My new Toshiba STORE ART 3 1 TB external Hard Disk is not working. i plugged it to my pc on windows 7. and it shows the drive in My Computer but when i opened it it saying that 'Please insert disk into drive E:.' So i also tried it in Windows XP SP3, but its the same. not working. is it my Hdd problem?
    President:
  • 650 Answers
Open your command prompt and format the drive type format volume [/fs:file-system]
volume: Specifies the mount point, volume name, or drive letter of the drive you want to format.
/fs:
file-system: Specifies the file system to use FAT, FAT32, or NTFS Floppy disks can use only the FAT file system.
Example.........FORMAT E: /FS:FAT32.....Press enter. E: is my second drive
Posted on May 19, 2011
How do I fix my greyed out volumes in my Seagate 4 TB external drive?
Is it formatted to FAT by any chance?
Have you tried pluging it into another mac?
Or even a to a Windows PC?
Oct 15, 2016 | Apple Customized 15" MacBook Pro Laptop...
External hard drive transfer rate very slow
Windows 7 has something set wrong if you are showing 2.6GB usable. Windows 7 will recognize 3GB regardless of whether it is 32 bit or 64 bit.
Oct 02, 2014 | Toshiba Canvio Desk HDWC130XK3J1 3 TB...
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Toshiba 1TB external hard drive does not show on menu
Open the file and cick save as. In the window that opens, select the external drive in the list.
or, right click the file and click copy. Open the external drive in my computer and click paste.
Mar 16, 2014 | Toshiba Computers & Internet
I've got a 2 TB WD Elements external hard drive, and suddenly, no computer wants to recognize it when I plug it in. It is just rejected by any pc i've tried (3 laptops so far...) and I've a...
Is the PC you've used before is the operating system is windows Xp? If you've using windows Xp before then you've plug it in a windows 7 Operating system, it means your hard disc have no problem the operating system of your PC is different than before. Try to plug it in a windows Xp operating system then recover it in there then format it in a windows 7 operating system then, the windows Xp and windows 7 try to make a network place in the connection then share the hard disc files that you've recovered then copy and paste it in the newly format hard drive that formated in a windows 7 operating system.
Jul 21, 2011 | Western Digital Elements 2 TB USB 2.0...
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
320 external hardrive
Most commonly, 297 GB is the formatted capacity of the 320 GB hard drive. You can check if there is any unpartitioned space left on your hard drive. Right click My Computer, click Manage, click Disk Management, locate the hard drive which shows 297 GB (a big reactangle). If this rectangle is all the way from left to right, everything is fine. Else it will also show another rectangle next to it as Unpartitioned space which you can format and use.
May 29, 2010 | Western Digital My Book Essential Edition...
Hi im sachin want to purchase 1 tb hard disk of cgate and LCD of ither samsung or sony.... 1. will support an external USB hard drive on this lcd's ? 2.is there any other type of hard disk i need to...
I do not know if the 1 Tb external hard will work on the USB ports on the LCD TVs.
What do you want to store on the 1 Tb USB hard drive and display on the LCD TVs?
Most LCD TVs can access USB memory sticks and display DVI movies (if supported by the TV), photos etc. that are stored on these USB memory sticks.
Try inserting an USB hard drive (borrow one if necessary, can be any capacity) into the USB port to see if it works before you decide to purchase a 1 Tb USB hard drive.
My suggestion would be to purchase a 1 Tb USB memory stick. This would out perform an external USB hard drive.
May 19, 2010 | Dell Dimension 3000 PC Desktop
Computer not recognizing external Hard Drive
Aren't usb drives fun? Anyway, there are a few points where this can break down. Your external drive is actually made up of a few parts. It has a normal hard drive, and either what is called a "SATA to USB Bridge" or a "IDE to USB Bridge". If it is a full desktop size hard drive, it will come with a power supply that you plug into the back of the drive. If you have a laptop hard drive it can be powered through the usb port.
When you plug it in, the computer should recognize that you plugged in a new device and show you a message saying found new hardware, found usb to ata bridge, found disk drive etc. in that order. If you get these messages and still no hard drive shows up in my computer, then you may need to assign a letter to the drive or even format it. Right click on the "My Computer" icon, then select "Manage". On the right hand side of the window that appeared, double click storage, then disk management. It should list all drives attached to the computer. Your TB drive should show up as a removable disk, and should already have a partition. If it does not have a partition, you will have to partition it. Just right click on the rectangular part (on the right side) and select format. If you cant format it, try right clicking on the left hand side, the square bit, and select initialize. Then format.
If you just need to set a drive letter, right click on the rectangular part and select 'change drive letters and paths"
Here are some other things that can go wrong:
Not enough power, the drive isn't getting enough power and cant mount. Try plugging in the power adapter that came with it or try a different usb port. If it came with one of those funny looking Y shaped usb cables, plug both ends into the computer, so that it can get enough power.
Bad hardware, either the hard drive or the bridge is bad.
Then you need to return it to the store you got it from. If that is not possible you may be able to pull the drive out of the enclosure and use it as an internal drive.
Bad USB ports.
This can be hardware or software. If other usb devices work fine then this is probably not the case.
Apr 26, 2010 | Computers & Internet
My 1 tb WD hard drive isn't even being recognized
If the 1 tb is spinning up, which I assume it is, the new PC (assuming a Win 7 OS) should see it and mount a driver to be able to talk with it. I would double check all my connections at the drive and the PC, try different USB ports just in case one is dead.
Apr 11, 2010 | Western Digital My Book Essential 1TB...
Computers & Internet Logo
448 people viewed this question
David Payne
David Payne
