Hi i have a candy smart automTic washer dryer but da water in da washer wil not drain and i dont np what to do. Can sumone help i really need a washer coz i hav kids n like al kids they lik to get dirty
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 19, 2011
Machine starts to spin out of control
Both problems could be related to a blocked drain, from what I can see in the manual. 3 Things to check -
1. Clean the filter - instructions can be found on age 24 of the manual.
2. Check the drain hose has no kinks/securely fitted.
3. Check the drain trap under the sink for blockages. Make sure waste water can drain away freely.
Keep a couple of old towels handy when checking the drain filter, if water is trapped in the machine, it will flow out of the filter housing when you remove it. Try a drain cycle for a minute or two before you remove the filter, then turn the machine off, and check it. That way you'll have drained as much water as it will allow.
The manual can be found here- http://service.candy-domestic.co.uk/manuals/pdfs/CNW156.pdf
Jan 07, 2014 | Candy CNW136 Front Load Washer/Dryer
Candy Washer/dryer Stalls
Have you checked the drain hose connection? Make sure the bung is clear in the trap
Aug 07, 2012 | Candy CNW136 Front Load Washer/Dryer
My candy 514 is not draining properly - even after a spin cycle the clothes are still very wet suggesting that water is not getting out
I have a GE and my friend has the same problem with his whirlpool. Removed the frt cover adn looking at the washer on the left side there is a clean out drain. My kids leave things in pockets and filles this drain up and washer will not drain. it is very easy to do
Oct 26, 2009 | Candy CNW136 Front Load Washer/Dryer
My washer will not keep water in the tub. The
Hi, You need to make sure the drain hose is as high as the top of the washer. If the drain hose is to low, the water wil drain out before it reaaches the proper water level.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 15, 2009 | Maytag PAV2300 Top Load Washer
Water not draining away
hi
check the hoses from the pump and check the pump for any obstructions.
Feb 14, 2009 | Washing Machines
Hi, I have a Candy CIW100T washing machine and its recently stopped draining the water aty the end of the cycle. Can you help please? Thanks
Check filter behind kick plate on bottom front of machine. Drain water out first by lowering drain hose into bowl or bucket.
Plz come back if further help required.
Dec 02, 2008 | Candy DQW150 Front Load Washer / Dryer
Will not drain
Try cleaning the filter as when this gets all clogged up the water doesnt drain thru the pump
Apr 24, 2008 | Candy AQ130 Front Load Washer
Dryer - acquaviva 1300 - how it works?
the dryer has 2 thermostats if these are blown then the heater wont work but you can check to see if the element is burned out by unplugging your machine opening the top off it the wires that plug into the element replace with a plugged wire with bare wires on the end place each wire into the correct connector and turn the plug on this will either heat the element up or if it doesnt then the element is blown m8
Aug 21, 2007 | Candy AQW130 Front Load Washer / Dryer
Hot wash programme won't work.
more than likely that your timer dial has a fault on it to replace your timer dial is alot if u need the 90 degree wash then you really are better off buying a new washer just as cheap to do it this way sorry for the bad news theres nothing you can really do sorry yet again m8
Dec 11, 2006 | Candy AQ130 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
