Question about OKI MICROLINE ML-395 Matrix Printer
Print fragmented documnts
My ml3390 oki printer prints dipersed data but when we print self test it is ok.
  • 734 Answers
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Posted on Dec 04, 2008
Printer saying recieving data and is not printing
First check the printer itself is working OK by printing a test page.
Most printers have a power-on self test (eg press feed button while pressing power on - please consult your manual). If the test print is OK, then it's the PC or connecting cable. You could try any other PC or laptop (you would have to instal your printer software first) but just try re-installing your printer software first on YOUR computer. If that doesn't work try any other PC or Laptop available as directed above.
If none of the works then the cable is suspect.
Mar 31, 2014 | Brother MFC Office Equipment & Supplies
Pages print with a line thru all the text. They aren't underlines, but have an actual line printed over the text. How do I change this?
It's called overstrike.
Try send a print out from another application. If result is same, then print a self test page. Still the same, then replace cartridge.
Otherwise, head needs service/replacement.
However, if self test print out look good then you should check printer preferences.
good luck
Dec 02, 2010 | OKI MICROLINE 380 Matrix Printer
When printing all I get is a message saying invalid data (printer B4300)
I had same problem and when I installed OKI B4350 (PCL) driver it started working fine.
Before I had OKI B4350(PS) driver installed and it gave me invalid data error everytime I've pressed print.
I hope this works for you too.
May 22, 2009 | OKI B4350 Laser Printer
Oki Microline 590
Try to perform an offline test print using your printer alone
To do this, power off your printer first
Press and hold the LF/FF button on the printer panel then power on. The printer will perform its own printing ( lines of pattern )
If it does it without problems ( no MENU lights came on ) the printer should be OK. If not try replacing the printer main control board.
Hope this helps
KM Hoo
Mar 04, 2009 | OKI MICROLINE 590 Matrix Printer
Documents held in queue
ok..would you like me to 'visit' your computer? to solve this?
click here for that option..d/l the application, and then 'knock' on my AskMe door.
Jun 01, 2008 | Lexmark X2350 All-In-One InkJet Printer
The types of printers that you have actually should be assigned to a free port, you cant setup 2 printers on the same port. check at the back of the printer the physical attachment of two printers the OKI and the Epson, if Oki is set to lpt1 then assign port from printer properties for oki to lpt1, and lpt2 on epson. 1 printer- 1 port, so by then check if the box for enable bidirectional support is check, remove the check mark from the box by clicking on it then hit apply then try printing a test page then try printing from application.
Apr 08, 2008 | Epson TM U325PD Matrix Label Printer
3410 Oki printer
If your print fades in then out every 5-6 lines, your platen probably has flat spots on it. This can be caused when someone forget to perform an alignment on a PH.
To run a test page you can power off the printer. Hold down the LF key and power on at the same time, this will print a self test.
Feb 04, 2008 | OKI Pacemark 3410 Matrix Printer
Abnormal printing with continuous tone
this sounds like it is doing something called a "hex dump" basicaly printing all ASCII characters. okis tend to do this from time to time if l;eft on for a significant period with no data sent to it. the only advice given by oki is to switch it off when not using it unfortunatly Hope this helps Cops
Oct 08, 2007 | OKI Pacemark 4410 Matrix Printer
Need Help!
Sounds like driver problems. Cant solve problems without details like what opperating system, what driver, how it the printer attached, usb, paralel, network? Will it print a test page from the driver ok?
Aug 31, 2007 | Samsung OKIDATA - OKI Microline 590...
OKI MICROLINE  ML-395 Matrix Printer Logo
169 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
