film is not jammed or damaged. With batteries in the winder and the power turned on, look for a series of contacts on the top of the winder that mate with your camera. Be sure these aren't dirty or broken as well. Using a paper clip, you should be able to short one or more of them to another to activate the winder to make sure it works properly.
When All Else Fails - A Bigger Hammer
If none of the previous suggestions work and if, ONLY if you don't value the camera for collector's value a firm tap might work as a last ditch effort. I once had an old Minolta SRT that locked up solid. I didn't want to bother with trying to open it up as I only used it for a shelf display so I took the lens off, used a wad of very clean, soft foam to hold the mirror steady and wacked it twice on the counter. Not enough to damage the camera body (or the counter!) but a good smack. Whatever was jammed came loose and the advanced began to work. As I said, I only use it for display so I don't know if it affected the shutter speeds, etc. but it worked and cost me nothing but time.
AUTO/POWER ADVANCE CAMERAS:
Newer "old" 35mm film cameras used a power winder motor to advance the film and **** the shutter. If you experience a jammed advance on these cameras, check the film path, sprockets and make sure they are clear and move freely, as I described previously. Try the film release button and see if that will release the drive as well. Another option that has worked at times is to remove the film, lens and all batteries from the camera (including any date/time battery) for at least a day or two to see if the camera will reset itself. This worked for me once with a Nikon N70.
As a last ditch effort, the table smack might work as well, but I make no promises and it's all your fault if you damage the camera beyond repair... or your furniture!
on Jan 06, 2015 | Photography
Minolta x74 camera
You may download a copy of the manual from here.
Aug 23, 2012 | Photography
I've got Nikon F65. I cannot load film. The motor which load up the film doesn't move at all. Please help!
I don't know this model but you can try this.Drop the film canister in and pull the film strip out and place on the film advance sprocket.Rotate the sprocket by hand/thumb until film is seated (1 turn). If the auto feed is working you will be OK. 2 other things ,1 of course load film in dark area, 2 check the batteries on the camera first, if they are week your film advance wont work ,Good Luck.
Jul 29, 2011 | Nikon Photography
I've taken many photos so far with my Canon T70 but have no idea how many and when to stop.. i'm not counting the number of photos i've taken, haven't heard any beeping and don't know...
The maximum number of shots possible is 24 or 36 depending on the film length, although sometimes you can squeeze an extra one out of a film. If the film loaded correctly you will get a frame counter in the LCD. If the film did not load correctly, then you have not taken any photos as the film is still in the canister and unexposed.
Take the camera to a totally dark room (and I do mean absolutely pitch black) and open the camera. if you can feel the film canister and just the short leader then it didn't load and you can turn on the lights and try loading again. if there is just the canister and no film sticking out, then the film has rewound and you can turn the lights on and send the film for developing to see if the camera worked. If you feel film going from the canister right across to the take-up spool, then your film is still being used and you should close the back of the camera before turning on the lights again. The latter does not necessarily mean that your camera is OK though as it should be showing frame numbers, but it may be usable still. If after a few more shots the camera is still behaving just the same then it's got a fault.
A faulty t70 is really not worth repairing. It's complex, spares are mostly unavailable, and they are almost worthless even in perfect condition. Any of the earlier non-t-series Canon FD-mount bodies are far better and a lot more fixable. They are also usually near worthless and can be picked up free or very cheaply, but as they have less to go wrong and were designed with repairs in mind then many common faults can be fixed.
Jul 27, 2011 | Canon T70 35mm SLR Camera
Nikon FG. Replaced 3V battery. On the M90 setting the film advances OK. On 'program' or other settings it will only advance once and after shutter fires it will not advance until put on...
M90 is a battery independent setting - it requires no battery power to function. If it won't advance until put on M90 from other settings, then either you're not allowing for proper exposure, have the settings incorrectly set (film speed, etc), or you have shutter issues. The shutter is electronically controlled on all settings except M90. In the auto setting, your lense MUST be set to the smallest aperture (biggest number). On any other setting, you can use it however you'd like. I'd suggest unloading any film, setting the shutter speed dial to 1/125 or so, opening the back and looking thru and firing the shutter. If it's not snapping open and immediately closed, theres an issue and you need to consult a repair technician either locally, through Nikon, or through KEH Camera online.
Jun 29, 2011 | Nikon FG 35mm SLR Camera
White Exposure when shot
you say.. "used to" does that mean it doesn't do it now?
overexposure is caused by setting the wrong ASA ( film speed) oon digital you set the ISO which is the digital equivalent.
GO TO MENU and set ISO to auto and WB (White balance to auto) EX(IT
See if that imoroves the outcome.
some ISO settings in models akllow individual selections of numerical values for different lighting.
ISO 64, 120, 250, 500, 1000. etc
1000 is for very low light (fast film ) 64 is for brighter conditions like average daylight
Please rate my help++++Thanks for using FIXYA
Mar 21, 2010 | Canon PowerShot A630 Digital Camera
Pictures come out very grainy
Most likely, you've set the ISO value higher than necessary for most circumstances. You may have done this deliberately to catch some fast action, or you accidentally hit the ISO button without realizing it. If you reset to lower ISO settings, your graininess problem will probably disappear.
The faster the "film speed", whether you're using real film or a digital camera, the more grainy the pictures will be. ISO is the film speed. The ISO speed is set by pressing the ISO button (just above the "FUNC SET" button); it cycles thru AUTO, HI, 80,100, 200, 400, 800, 1600, then back to AUTO. If you've set the camera to AUTO on the control wheel opn the top of the camera, then you can only select ISO of AUTO or HI (which is slightly faster than AUTO).
The higher ISO settings are useful in low light conditions or to catch fast action, but those higher settings should not be used otherwise because of the increased graininess.
I hope this helps you.
Oct 19, 2008 | Canon PowerShot A540 Digital Camera
I cant seem to load film in my camera . it winds it back up as soon as i close it or try to take pictures
It's still in auto-rewind mode. Depending on the model, do a manual rewind with no film in the camera to reset the internal counter. Then load film and try it. Please leave feedback if this helps.
Jul 26, 2008 | Cameras
Eos Rebel 2000 battery problem
Send camera to me and I will advise you B4 repairs regarding cost etc. WWW.FLCAMERAREPAIR,COM Art Schneider
Oct 18, 2007 | Canon EOS-AE-1 35mm SLR Camera
Olympus PEN EPL1 Digital Camera Logo
80 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
