Fatal error 06 - Computers & Internet
    Scholar:
  • 65 Answers
This behavior can occur if an earlier version of McAfee's VirusScan (anti- virus software) or Norton AntiVirus is being loaded from the Autoexec.bat file.
Warning This workaround may make your computer or your network more vulnerable to attack by malicious users or by malicious software such as viruses. We do not recommend this workaround but are providing this information so that you can implement this workaround at your own discretion. Use this workaround at your own risk.
To resolve this issue, disable McAfee VirusScan or Norton AntiVirus. To do so, follow these steps:
  1. Restart your computer, press and hold down the CTRL key until the Windows 98 Startup menu appears, and then choose Command Prompt Only.
  2. At the command prompt, type edit c:\autoexec.bat, and then press ENTER.
  3. Type rem, and then a space at the beginning of the line that contains Vshield.exe.
    If you are using Norton AntiVirus, type rem and then a space at the beginning of the line added by Norton AntiVirus.
  4. Save and then close the Autoexec.bat file.
  5. Restart your computer. Setup should continue.
Posted on May 19, 2011
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
"Message storage memory not ready", followed by 0x80900001 error while backing up
first try to reduce the memory of phone.Because if the phone memory is almost full this could happen.Thanks for visiting fixya.
Mar 27, 2012 | Nokia mobile C2-00 Dual SIMbiosis
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
When I open navigation tool I get a Fatal Application Error
One check the sd card for the unit and maker sure it is not locked (yes they do have a lock on them), it will be a small white? tab on the side that will slide up and down. That's the lock.
If this is good and it is not locked, then i would suggest that you check and see if you have an install cd for your unit. If you do and once you verify that you have the maps, I would suggest that you either get a new 2gb sd disk to use in the gps or reformat the original and install the software again.
These types of errors are generally caused when the operating system tries to access a file and for whatever the reason, that file or simply a byte of information has gone missing or is corrupt. The unit can't find the software and spits out a pretty much useless code for the average user.
Hope this helps.
Apr 26, 2010 | GPS
My pc`s screen is blue and it sais stop:c000021a ,is there? anything I can do to fix it
hello there
here is some information that should be able to explain this error and how to fix it ok?
best regards michael
  1. How to troubleshoot a "STOP 0xC000021A" error ... presents advanced troubleshooting steps for the STOP 0xC000021A error. ... STOP: c000021a {Fatal ... Note Most STOP 0xC000021A errors occur because Winlogon. ...support.microsoft.com/kb/156669
  2. "STOP: c000021a (Fatal System Error)" Error! RE: "STOP: c000021a (Fatal System Error)" Error! Ya, thats what I thought I might have to do ... RE: "STOP: c000021a (Fatal System Error)" Error! just input the ...www.msghelp.net/showthread.php?tid=66202 - 52k - Cached
  3. How I fixed my Windows XP Stop c000021a {Fatal System Error} with ... How I fixed my Windows XP Stop c000021a {Fatal System Error} with Knoppix Linux. 2008 March 14 ... Message: Stop c000021a {Fatal System Error} The Session ...healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-f... - 53k - Cached
Sep 16, 2009 | Microsoft Windows XP Professional With...
Iomega HDD Fatal Error 05
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Jul 05, 2009 | Iomega ScreenPlay
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Emachine will not start up it says fatal error regeristery not updated, then turns off
Linux and UNIX ld command help -z defs, Force a fatal error if any undefined symbols remain at the end of the ... which are marked lazyload will not be loaded at initial process startup
E-mail CHID: 5369 Unfortunately we were unable to find anything about the Fatal Exception error message you are encountering we suggest you go through the basic fatal.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | E-Machines eMachines Desktop PC
I730 phone module fatal Error
I've had my i730 for years. Never had that problem. Virus? Or maybe just too much info in it. I used mine on a picture web site and that about wiped it out. But the reset took care of that.
Sep 25, 2007 | Samsung SCH-i730 Pocket PC
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
