Question about Minolta Di3010 Copier
Error Code C0520 is shown when the machine is started. No sign of further function. Minolta Cspro 3000 model
  • Minolta Master
  • 6,161 Answers
Open the front door to your left small access cover remove cover press the trouble reset if the code comes back replace the fuser unit try below web site for parts for the fuser (the hot part) continue to reset can cause a fire
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Feb 22, 2015
  • 163 Answers
SOURCE: Minolta CSPRO EP2030
respected sir i just wnt to say that open the rear upper cover ,there will be a small micro switch ,while ON the machine press that micro switch your machine will be ready
Posted on Oct 07, 2007
Cogz
  • 1326 Answers
SOURCE: Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Posted on Feb 07, 2009
  • 15 Answers
SOURCE: Error Code C04
Let the copier on then press S1 (reset switch ) on Board-A.
Posted on Apr 09, 2009
goalie39
  • 469 Answers
SOURCE: code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Ed
Posted on Apr 27, 2009
goodgold
  • 389 Answers
SOURCE: MINOLTA EP2010 CSPRO ERROR CODE C04, WHAT DOES IT
MINOLTA EP2010
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
Posted on Oct 10, 2009
MMY COPY MACHINE IS CSPRO MODEL EP 3010 MINOLTA APER ERROR CODE C061
Lens Motor, under the big glass is to your right is the lens assy. there is a motor that works the mirrors on that side it is either jammed or burned out. Or worse case the board controlling it is bad. You have a Legacy Minolta Machine, get a tech out (Old School one:))
Jun 02, 2014 | Konica Minolta Office Equipment & Supplies
Error c0520
open and close the front door and see if the code resets
Nov 01, 2013 | Konica Minolta Office Equipment & Supplies
Minolta cspro 2010 error code c05
pLEASE DESCRIBE YOUR PROBLEM CORRECTLY.tHE 05 CODE REFER TO FUSING UNIT.Check or change the fuser unit components,clean the thermofuse and thermistors.
May 12, 2010 | Minolta EP4000/5000 CS/PRO Copier
Error code c0520 konica minolta c350
How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521).Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Jan 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Code C0070 durning the working time
Ed
Apr 26, 2009 | Minolta EP1030/1030F CS/PRO Copier
Feb 06, 2009 | Minolta Di3010 Copier
Problem in minolta cspro 2050
What code are you looking for??? I'll tell you what it means for FREE.....
Aug 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
Minolta Di3010 Copier Logo
180 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
